Display six NTSC inputs to a single 6 way split screen HD output? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-31-2013, 08:29 AM - Thread Starter
MichaelFarley's Avatar
I would like to display 6 NTSC standard definition (640x480) video signals via RCA composite or 75ohm BNC, simultaneously on a single HDTV in a 6-way split screen format via HDMI, DVI, or VGA. The video should be realtime (~30fps). Does anyone know how I can accomplish this?
Thank you!
MichaelFarley is offline
post #2 of 2 Old 02-26-2013, 01:15 PM
Glimmie's Avatar
Quoted: 738 Post(s)
Liked: 613
Thank you!
There are quite a few devices made for security cameras that will do this. You can find them quite cheap on EBAY. The image quality is usually mediocre, good enough for security cameras.
On the extreme end there are broadcast products such as the Evertz VIP product line which are very high quality but now you are into many thousands of dollars.
http://www.evertz.com/products/VIP
Here's another broadcast unit:
http://www.sierravideo.com/cgi-bin/complex2/catprodC.pl?catid=25
Glimmie is offline
Reply Video Processors
