VP50Pro image shift. - AVS Forum | Home Theater Discussions And Reviews
Old 04-15-2013, 07:49 AM - Thread Starter
barcoed's Avatar
Out of ignorance I must ask this question (I’m thrashing myself for not being able to work out the answer!).
I have a 4X3 projector being fed from the VP50Pro. Various sources are in front of the VP50Pro (all HDMI).
I have a lot of 4x3 material (50hz pal) and all works fine for that.
When viewing HD material, I have set a 16x9 screen on the VP50 and squished the image on the projector (Sony G70 CRT) and shifted it up to the top of the tubes. I then roll-up the electric screen to frame the 16x9 image. All good so far.
When watching films (typically 2.35:1) 24hz upped to 48hz by the VP50, I have black bars top and bottom, where I’m just wasting video bandwidth. (I can live with that) .I can't squish or move the image any more to properly frame the image as I'm out of adjustment on the projector.
What I would like to do is move the active image on this 2.35:1 (or 2.4:1) stuff to the top of the 16x9 output (leaving a single black bar below (the sum of the top and bottom bars detailed above)) so I can roll-up the electric screen to properly frame the image again
I can’t work out how to do this with the VP50 - what screen to set, what aspect etc..?
barcoed is offline
Old 04-29-2013, 02:16 AM - Thread Starter
barcoed's Avatar
... any ideas?
barcoed is offline
Old 04-30-2013, 06:33 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
VP50 or 50Pro ? I can look into this tonight or tomorrow.
Fudoh is offline
Old 05-07-2013, 06:38 AM - Thread Starter
barcoed's Avatar
Thanks. It's the VP50Pro (Latest f/w).
barcoed is offline
Old 05-15-2013, 05:10 AM - Thread Starter
barcoed's Avatar
Any luck, Fudoh?
barcoed is offline
Old 05-15-2013, 06:50 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
I tried shortly, but it was too complicated to wrap my head around it - especially since you squeeze the image vertically on the projector, but I don't. Vertical picture shift only gets enabled in one of the lens modes or when the picture AR is under 1.33. I'll try again.
Fudoh is offline
