Help: Video Processor with a component output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-25-2013, 09:11 AM - Thread Starter
daddygrant's Avatar
Hey Guys,
We are getting a system that requires a component link to display video on a group of TVs through out a nursing home. Our Recreation department is looking for a media/video switch/processor for various sources ( VGA, HDMI,Component, Composite ... ) that is easy to use. We don't need anything really fancy. Just something reliable.
I looked at the DVDO Edge but the output is only HDMI. I did consider getting a HDMI to Component box but I'm trying to reduce the amount of equipment to lessen the likelihood of staff messing things up.
Any suggestions?
daddygrant is offline
post #2 of 5 Old 01-25-2013, 12:46 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
The current processors from DVDO and Lumagen only have HDMI outputs, but if you go back a generation or two, you usually get a set of BNC outputs which can be configured to be RGBHV/VGA or component. Maybe a DVDO iScan VP50 or something in the same range.
Your problem will be HDCP-encrypted HDMI sources though. Once you have a source with a HDCP-encoded output, the analogue outputs on the video processor will be switched off.
Fudoh is offline
post #3 of 5 Old 01-25-2013, 03:08 PM - Thread Starter
daddygrant's Avatar
Thank you for your reply.
Interesting. Can a HD fury mitigate that? We plan to use a VCR, DVD player, a laptop and a Roku.
post #4 of 5 Old 01-25-2013, 05:16 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Sure, but then again, just get an EDGE and put the HDFury on it's output. HDF2 and 3 output component just as well.
daddygrant likes this.
Fudoh is offline
post #5 of 5 Old 01-26-2013, 06:04 PM - Thread Starter
daddygrant's Avatar
Thank you. I'll get the edge and the hd fury2
Reply Video Processors
