Lumagen New Radiance 21xx Video Processors - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #31 of 332 Old 04-30-2014, 03:50 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1733 Post(s)
Liked: 2136
REC2020 is a lot of larger than DCI P3, do you think that consumer display companies (they interested mainly for slim TV's/A++ power/web features) that will start to produce instantly consumer displays that can reproduce 100% of the REC2020 colors?
Note the only display right now at large inch, (42 inch) that can reproduce DCI P3 100% is the Dolby at 55.000$, and there only a few projectors with low cost from 30.000$ than can do DCI P3 100%.
I believe REC2020 will stay at papers since the whole industry is mastering the movies for cinema @ DCI P3, it's easier to see DCI P3 Stuff at home than from REC2020.
I believe for companies will stay to REC709 for 4K to keep compatibility for consumer 4K TV's that can't do REC2020, and for the all other 1080p displays.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #32 of 332 Old 05-01-2014, 09:29 AM
HogPilot's Avatar
Liked: 25
The problem is that Rec.2020 specifies far more about the UHD signal than just the color space. Compared to 709, 2020 specifies higher resolutions (both 3840x2160 and 7860x4320), higher frame rates (120Hz, in addition to 60/50/30/24), no interlaced is allowed, different primaries, higher bit-depths and a new transfer function that accounts for them, and different signal characteristics. If the industry decides not to use part of all of these standards, they'll have to re-write a new set, but broadcasters and content distributors simply can't pick and choose which part of standards they want to adhere to and which they don't. Maybe 2020 won't be it, but I'm not aware of anything else out there that attempts to define UHD standards, and unless that happens, manufacturers will have to get on board with what I find to be a lot of long-overdue changes.
ConnecTEDDD likes this.
There are 10 types of people: those who understand binary, and those who don't.
HogPilot is offline
post #33 of 332 Old 05-04-2014, 08:03 PM
uderman's Avatar
Quoted: 108 Post(s)
Liked: 51
Do you know any details on the 3D comb filter? Is it any better than TI TVP5160 by any chance? Does it have any user adjustments?
If the 3D comb filter is half decent, I can finally retire my 2 Crystalio II Vps
Wanted:
HD-VMD Discs
Muse/Hi-Vision Discs - Mint/Complete Only!
uderman is offline
post #34 of 332 Old 05-05-2014, 04:09 PM - Thread Starter
Liked: 2136
Hi, It's a better idea to ask this question to Lumagen's Forum, for quicker answer. smile.gif
post #35 of 332 Old 05-05-2014, 05:12 PM
uderman's Avatar
Quoted: 108 Post(s)
Liked: 51
I did ask it to the support page. It is analog devices adv7800 encoder chip which is also found on dvdo duo and dvdo edge. Not much to write home about if it is implemented the same way as dvdo units.
I will go with the hdmi only units and use my crystalio 2 for analog sources.
Wanted:
HD-VMD Discs
uderman is offline
post #36 of 332 Old 05-06-2014, 04:06 PM
fight4yu's Avatar
Liked: 43
the trend seems to be increasing the cube size (from 5^3 to 9^3 to 17^3), although it seems that every time it is limited by FPGA size.
For 21xx, is 17^3 the maximum for this FPGA already, or there is room for more when the next generation comes out?
fight4yu is offline
post #37 of 332 Old 05-06-2014, 10:14 PM
jrp
jrp's Avatar
Quoted: 233 Post(s)
Liked: 489
We have not decided if we would have a larger CMS 3D LUT in a future unit.
That said, I think 17x17x17 will provide exceptional results, and results essentially indistinguishable to humans verses a 33x33x33 matrix. Probably light a fie with this comment, but I just don't see a need for a larger matrix for display calibration.
Note: For video production, a larger matrix can make sense.
Jim Peterson
Lumagen
jrp is offline
post #38 of 332 Old 05-08-2014, 09:21 AM
uderman's Avatar
Quoted: 108 Post(s)
Liked: 51
Is it possible to have a dynamic output? Like 1080p24 in 1080p24 out, 480i in 480p out, 480ifilm in 1080p24 out etc..
Or is it fixed output only?
Wanted:
HD-VMD Discs
uderman is offline
post #39 of 332 Old 05-08-2014, 11:24 AM
ScottJ's Avatar
Quoted: 318 Post(s)
Liked: 162
You can set the desired output resolution as a function of the input resolution. It is very flexible that way, though I'm not sure if it can easily/automatically distinguish 480i video from 480i film.
ScottJ is offline
post #40 of 332 Old 05-10-2014, 06:17 PM - Thread Starter
Liked: 2136
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 050114 Firmware Update
Release Notes
Added support for 2124/2144 analog video and audio (not important for 2123/2143 units).
Bugfix for occasional small dashes in menu.
Bugfix for some sources not showing video when switching to them.
Update time ~15 minutes @57k from previous firmware.
Download Link
post #41 of 332 Old 05-16-2014, 07:25 AM - Thread Starter
Liked: 2136
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 050814 Firmware Update
Release Notes
Bugfix for couple issues with using configuration files from other units.
Adds fan speed control options under "Other" on menu.
Adds S-Video selection type for inputs 9 and 10 on 2124/2144 (Svideo uses component Green input for Y and component Blue input for C).
Output trigger option now available if purchased using this firmware.
Bugfix for certain combination of setting and sources that can give an occasional momentary screen tear in video.
Added an option in menu under Input: HDMI Setup: Aspect Setup called Aspect Set which enables setting the same input aspect across src resolutions for the current memory for remote/rs232 input aspect commands. This is intended for control systems that know the source aspect but may set the aspect before the source changes modes.
Update time ~3 minutes @57k from previous firmware.
Download Link
post #42 of 332 Old 05-18-2014, 12:55 AM
Gordon Fraser's Avatar
Quoted: 168 Post(s)
Liked: 180
Great job in the fan control...on low it's inaudible now....perfect!
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #43 of 332 Old 05-19-2014, 01:00 PM
gulliBELL's Avatar
Quoted: 86 Post(s)
Originally Posted by sjschaff View Post
Thanks for the info. Guess I'll stick with my XS till more of the dust settles -- end to end with source suppliers out to projectors.
That's what I decided to do, the trade-up pricing offer doesn't even close to tempt me to switch.
"My interest in home theater is not only that it annoys the wife, but if it was, then that would be enough"
gulliBELL is offline
post #44 of 332 Old 05-19-2014, 01:04 PM
gulliBELL's Avatar
Quoted: 86 Post(s)
Yes.
post #45 of 332 Old 05-20-2014, 06:39 PM - Thread Starter
Liked: 2136
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 051014 Firmware Update
Release Notes
Corrects configuration CMS update problem in 050814.
Download Link
post #46 of 332 Old 05-21-2014, 01:55 PM - Thread Starter
Liked: 2136
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 051114 Firmware Update
Release Notes
Small fix to allow the rs232 command for the "Alt" key to work with delimiters on.
Another small fix to the config updating code.
Download Link
post #47 of 332 Old 05-21-2014, 08:59 PM
Franin's Avatar
Quoted: 2401 Post(s)
Liked: 1508
Release Notes
Download Link
_________________________
Franin is online now
post #48 of 332 Old 05-21-2014, 11:30 PM - Thread Starter
Liked: 2136
Release Notes
Download Link
Hello Franin, it's better idea to report this at Lumagen's forum, to include that fix you want to the next 20xx firmware update. smile.gif
post #49 of 332 Old 05-21-2014, 11:41 PM
Franin's Avatar
Liked: 1508
gulliBELL likes this.
post #50 of 332 Old 05-21-2014, 11:43 PM - Thread Starter
Liked: 2136
post #51 of 332 Old 05-21-2014, 11:44 PM
Franin's Avatar
Liked: 1508
I agree 1000%
post #52 of 332 Old 05-22-2014, 12:21 AM - Thread Starter
Liked: 2136
Owner's Manual for Radiance 2144/2124 Video Processors is now available for download here.
post #53 of 332 Old 05-28-2014, 01:56 PM - Thread Starter
Liked: 2136
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 052314 Firmware Update
Release Notes
Adds "Off" to the fan control settings for 2123, 2143 for use in well vented areas demanding quietest operation.
Couple of bugfixes for problem getting a picture on some sources when going to standby and turning back on.
Another configuration compatibility correction.
Download Link
post #54 of 332 Old 06-14-2014, 07:03 AM
uderman's Avatar
Quoted: 108 Post(s)
Liked: 51
How does it deal with noise reduction? How are the controls? Does it have one control i.e low, mid, high for noise reduction? Or have individual selection for temporal, spatial, mosquito, bar?
uderman is offline
post #55 of 332 Old 06-15-2014, 01:53 AM
Quoted: 168 Post(s)
Liked: 180
The manual is available to download from their site.
It has spacial/temporal reduction, block noise and mosquito noise reducitons..sections. All with scale from 0 to 30 i think...
Convergent-AV
post #56 of 332 Old 06-24-2014, 02:12 AM - Thread Starter
Liked: 2136
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 061014 Firmware Update
Release Notes
Fixes up a few bugs in some of the test patterns in the previous release. (Update time ~3 minutes @57k)
Download Link
post #57 of 332 Old 07-12-2014, 12:23 PM - Thread Starter
Liked: 2136
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070214 Firmware Update
Release Notes
Adds 4k@60Hz, 4k@50Hz, 1080p@120Hz output modes (2143/2144 only).
Adds capability (for 2143/2144) to Auto output selection to select 4K output modes when appropriate based on the displays 4K EDID information---works with 4K Sony projectors.
A couple of APL test pattern fixups.
Speeds up test patterns.
Fix for sometimes incorrectly disabling a video output when changing between sources.
Slight improvement to 4k scaling.
Fixup for 2144 analog video input 9 not working after factory reset.
Bugfix for issue that can blank output video to an output when switching memories in some cases. (Update time ~15 minutes @57k)
Download Link
post #58 of 332 Old 07-14-2014, 01:49 AM
JanJankovsky's Avatar
could you tell me what the difference btw 2141 and new 2143?
JanJankovsky is offline
post #59 of 332 Old 07-14-2014, 02:51 AM - Thread Starter
Liked: 2136
Hi, there is a typing error to your question, Lumagen Radiance 2141 doesn't exist as a model.
post #60 of 332 Old 07-14-2014, 09:09 AM
Quoted: 168 Post(s)
Liked: 180
If the question is difference between 2041 and 2143...the answer is
2143 has 4 more HDMI inputs
2143 can output 4K at 24/25/30/50/60Hz while 2041 is limited to 4K at 24/25/30
2143 will soon have 17x17x17 LUT capabaility while 2041 is only 9x9x9
2041 has co-axial digital audio output and 2143 does not.
Convergent-AV
Reply Video Processors
