Crystalio 3100 3D Support or alternatives - AVS Forum | Home Theater Discussions And Reviews
Old 01-21-2013, 03:05 AM - Thread Starter
AJSG's Avatar
This could be a really dumb question but I cannot find a straight answer from Dr Google.
Can the Crystalio 3100 support 3D images? I am about to upograde my projector to a 3D one and I had this sudden doubt.
If it doesn't does anybody know what the alternatives are?
I am feeding this into the 3100:
Sky+ HD via HDMI and separate Coax Audio
PS3 via HDMI and separate SPDIF Audio
Wii vis Component and L/R Audio
Arcam DVD player via HDMI and Coax Audio, also feeding SPDIF Audio to amplifier separately for Audio only CDs
Dune 3.0 Network Player via HDMI and Coax Audio
So I need 4x HDMI input, at least one Component Input and configurable audio (3x coax 1 spdif 1 L/R)
At the moment I run everything via an Arcam amp but happy to change the amp for something a little more modern.
Speakers: 5 speaker setup with subwoofer.
Display is via a 40in Loewe (non 3D) and an Infocus in76 projector.
Thanks in adavance,
Andrew.
Gentlemen prefer Bonds...
AJSG is offline
Old 01-22-2013, 04:45 PM
uderman's Avatar
Quoted: 91 Post(s)
Liked: 44
checkboard type 3d normaly found cable/satellite tv is fine. crystalio should be able to pass that.
I dont understand why you run hdmi and audio seperately. crystalio can support DD,DTS bitstreams and 2c pcm audio tru hdmi.
your only trouble is going to be PS3. Crystalio wont support the 3d it provides and can not pass multi ch pcm or lossless bitstreams.
alternatives are:
dvdo iscan duo
lumagen mini or xe
or you can buy BD player with 2 hdmi out. 1 directly into projo and 1 into reciever. Crystalio or any processor will not help much with BD picture beside color management and minor noise reduction(i prefer untouched 1080p)
Wanted:
HD-VMD Discs
Muse/Hi-Vision Discs - Mint/Complete Only!
uderman is offline
Old 01-23-2013, 12:40 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 488
I would definitely just grab a Dual HDMI player.
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
Old 01-23-2013, 01:43 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Or you just keep your complete setup and just add a little HDMI matrix switch in between the sources and the processor and the beamer be good with it ! This way you can route 3D signals around the VP, while keeping everything in place.
Fudoh is offline
Old 01-26-2013, 01:17 PM - Thread Starter
AJSG's Avatar
Almost nothing I own can send DD etc via an HDMI cable, even in 1.4. HDMI is a gargantuan waste of space and money. I absolutely hate it, that is why I bought 2 Furys and use one and keep the other just in case they get shut down. Whole house is served 1080i via Component.
Sky+ HD box, even the new one will NOT send DD via HDMI, my DUNE 3.0 BD won't either. PS3 doesn't work either, it sends some simil DD but nothing like the quality of the full DTS you can get with a separate coax connection.
Thank you for the response but in the end I just bought a friend of mine's set up, the whole thing from processor to 3d projector. Am selling the 3100 and all the Arcam gear on eBay! Wish me luck.
Andrew.
AJSG is offline
