Is Video Processor Required To Capture HDMI Output via PC Capture Card ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-12-2013, 04:59 AM - Thread Starter
Dushy Squirt's Avatar
Hi,
I would like to be able to capture the HDMI output from a set top box using a Viewcast Osprey 240e capture card installed in a PC.
The breakout cable that connects to the Osprey 240e in the PC has BNC component connectors for Video and RCA connectors for L/R audio.
Do I need a video processor to accept the HDMI output from the set top box and convert this signal into component Video and L/R audio? Or, will a direct cable connection using an HDMI to 5 RCA cable do the job, obviously I would have to fit 3 x RCA/BNC adapters on the component leads?
Thx
Dushy
yes she does !
Dushy Squirt is offline
post #2 of 2 Old 04-12-2013, 08:22 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Don't know your capture card, but HDMI to an analogue input using a breakout cable will NEVER work. If your capture card only has analogue inputs you need a D/A converter.
The HDMI output might also be HDCP-encrypted, so you would need a HDCP decryptor. A HD Fury combines both, the HDCP killer and the D/A converter, into a single box.
Fudoh is offline
Reply Video Processors
