I need to scale a blurauy down to vga - AVS Forum | Home Theater Discussions And Reviews
Old 07-11-2013, 08:02 PM - Thread Starter
filefish's Avatar
I have an older projector that falls flat on its face with a Blu-ray player, I need to scale it down to vga/svga
Right now the HDMI out on the player is connected to a HDMI to RGB adapter. When I first turn the player on, the projector resolves the splash screen just fine, but once it gets to the menu it falls on it's face. Any ideas?
filefish is offline
Old 07-12-2013, 06:01 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
You should be able to force the player's output resolution to 480p, no matter what.
I would - temporarily - connect the player for a TV to see if the player keeps the 480p resolution all the time, or it defaults back to 1080i/p at some point. If it does - for whatever reason - you're likely better off with a different player than using an external video processor for downscaling.
Fudoh is offline
