Lumagen Radiance 20XX Support Thread - Page 11 - AVS Forum
 14Likes
post #301 of 315 Old 12-30-2014, 12:33 PM
Pres2play's Avatar
Quoted: 142 Post(s)
Liked: 183
Thanks, Gordon. I'll follow this up in the Mini 3D thread.
Pres2play is online now
post #302 of 315 Old 12-30-2014, 01:27 PM
Pres2play's Avatar
Quoted: 142 Post(s)
Liked: 183
Originally Posted by jrp View Post
Please reread my above posts on Chroma bandwidth. The Chroma Burst test pattern is not a good indicator of Chroma bandwidth for real video for anything that is actually processing the video as it has out-of-bound frequency components. It cannot be used to imply there is some "undetectable with normal video images" roll off of Chroma. The Chroma Burst pattern is useful, but not for this.
It is true that no filter is perfect, but the Chroma bandwidth of the Radiance with real world video is simply excellent. The Radiance - since it is processing the video and converting 4:2:2 to 4:4:4 and back - behaves exactly as it should with the Chroma Burst pattern.
That said, all current Radiance units have the same architecture and perform essentially the same. The 2XXX units do have improved precision compared to the RadianceMini/XS/XD/XE.
I use the Color Space Evaluation pattern and I don't see banding on color bars or burst patterns. The color transitions are smooth. Am I using the wrong pattern?
Edit: also checked the Luma Multiburst Linear pattern and Luma Wedge pattern (below) on the S&M disc and there was no sign of high-frequency roll-off. None of the patterns showed dimming and all have fine detail.
post #303 of 315 Old 12-31-2014, 02:27 PM
Pres2play's Avatar
Quoted: 142 Post(s)
Liked: 183
No 4k on the 20XX? Ouch!
post #304 of 315 Old 01-01-2015, 07:38 PM
uderman's Avatar
1- geometry correction - is this aspect ratio selection?
2- artifact reduction - noise reduction?
3- Looking at the block diagram in owners manual, it appears artifact reduction and geometry correction happens after deinterlacer. Is noise reduction more effective on progressive images?
4a- some sources output video(speaking sd of course) in original aspect ratio. I.e pillar boxed for 4:3. Is it better to out all content in full setting and have lumagen pillar box or zoom in (4:3 letterbox) after deinterlacer as block diagram suggest?
4b-is noise reduction more effective before aspect ratio adjustment? I am guessing zooming in on 4:3 lbx sources is considered scaling and can confuse noise reduction?
4c- do you suggest deinterlacer->noise reduction->darbe(assuming it happens here)->aspect ration control->scaling->color correction?
5- where in the chain darbe is applied?
6- can lumagen pass through dolby atmos, dts x codecs? Via fw possibly?
7- is there a setting in edid section to force pal/50hz output?
8a-Is there a way to have auto aspect ratio automatically apply masking on 2.35:1 image? I have some films with burned subtitles outside picture, I cover with masking.
8b- can auto aspect ratio detect 4:3 lbx (sd) image that are placed on the top part of the screen? I have some films that have the video moved up to leave room for burned in subtitles.
Thank you
uderman is offline
post #305 of 315 Old 01-01-2015, 10:08 PM - Thread Starter
jrp
jrp's Avatar
Quoted: 39 Post(s)
Liked: 47
1- geometry correction for the Radiance is aspect ratio selection, plus cropping and masking.
2- artifact reduction includes the noise reduction.
3- Artifact reduction and geometry correction happens after deinterlacer.
3a- I expect that noise reduction has the effectiveness on interlace and progressive assuming they have relatively the same initial quality.
4a- Output sources exactly as in the source and allow the Radiance
4b-Hard to say, but I believe noise reduction at the source resolution may have a slight edge given there are no extra pixels added by the scaling of the aspect ratio correction. Noise reduction (and Darbee DVP(TM)) are area based and extra pixels after scaling reduces the effective area the algorithm can look at.
4c- Deinterlacer->noise reduction->edge enhancement->darbee->aspect ratio control & scaling (as one operation)->color correction is the order in the Radiance and we think the prefered order.
5- See 4c for Darbee position in the pipeline
6- The Radance units (except the RadianceXD) can pass through Dolby Atmos. I assume DTS X is like Atmos and encoded with the same data formatting as DTS Master and so the Radiance should be able to pass it. I talked with the tech guy from Dolby at CEDIA and he assured me anything that passes Dolby TrueHD can pass Atmos. We have at least one system doing so, but I believe the owner did manually select Atmos somehow. So Dolby's statement may come with caveats. I do not have any info on DTS X. So the jury is out on DTS X for now. If someone is able to test DTS X with a Radiance let us know your results.
7- I think you mean for a source in front of the Radiance. Using the Radiance manual EDID you can turn off 60 Hertz formats if you like.
8a-The Radiance will apply the selected output mask for the selected output style. So I do not think we can do this with auto-aspect at the moment. You can do this manually by associating different output styles having different output mask settings with different memory selections (MEMA to MEMD).
8b- The Radiance uses the number of blank lines at the top as part of its auto-aspect processing. So if films have the video moved up to leave room for burned in subtitles it would defeat the auto aspect processing.
Jim Peterson
Lumagen
jrp is online now
post #306 of 315 Old 01-02-2015, 12:19 AM
uderman's Avatar
thank you!!!
uderman is offline
post #307 of 315 Old 01-02-2015, 09:29 AM
uderman's Avatar
If they decided to go with rec.2020 colorspace for 4K Bluray disc and 4K displays with rec.2020 colorspace capabilities start to appear, can current radiance units keep up?
I understand it wont input 4K but can it upscale 1080p Blurays and convert to rec.2020 colorspace?
Can a fw update allow 4K60 output to be in rec.2020 and calibration controls act accordingly?
I am trying to decide between a 1080p and 4K unit. I don't own a 4K display yet but if it's future proof enough, I will go with 2144.
last question, I have an already calibrated Pioneer last gen plasma. Do you recommend I run auto calibration on this input or an input with default settings(none-calibrated) does it matter?
uderman is offline
post #308 of 315 Old 01-02-2015, 11:48 AM - Thread Starter
jrp
jrp's Avatar
Quoted: 39 Post(s)
Liked: 47
I understand it won't input 4K but can it upscale 1080p Blurays and convert to rec.2020 colorspace?
It may be possible to upgrade the 21XX units for Rec 2020 colorspace in the future, but not the Mini/XS/XD/XE units as their FPGA's are full and the 2020 color space is expected to add gates in the FPGA. Until we implement the 2020 color space we will not know if it fits in the 20XX units or not, and we are not even certain on the 21XX units yet.
If we implement Rec 2020 colorspace, it is only needed for Rec 2020 encoded disc's. The auto calibration software and Radiance would both need updates, but assuming the updates get done, it would be possible to auto calibrate in Rec 2020.
I recommend the Pioneer be in a default state. You may be able to get a good calibration with the post-calibrated Plasma, and you can try first if you like. If there is going to be an issue it would be due to the primaries being pulled in too far, or to non-linearity the TV/projectors induce in their calibration hardware due to their use of a non-linear color space for their controls.
Choose a color mode (names might be something like normal, user) that is reasonably linear, and has the primary and secondary points at or outside the Rec 709 triangle. Turn "dynamic" features off (e.g. frame interpolation and dynamic contrast). Set black and white levels with the Pioneer controls and the Contrast2 and Contrast1 patterns in the Radiance. We also suggest you consider calibrating the 100% White color temperature manually with display controls as well. This is required with Chromapure, but may not be needed with either Calman or Lightspace since they can do the calibration of 100% white as part of the auto-cal. See our TechTip 2 for some hints on calibration that can be applied to autocal.
Jim Peterson
Lumagen
jrp is online now
post #309 of 315 Old 01-02-2015, 04:08 PM
uderman's Avatar
I am leaning towards 2144 in case I get a 4K display down the road. I am looking to place my order this weekend.
Since you said there is still room on 21xx units fpgas,
1- what are likely updates?
2- I will be using an hdmi switch then feed lumagen into preamp therefor
Source->hdmi switch->lumagen->pre-pro->display
Is there a limitation on hdmi for how many devices you can have in the same chain?
Thanks again
uderman is offline
post #310 of 315 Old 01-02-2015, 06:44 PM - Thread Starter
jrp
jrp's Avatar
Quoted: 39 Post(s)
Liked: 47
2- I will be using an hdmi switch then feed lumagen into preamp therefore: Source->hdmi switch->lumagen->pre-pro->display. Is there a limitation on hdmi for how many devices you can have in the same chain?
1) I think we will do a Rec 2020 update for the 21XX sometime after it gets in the - as yet un-announced - Radiance Pro 4K input HDMI 2.0/HDCP 2.2 units. This is some time away. I can say that for some time to come we will be limiting updates on current units to bug fixes since the Radiance Pro development is taking the bulk of our time at the moment.
2) Yes, there is a limit, but you are not close to being there.
Jim Peterson
Lumagen
jrp is online now
post #311 of 315 Old 01-11-2015, 11:38 PM
Pres2play's Avatar
Quoted: 142 Post(s)
Liked: 183
If I may ask, masking only works with projectors? Will it work on a plasma TV?
post #312 of 315 Old 01-12-2015, 12:08 AM
ScottJ's Avatar
Quoted: 127 Post(s)
Liked: 77
Masking simply blacks out part of the image. It works with any display type.
ScottJ is online now
post #313 of 315 Old 01-12-2015, 12:26 AM
Pres2play's Avatar
Quoted: 142 Post(s)
Liked: 183
Sorry, I meant will it keep the black bars on a plasma from turning gray during dark scenes? That was my greatest peeve with plasma.
post #314 of 315 Old 01-12-2015, 12:57 AM
ScottJ's Avatar
Quoted: 127 Post(s)
Liked: 77
I've never noticed that on my plasma. I don't think the Radiance can help with that; it sounds like a limitation in the display itself.
post #315 of 315 Old 01-12-2015, 03:44 AM
Pres2play's Avatar
Quoted: 142 Post(s)
Liked: 183
Thank you Scott. The Lumagen's mask feature is so cool it got me thinking about the black bars on my old Pioneer plasma. It was never calibrated, so that might have played a role in the bars appearing gray at times.
Reply Video Processors
