Laserdisc S-Video to HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 05-03-2013, 11:46 PM - Thread Starter
simkofab's Avatar
I recently bought a Panasonic P50S60 Plasma. I had a 40" Mitsubishi CRT. Yeah, I know. Anyway I still enjoy my laserdiscs. I have a Pioneer CLD-79. It has S-Video and a composite output. How do I get the best video signal to my TV?
My TV only has 2 HDMI inputs and one composite. My HD DVR and Blu-Ray player are in the HDMI inputs.
I can easily swap out one of my HDMI connections to watch a laserdisc when I want to as my TV is on a stand. I have yet to attach the player to the composite because I don't want to pull the player out of the cabinet and run everything twice. Also I'm running my audio through a JVC DSP-A1 receiver.
I've read a little bit about converters and scalers but I've been out of the game for about 15 years and I'm not sure of what I need. I could use some guidance.
simkofab is offline
post #2 of 17 Old 05-04-2013, 12:39 AM
Roger Dressler's Avatar
Quoted: 1519 Post(s)
Liked: 710
You'll need something like this. It includes upscaling which, while not necessary, can be very useful if the display does not have scaling.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #3 of 17 Old 05-04-2013, 12:07 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
The monoprice box is a very generic (and cheap) deinterlacer and upscaler.
There's an excellent change that your TV will do a better on it's own. And for that matter I wouldn't worry about the connection being composite only. While your TV won't have the best comb filter around, it's very likely at least on par with the one built into your LD player.
Unless you spend a lot more money, it won't get any better than running composite directly into the TV set.
Fudoh is offline
post #4 of 17 Old 05-05-2013, 06:48 AM - Thread Starter
simkofab's Avatar
Thanks. After thinking about it I figured my new TVs processor would do a pretty good job compared to my LD. I'm just going to go with a quality cable and the composite.
simkofab is offline
post #5 of 17 Old 05-06-2013, 11:38 AM
Josh Z's Avatar
Quoted: 2134 Post(s)
Liked: 1432
Composite video is Laserdisc's native format. If you use S-video, you're relying on the quality of the comb filter inside the LD player. Very few LD players (arguably none) have good enough comb filters to make this worthwhile. Even the cheapest of modern TVs have comb filters at least comparable to if not better than even the best LD players. Composite is almost always your best connection choice with Laserdisc.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #6 of 17 Old 05-06-2013, 07:10 PM
TK Doom's Avatar
Why do you say composite?
Wouldn't component be a better connection than Composite?
Confused.
TK Doom
Unreal Tournament Forever
Project Gotham Racing too!
TK Doom is offline
post #7 of 17 Old 05-06-2013, 07:49 PM
Glimmie's Avatar
Quoted: 725 Post(s)
Liked: 591
Confused.
LaserDisk is a COMPOSITE signal right off the disk. DVD is COMPONENT off the disk. Svideo is halfway in between in terms of transmission quality but as the signal on the laserdisk is composite, it must be converted to Svideo inside the laser disk player. If you feed composite to your TV then the TV must convert it to Svideo then onto component.
It comes down to which has the better converter. And based on technology advances, the TV is far likely to have a better converter.
Now just to confuse the issue more, some laserdisk players convert the composite to Svideo for noise reduction, than back to composite. So in this case Svideo would be the best connection. But that's hard to tell without a service manual. I believe the CLD 79 has direct composite out. I think it's the CLD97 or 99 that does this double conversion.
So what it really comes down to is which looks best to you. Just buy a low cost composite and Svideo cable. Don't spend more than $5-10$ on either one. Then just pick which ever looks best to you. In the end, that's all that counts.
Glimmie is offline
post #8 of 17 Old 05-06-2013, 11:31 PM
TK Doom's Avatar
Yes, I just found this out while re-connecting my Laser disc to my system.
TK Doom
TK Doom is offline
post #9 of 17 Old 05-07-2013, 09:49 AM - Thread Starter
simkofab's Avatar
Thanks for the details. I was thinking I'd need some type of scaler. I wasn't thinking about what my new TV could do. I have a lot of good cables laying around so I'll try both types & leave it at that.
simkofab is offline
post #10 of 17 Old 05-07-2013, 10:44 AM
Josh Z's Avatar
Liked: 1432
Confused.
No Laserdisc players can output Component Video for Laserdisc. The only LD players with Component outputs were the LD/DVD combi players at the end, and the Component connections only work with DVD.
Josh Z
Josh Z is offline
post #11 of 17 Old 05-07-2013, 07:11 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
European Sony LD players did some internal composite to RGBs conversion and allowed LD playback through RGB scart connections. Terrible quality though.... rolleyes.gif
Fudoh is offline
post #12 of 17 Old 09-20-2013, 03:40 PM - Thread Starter
simkofab's Avatar
Well after finally being able to get back to this I realized that I misspoke. My TV doesn't have composite but component jacks. I need a converter now. I see that a lot of people purchased that little white box labeled "MINI". There are others that cost more but they add S-video and/or component switching also. Are they all pretty much the same when it comes to converting composite? Do they all require power?
simkofab is offline
post #13 of 17 Old 10-08-2013, 08:01 AM
IanD's Avatar
Quoted: 82 Post(s)
Liked: 50
Composite is the lowest common denominator for displaying video on a TV and I would expect to be retained until analogue video is removed completely.
Composite video has a yellow socket and is usually associated with a red and white socket for stereo analogue audio.
It's possible a TV might locate these sockets to the side if not the back.
If you have a DVD Recorder, they are usually the easiest way to convert laserdisc composite to HDMI or component, but may not have the absolute best quality: that takes a lot more searching and selecting effort.
IanD is offline
post #14 of 17 Old 10-08-2013, 03:52 PM
benareeno's Avatar
Quoted: 18 Post(s)
I'd be very interested to hear how a laser disc looks on a plasma...my guess is that it would not look good at all...but, let us know!
benareeno is offline
post #15 of 17 Old 12-04-2013, 08:40 PM
ELIE BARNES 3's Avatar
it looks really good, i'm using a cheap scaler and s-video to hdmi, led tv
ELIE BARNES 3 is offline
post #16 of 17 Old 12-06-2013, 09:04 PM
Krell789's Avatar
I have a LD plugged into my plasma using the S- Video connection it looks really good. I have another LD plugged into my other plasma using the composite connection it also looks good, it's better than I thought it would look myself, I'm quite impressed with the results.
Krell789 is offline
post #17 of 17 Old 01-13-2014, 11:27 AM
Selden Ball's Avatar
Quoted: 3046 Post(s)
Liked: 1494
Hopefully you've solved your connection problem by now but...
Yes, converters which generate a component signal all require power. Really cheap in-line composite to S-video converters could get by without one because they just included some in-line filters to separate the chroma from the luminance signal. Component video signals are more complicated.
Double check the component connections on your TV. Some TV manufacturers have merged their composite and component inputs so that there are only 3 RCA connectors but one of them can be used for a composite signal.
Selden
Selden Ball is online now
Reply Video Processors
