algolith dragonfly remote help!!!! - AVS Forum | Home Theater Discussions And Reviews
Old 06-12-2013, 11:14 PM - Thread Starter
balboarules's Avatar
Quoted: 78 Post(s)
Liked: 35
I just got a used Algolith Dragonfly and it did not come with a remote, I believe it is set to the wrong video output as I cannot see anything on the set from it.. I found a place to download the manual, it states that you have to hit the format button on the remote to change the video output resolutions.. but I have no remote! I downloaded from the Logitech site the dragonfly, however the format button does nothing, the unit has a blue light on the front that flickers when you press any buttons, the format button does not make the light flicker..
I need to find this remote, or find someone with this processor that would let me borrow their remote to program mine.. I would gladly pay for the use of it.. or if anyone knows anywhere I can buy this remote, please direct me there.... I found NOTHING on line with my hunt so far.. except the manual which I printed out..
PLEASE HELP!
balboarules is offline
Old 06-13-2013, 03:00 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Can't help you directly, but I think that the Dragonfly uses the same remote as the Mosquito HDMI units. Should make it much easier to find somebody with a running unit.
Fudoh is offline
Old 06-13-2013, 08:21 PM - Thread Starter
Quoted: 78 Post(s)
Liked: 35
I am hoping that is the case.... I have someone who I sold the Mosquito HDMI to who should have the remote.. he is still digging around for it.
Old 06-14-2013, 12:01 PM - Thread Starter
Quoted: 78 Post(s)
Liked: 35
Is anyone out there using this in their setup?
