Lumagen Radiance 20XX Support Thread - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #241 of 375 Old 08-15-2014, 05:33 PM
bgoering's Avatar
Quoted: 165 Post(s)
Liked: 48
Anyone else see an issue with post numbers in this thread... Before I posted this there is a link for page 9 but no page 9. After I post this I expect to see this is post #241 of 242, but there will be no post 242. Oh well...
Edit: Hmmm - maybe this post fixed it
bgoering is offline
post #242 of 375 Old 08-16-2014, 10:55 AM
Rolls-Royce's Avatar
Quoted: 239 Post(s)
Liked: 352
Originally Posted by colleycol View Post
I am on firmware 072214 and I have been experiencing a couple of things:
1. The screen took a red tint, hard to describe. Looks like red and white, instead of a black and white movie if that makes sense. The only way to remove it was to turn off the Lumagen and cycle it back on. Did this twice in a movie..
2. After that, the pic would freeze and need to be cycled again. This is during the same viewing session.
Anyone else experienced this?
This hasn't been reported by anyone else AFAIK. Try unplugging-not just turning off-the Radiance for 30 seconds or so, then plugging it back in. If this doesn't work, you can try temporarily resetting the Radiance to factory defaults (don't save before shutting down). If still bad, try reinstalling the firmware. If the problem is still there, try dropping back to the previous firmware version and see if the problem goes away.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #243 of 375 Old 09-01-2014, 12:31 AM
ConnecTEDDD's Avatar
Quoted: 1046 Post(s)
Liked: 1515
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081614 Firmware Update
Release Notes
Added option to enable Darbee enhancement for just 2d or just 3d sources. (Update time ~15 minutes @57k)
Download Link
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #244 of 375 Old 09-03-2014, 07:32 PM
Liked: 1515
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081814 Firmware Update
Release Notes
Location values displayed for 9x9x9 gamut adjustment via the menu were off by 1 for a couple locations due to a rounding error. (Update time ~3 minutes @57k)
Download Link
post #245 of 375 Old 09-23-2014, 12:31 AM
Liked: 1515
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 091114 Firmware Update
Release Notes
Fix for a bug which under rare circumstances could give strange colors in grayscale that a user may have remedied by turning off and back on. (Update time ~15 minutes @57k)
Download Link
post #246 of 375 Old 09-23-2014, 10:55 PM
911turbojk's Avatar
LUMAGEN 2143 + DATASAT RS20i I/O question
Guys,,
I about to install the LUMAGEN 2143 + DATASTA RS20i for my system , just checking in to see how everyone routes their HDMI ?
I assume all the source are routed to the 2143 , then OUTPUT 1 -> Projector Input,
However what happens to the SOUND? Do we just use the TOSLINK + the COAX on the RS20i ?
I am worried that not going through the HDMI as sound input on the RS20i will not let me get the best possible sound out of my equipments
Is that going to be the case?
HELP ~~~~~
911turbojk is offline
post #247 of 375 Old 09-24-2014, 10:38 PM - Thread Starter
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
Originally Posted by 911turbojk View Post
Guys,,
Here is a sysnopsys of an email I sent to 911turbojk:
Sources to Radiance. Radiance Output 1 to Datasat. Radiance Output 2 to projector.
The Radiance will pass audio, including HD audio, to Datasat.
911turbojk likes this.
Jim Peterson
Lumagen
jrp is offline
post #248 of 375 Old 09-25-2014, 11:19 AM
Liked: 1515
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 091214 Firmware Update
Release Notes
Fix for an issue in 091114 having problems with 480/576p reinterlacing giving blank screen or green/pink colors.
Fix for an issue with the test pattern color when editing the color gamut via the menu. (Update time ~15 minutes @57k)
Download Link
post #249 of 375 Old 10-14-2014, 12:47 PM
Liked: 1515
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 100514 Firmware Update
Release Notes
Fix for not being able to power up on an analog input.
This update is only helpful for units with analog inputs (2022/2042). (Update time ~3 minutes @57k)
Download Link
post #250 of 375 Old 10-24-2014, 02:02 PM - Thread Starter
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
Lumagen Announces the Radiance 2020 Video Procesor
Today Lumagen is annoucing the Radiance 2020 video processor. The Radiance 2020 is essentially the (now retired) Radiance 2021, minus the COAX audio output and in a smaller case.
It has exactly the same video setup, processing and calibration feature set as the Radiance 2021.
Highlights:
4 HDMI 1.4a inputs (max 1080p60)
2 HDMI 1.4a outputs (max 1080p60)
9x9x9 Linear-Gamma RGB CMS
Darbee DVP(TM) enhancement
Image-based auto input aspect selection
RS232 command port
Wired IR command input
12 VDC power supply
Case: 11 x 1.7 x 5 inches
Note that the Radiance 2020 is not rack mountable.
The US retail price for the Radiance 2020 is $2495. Volume shipments for the Radiance 2020 will begin on 10/28
Name:	Radiance 2020 front small.JPG
ID:	328953   Click image for larger version
Name:	Radiance 2020 back small.JPG
Kris Deering likes this.
Jim Peterson
Lumagen
jrp is offline
post #251 of 375 Old 10-29-2014, 09:02 AM
Liked: 1515
Owner's Manual for Radiance 2020 Video Processor is now available for download here: http://www.lumagen.com/testindex.php?module=manuals
post #252 of 375 Old 11-05-2014, 04:50 PM
Liked: 1515
Lumagen Radiance 20XX Series (2020,2021, 2022, 2041, 2042) New 110114 Firmware Update
Release Notes
Fixed issue where setting hotplug to always on could result in video not turning on for output. (Update time ~3 minutes @57k)
Download Link
post #253 of 375 Old 11-11-2014, 12:43 PM
RickAVManiac's Avatar
Quoted: 164 Post(s)
Liked: 152
Highlights:
RS232 command port
12 VDC power supply
Seem to be a very good replacement for the mini.
Does Lumagen still plan to introduce this year a new 4k processor with a full HDMI 2.0 in and out?
RickAVManiac is online now
post #254 of 375 Old 11-11-2014, 04:09 PM - Thread Starter
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
RickAVManiac and everyone:
We are obviously working on a Video Processor that will accept 4k inputs. However, currently we do not have anything to share on this product other than we are adding to our "Beta Site" list.
If you are interested in either being an "Early Beta Site" (limited), or "Beta Site" (a much larger group), please email us at support@lumagen.com with your contact info.
Jim Peterson
Lumagen
jrp is offline
post #255 of 375 Old 11-12-2014, 07:24 AM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
^ Email Sent.
dsinger is offline
post #256 of 375 Old 11-20-2014, 01:13 PM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
@jrp
Can you give a rundown on the 3 noise reduction settings? What particular noise patterns are each designed for and some idea of how the numerical scale relates to strength of the noise suppression. Any suggestions on using typical sources to test settings would be appreciated as well.
zoyd is offline
post #257 of 375 Old 11-20-2014, 01:57 PM - Thread Starter
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
Zoyd:
I don't have a lot to say on the range of enhancement settings, other then stay away from the maximum end of the range. The best setting is really a personal preference, but I can give you some starting points.
For 2D/3D Noise Reduction: I use 3 since I see a slight improvement without artifacts. For Noise Reduction, we believe it is "temporal" up to about 3, and then the "spacial" noise reduction starts to kick in. We don't know the exact point where spacial kicks in since the manufacturer has never told us. Temporal noise reduction should not affect resolution much, but spacial noise reduction will. I think the optimal range is 3 to perhaps as high as 6, with 6 starting to show some resolution reduction.
For Mosquito Noise Reduction: I use 3, and think 3 to 6 is also a good range to try.
Block Artifact Reduction: I leave this set to 0. This control is to improve horrible video quality. Don't watch horrible quality video sources.
Sharpness: I use all six settings at 3. I think the reasonable range is 3 to 6, but have heard some people using up to 10. You may start seeing some artifacts as you get to 5 and above.
Dynamic Contrast: I don't like any "dynamic" controls like this. I leave mine set to 0. Often using a slightly higher Gamma will give similar results without the chance of causing artifacts. Whether it is a Dynamic Iris, or a Dynamic Contrast, they use an area based algorithm that can, and will in some cases, be fooled into doing the wrong thing. First rule would be to not use both a Dynamic Iris and Dynamic Contrast, as they are trying to do basically the same thing and they can interfere with each other.
If you want one of these, first try the Dynamic Iris if your projector has one. I suggest you try it at a low setting. If not, or you have a TV, and you want to test Dynamic Contrast try setting it to 1 or 2. If you have a Radiance that includes Darbee DVP(TM), I suggest that the Dynamic Contrast be set at 0 and use the Darbee feature - which is similar to a "special twist on local area dynamic contrast" control, and works much better than a large-area based Dynamic Iris, or Dynamic Contrast.
Grifo, alex_t, zoyd and 1 others like this.
Jim Peterson
Lumagen
jrp is offline
post #258 of 375 Old 11-21-2014, 12:21 PM
GeorgeHolland's Avatar
Quoted: 45 Post(s)
Liked: 46
Radiance 2020 CIH and audio routing
I posted a question in the CIH section and rather than double post, included a link below:
Can the JVC RS-56 zoom method be improved with Radiance?
A second question is about recommendations' for cable routing. My configuration is fairly simple and my plan is:
Comcast set top box HDMI to Radiance Input 1. Radiance HDMI out 1 to Receiver SAT/Cable HDMI in. Radiance HDMI out 2 to JVC RS-56.
Oppo BDP-103 HDMI out 1 to Radiance HDMI input 2. Oppo HDMI 2 to Receiver HDMI BD input. Radiance HDMI out 2 to JVC RS-56.
I suppose I could use a single HDMI out from the Oppo and not mess with changing receiver audio inputs but like the idea and confirmation of the receiver source display.
GeorgeHolland is offline
post #259 of 375 Old 11-27-2014, 09:41 AM
westmd's Avatar
Quoted: 770 Post(s)
Liked: 260
Is there any technical difference between the Lumagen 2020 anf the Mini3D (except for Darbee and amount of HDMI in/outputs?
westmd is offline
post #260 of 375 Old 11-27-2014, 10:32 AM
Gordon Fraser's Avatar
Quoted: 114 Post(s)
Liked: 149
yes. The mini has a 125 point CMS and the fpga resources are now pretty much full up. The2020 has he much larger 729 point LUT CMS and more memory and larger FPGA on board so it may get further enhancements that the mini would not have capacity for.
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is online now
post #261 of 375 Old 11-27-2014, 01:10 PM
Liked: 1515
There is helpful to check the 3D Cube Resolution Comparison Guide where you can visualize the difference of calibrated color points precision over various cube resolution sizes between all available hardware solutions of pro industry & consumer market.
You can check also the 3D LUT Boxes / Video Processors Comparison Table Page which features the complete spec. list of the available hardware solutions.
These comparison screens shows only the device features that are useful or can be used for HT use only (HDMI In-Out).
post #262 of 375 Old 11-27-2014, 02:27 PM
westmd's Avatar
Quoted: 770 Post(s)
Liked: 260
Wouldn't it be best to go for a eecolorbox if I wouldn't mind skipping 3D or what is the catch here?
westmd is offline
post #263 of 375 Old 11-27-2014, 03:46 PM
Liked: 1515
Hi, I posted the above example to show the differences of specs or cube sizes visually. If you want to find or discus information about other video processors or 3D LUT boxes, you can use other threads at display calibration area of this forum.
It's better to discus here only Lumagen related stuff, thanks.
post #264 of 375 Old 11-27-2014, 08:24 PM
Quoted: 239 Post(s)
Liked: 352
The Radiance is a complete scaling and calibration solution, while the eecolorbox is a LUT holder only. The 2020 also has Darbee functionality built in.
...Royce...
post #265 of 375 Old 11-27-2014, 08:31 PM
Quoted: 239 Post(s)
Liked: 352
The Mini also has a much smaller form factor than the 2020. This could result in heat related issues with the Mini vs the 2020 when driving the processor hard (scaling + interlacing/deinterlacing + CMS + grayscale, etc).
...Royce...
post #266 of 375 Old 11-28-2014, 02:43 AM
Quoted: 114 Post(s)
Liked: 149
I have only ever come across a couple of problems where heat may have been an issue with a mini installation. In those cases the unit was located in a non optimal location and was not installed vertically as it is designed to be used. In such an installation the use of an additional heatsink would likely solve any issue...and in any case, it is extremely rare.
Convergent-AV
post #267 of 375 Old 11-28-2014, 12:07 PM
Quoted: 239 Post(s)
Liked: 352
Hi, Gordon. In no way was my post meant as a slap at Lumagen. I have a Mini that had some intermittent image instability problems when viewing 3D content, and it was suggested by the guys at Lumagen that they could have been heat-related. Although not mounted vertically, my Mini was in the open on top of a cabinet. I had also attached four standoffs to its base to allow airflow around all its surfaces. It was replaced in that installation by a 2021 which has never shown any trace of instability, and I now have a 2020 enroute to replace the Mini in its second installation (where it is now exhibiting video and audio dropouts).
...Royce...
post #268 of 375 Old 12-09-2014, 01:59 PM
chronoclast's Avatar
Quoted: 21 Post(s)
I'm a new 2020 owner and I calibrated and got it set up yesterday. My chain now is Oppo 103 (HDMI 2 output and source direct) > Marantz SR7008 AVR (processing is turned off) > 2020 > display. Both the 103 and the 2020 are set to Ycbcr 422 now. I've also tested their other color spaces. Checking with Spears and Munsil it fails horizontal chroma burst, has banding in the ramps, and the chroma range boxes aren't visible with the Oppo set to 422 and 444. It passes the chroma burst on RGB but banding is still there and the boxes aren't visible. Changing the 2020's output doesn't make a difference. Before I added the 2020 to the chain, it passed everything on 444 but 422 failed.
Should I be concerned about this?
Vizio M502i-B1, Ideal-Lume Bias Light, Chromapure, i1 Display 3 Pro, Harmony 700 Remote
Lumagen Radiance 2020, Oppo BDP-103, Marantz CD5004
Marantz SR7008, Polk Series II Monitor 70s Fronts, CS2 Center, 30s Surrounds, BIC America F12 Dual Subs
chronoclast is offline
post #269 of 375 Old 12-10-2014, 12:25 AM - Thread Starter
jrp
jrp's Avatar
Quoted: 177 Post(s)
Liked: 296
The Spears and Muncil Chroma Burst is different than actual video in two regards:
1) The Spears and Muncil Chroma burst uses out-of-Nyquist-band transitions. This is actually common in test patterns. However, actual video is required to keep transitions within the frequency limits imposed by Nyquist Sampling Theory. Within the Radiance the input pipeline is 4:2:2, and the calibration pipeline is RGB (i.e. converted to full resolution Chroma, and then to RGB), and this is done with a Nyquist filter. Nyquist filters cannot pass out-of-Nyquist-band signals without changing them.
2) The Spears and Muncil Chroma burst uses YCbCr combinations that create out-of-range values when converted to RGB, as the Radiance does in its calibration pipeline. The RGB values in the Radiance clamp negative values to 0 and over-range vales to 255 (speaking in 8 bit terms). Since black = 16 and white = 235 in 8-bits terms the RGB values must be significantly below black or above white to get clamped. The Spears and Muncil Chroma Burst pattern has values that do get clamped (both negative and over 255). So once these are converted back to YCbCr the values will be changed, and this will affect results when the data is then filtered using Nyquist based sampling.
So, are the Spears and Muncil Chroma Bust pattern useful? Certainly. We are glad to have it and the other patterns.
However, one must, as is always true for test patterns, understand what they are and how they should be evaluated. For example, the patterns can be good at checking TV/projector performance, but they do have limitations when used to evaluate a product that processes video, and this may include the processing in the TV/Projector if enabled. In fact the TV/projector processing may reduce bandwidth slightly in a non-visible way, but when put in series with another processor (e.g. Radiance), which also filters the video, the sequential effect of two filters may be visible.
Note that we did evaluate the patterns and were able to use the results to improve our performance when processing the patterns. These changes also improved our performance with actual video as well. We also found that the GF9450 video deinterlacing chip used in the current Radiance units has a very slight roll-off in Chroma bandwidth. So they are certainly helpful to us at Lumagen.
I have emailed Stacey (Spears) about my concerns that the patterns are being used by many who do not understand limitations of Nyquist Sampling and RGB clamping, and their effect on video processing. If Stacey is reading this he may even want to comment.
Note on Radiance setup: If you have a progressive source (e.g. Bluray movies), you can put the Radiance in "Game Mode" to bypass the GF9450 for that source (in Input Video Setup menu), assuming you are not using any GF9450 enhancements (e.g. edge, noise). I do not think that for real video you will see any improvement in Chroma bandwidth, but it is possible there might be a very slight improvement, and it will improve the Chroma Burst pattern. It also has the potentially nice side effect of reducing the video latency in the Radiance since it eliminates the GF9450 processing time.
Jim Peterson
Lumagen
jrp is offline
post #270 of 375 Old 12-10-2014, 04:16 AM
Quoted: 21 Post(s)
^ Thank you for the explanation. I had no idea about how the Lumagen's processing interacts with the patterns. It's only the patterns I've seen issues on anyways. The PQ looks amazing with real material. The Lumagen has made a big improvement on my setup for calibration and processing.
Reply Video Processors
