Edge Green or Radiance 3D mini for Aspect ratio? - AVS Forum | Home Theater Discussions And Reviews
Old 01-12-2013, 05:08 PM - Thread Starter
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
Will the Edge Green or Radiance 3D mini do a good job in filling my screen when there's a 16:9 or 4:3 source. Without much cropping or PQ loss? Sorry for the noob question don't know to much about VP's. I have a Elite 70X5 LED set . Thanks..
rhed is offline
Old 01-12-2013, 05:52 PM
Kelvin1965S's Avatar
Quoted: 257 Post(s)
Liked: 153
Is your display a 2.35:1 (22:9) aspect ratio? If so then they will both have to do exactly the same amount of croping or distorting of the image to stretch it from 16:9 to 'fill' a 2.35:1 screen. It is simply the laws of physics. There is no magic bullet so you either stretch or crop, or perhaps a mixture of the two (but you'll need the Lumagen for that since the Edge is a bit more limited. However, IHMO it's a crummy excuse to buy such a good video processor.
If it's a 16:9 screen and you just want to fill it with 2.35:1 content then pretty much the same applies.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
Old 01-12-2013, 07:37 PM - Thread Starter
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
Yea.. My display does stretch or zoom. If I zoom it fills the 2:35:1 but I don't like how there is cropping on the sides of the image.
rhed is offline
Old 01-13-2013, 03:20 AM
Gordon Fraser's Avatar
Quoted: 114 Post(s)
Liked: 149
If you don't want to crop the sides then you will need to do some form of non linear stretch. This will affect geompetry but there is no way round that. Lumagen have an NLS mode that does at least allow you to decide how much croping, where the distortion happens and by how much, so at least you can decide the look of this effect.
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
Old 01-13-2013, 05:41 AM
BakeApples's Avatar
Quoted: 245 Post(s)
Liked: 139
I think the Mini3D does a great job with the NLS, i have tried several 16:9 sources and stretched them to 2.35:1 and i think it looks surprisingly natural on my cinemascope screen.
Sure, the picure will get a little distorted and you will loose a little information at the top & bottom but like someone said before, you can tweak these settings to your own preferences.
Personally, i love the NLS feature!
Sony VPL-VW550 | DNP Supernova 08-85 116" 2.35:1 | Lumagen Radiance Pro 4440 | Pioneer SC-LX89 | Oppo UDP-203 | Zappiti One 4k HDR | PS4 | Audio Pro/Pioneer 5.1.4 Atmos | SVS SB-1000
BakeApples is offline
Old 01-13-2013, 06:25 AM
Quoted: 257 Post(s)
Liked: 153
Personally I hate the NLS feature, but each to his own. I just don't 'get' the 'must fill the whole screen all the time' mentality. I use side masking for 16:9 cheap pieces of black velvet pinned up to cover the side bars and just watch at 1.85:1.
Still, there would only be one model of everything AV if we all liked the same thing. smile.gif
Old 01-15-2013, 01:20 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
I believe the older Vision processors will do this, for a few hundred$ used.
Noah
noah katz is offline
Old 01-15-2013, 01:50 PM
Toe
Toe's Avatar
Quoted: 1453 Post(s)
Liked: 1832
Agreed! I certainly don't stretch everything as I still prefer to watch 2d blu ray in its OAR, but for things like animated 1.78/85 3d and games I am really enjoying the NLS feature more than I expected. I love all the tweaking options as well. VERY cool option/feature to have for CIH users IMO.
Toe is online now
Old 01-15-2013, 06:00 PM
Kilian.ca's Avatar
Liked: 37
[deleted]
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
Old 01-16-2013, 10:31 PM - Thread Starter
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
What does the NLS feature really do? Is this on the mini 3D?
rhed is offline
Old 01-17-2013, 09:42 AM
Toe
Toe's Avatar
Liked: 1832
It allows you to stretch out, or stretch and crop a 1.78/85 image to 2.35/40. You first setup your projector to fill a scope screen horizontally which will give you a well framed scope image, but 1.78/85 will shoot off the top/bottom of the screen onto your screen wall. In order to get your 1.78 image framed right at this point without having to re-zoom the projector, you setup a shrink option which scales the image down to fit the 1.78 image inside the 2.35 screen (black bars on the sides). At this point you can then NLS the image to fill the 2.35 screen by stretching, or stretching and cropping (you could just crop it as well, but this would not require setting up the NLS feature).
This is not just a feature with the Mini as quite a few VPs can do the NLS from my reading. The Mini does allow lots of options for both the stretching and cropping to tailor things however you think looks best. The downside to all this is you are loosing resolution and altering the original geometry, so it is a trade off and only you can determine if it is worth it. For me it is worth it for some things like 3d 1.78, games, menus and extras (which I never really watch anyway). For 2d blu ray I still much prefer to keep OAR intact AND get the full resolution by zooming my projector down which is extremely easy if you have a motorized lens and even easier if you have lens memory.
Here is a video by forum member BrolicBeast that shows NLS in action........
http://www.youtube.com/watch?v=jwF7nYe-YzM
Toe is online now
Old 03-03-2013, 07:26 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
What is the cheapest video processor that can do 2.35:1 NLS from 1.85:1 image?
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
Old 03-04-2013, 09:45 AM
Josh Z's Avatar
Quoted: 2137 Post(s)
Liked: 1434
I think a lot of you are misunderstanding the o/p's question, and he's misunderstanding what you're telling him. He does not have a 2.35:1 CIH screen. In his first post, he said that he has a Sharp Elite PRO-70X5 TV. That's a standard 16:9 set.
rhed, I think you need to better describe exactly what it is you're trying to do. Your TV is 16:9 (1.78:1). Some movies will be wider than that (2.35:1), which will appear with black letterbox bars on the top and bottom. Some movies or TV content will be narrower than that (4:3, aka 1.33:1), which will appear with pillarbox bars on the sides. Are you trying to make everything fill the screen without bars, or are you only concerned with 4:3 material?
What this ultimately comes down to is that the geometry is what it is. Your TV is one shape. If you want to fit content of other shapes into it, you need to either crop or stretch it. Or you can just learn to deal with the black bars, which is by far the easiest and best solution.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
Old 06-19-2013, 07:26 PM
Tazishere's Avatar
The least expensive solution for you is the Edge Green. It has an easy to use continous zoom to fill your screen exaclty as much as you want. The remote control has +zoom and -zoom straightforward controls that bypass the menu, for when that's all you need to do.
BTW, you are asking a controversial question. In this place people will scold you for wanting to do that.
Tazishere is offline
