Lumagen New Radiance 21xx Video Processors - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #61 of 331 Old 07-14-2014, 05:26 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1672 Post(s)
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070314 Firmware Update
Release Notes
Fix for issue with rs232 test pattern usage that would often give a corrupted picture. (Update time ~3 minutes @57k)
Download Link
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #62 of 331 Old 07-16-2014, 11:24 PM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070514 Firmware Update
Release Notes
One more fix for an issue with rs232 test pattern usage via calibration software. (Update time ~3 minutes @57k)
Download Link
post #63 of 331 Old 07-18-2014, 10:00 AM
JanJankovsky's Avatar
Does 2143 support many color profile for the same HDMI input? I would like have many calibration presets for one source: for different light conditions.
JanJankovsky is offline
post #64 of 331 Old 07-18-2014, 10:03 AM
ScottJ's Avatar
Quoted: 318 Post(s)
Liked: 162
You can do this using any of the Radiance models by using the memories. Press MemA for dark room, MemB for bright room, etc.
It will take a little work to set up but once configured it's a single button press to switch among them.
ScottJ is offline
post #65 of 331 Old 07-18-2014, 10:43 AM
thanks
Going to order (Canada) Will test with Sony VW600
post #66 of 331 Old 07-18-2014, 11:41 PM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070714 Firmware Update
Release Notes
Found 2 other issues with rs232 test pattern usage via calibration software. (Update time ~3 minutes @57k)
Download Link
post #67 of 331 Old 07-21-2014, 11:43 PM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 070814 Firmware Update
Release Notes
A fix for exiting test patterns when using vertical shift (bottom of screen left uncleared). (Update time ~3 minutes @57k)
Download Link
post #68 of 331 Old 07-31-2014, 10:55 PM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 072014 Firmware Update
Release Notes
Small horizontal and vertical chroma improvements.
Added a CUE (chroma upsample error) setting under Input: Video Setup: RES: Picture.
Fixed an issue to handle 720p50 framepacked 3D source.
Fixed an issue that sometimes caused problems updating at 57k baud (so after this update is made subsequent updates should run smoothly at 57k). Preferable to perform this update at 28k to avoid problems. (Update time ~15 minutes @57k)
Download Link
post #69 of 331 Old 08-03-2014, 04:45 AM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 072114 Firmware Update
Release Notes
Fixed an issue that sometimes caused problems updating at 57k baud (so after this update is made subsequent updates should run smoothly at 57k). Preferable to perform this update at 28k to avoid problems. (note: bug occurred in 072014 and this update replaces it) (Update time ~15 minutes @57k)
Download Link
post #70 of 331 Old 08-08-2014, 02:31 PM
JonStatt's Avatar
Quoted: 52 Post(s)
Liked: 49
Has anyone calibrated a 2124 with Calman using 072114 firmware, and 5.3.5 Calman?
The autocal for the 9x9x9 LUT refuses to work with Calman showing the following dialogue when trying to run it...."The operation is not supported for the device" and if you press okay, simply nothing happens at all...
JonStatt is offline
post #71 of 331 Old 08-13-2014, 02:08 AM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 072214 Firmware Update
Release Notes
Improved the CUE filter menu, filter did not immediately turn on when enabled. (Update time ~3 minutes @57k)
Download Link
post #72 of 331 Old 08-13-2014, 05:18 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
Originally Posted by dsinger View Post
I can understand the desire to have UHD inputs on a video processor if you own a UHD display, but given the complexities of designing an end-to-end UHD video processor, the almost complete lack of native consumer UHD material and the lack of a UHD standard, I don't see why Lumagen would want to release a fully-UHD processor right now.
Informed speculation is that Lumagen will have a true 4k in and out vp by year end. Reason , at least in my case, is because customers want it. My Radiance XD will be 7 in August.
Happy birthday to your Lumagen.
dsinger likes this.
mark haflich is offline
post #73 of 331 Old 08-25-2014, 11:37 PM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 080114 Firmware Update
Release Notes
Fix for a configuration saving issue that didn't allow the "undo save" to work properly.
Also, another fix for working with the configuration utility.
Note the configuration utility was also just updated to version 1.8. as the earlier version was not downloading the CMS portion of the configuration to save on a PC for 21XX units. If you backed up your 21xx configuration earlier you should back it up again after performing this update and downloading the new 1.8 version of the configuration utility.
There were some improvements to the config utility as well. (Update time ~3 minutes @57k)
Download Link
post #74 of 331 Old 08-27-2014, 06:46 PM
jrp
jrp's Avatar
Quoted: 230 Post(s)
Liked: 476
We are a day or two away from releasing the 17x17x17 3D LUT for the 21XX series. Note this is only for the 21XX series. The 20XX units remain at 9x9x9, and the other Radiance units at 5x5x5.
Spectracal and Chromapure now have a 21XX unit for testing, and we will have a unit in the U.K. for Light Illusion next week. None have the Radiance 17x17x17 release yet, but we will be posting it in the next two days or so.
Based on my communications with all three companies it sounds like all will make it a priority to get their programs updated for the larger Radiance cube size pretty quickly especially since the commands are essentially the same as the 9x9x9 cube (with a couple minor additions).
Jim Peterson
Lumagen
jrp is offline
post #75 of 331 Old 08-29-2014, 11:03 AM
Gordon Fraser's Avatar
Quoted: 166 Post(s)
Liked: 180
17x17x17 LUT update now posted
http://www.lumagen.com/testindex.php...ce21XX_updates
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #76 of 331 Old 08-29-2014, 11:50 AM - Thread Starter
Liked: 2082
Originally Posted by Gordon Fraser View Post
Lucky 21xx users will now have only to wait for the software release to support this cube size
post #77 of 331 Old 09-03-2014, 02:43 PM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 081814 Firmware Update
Release Notes
Location values for 17x17x17 gamut adjustment via the menu were off by 1 for a few locations due to a rounding error. (Update time ~3 minutes @57k)
Download Link
post #78 of 331 Old 09-07-2014, 07:05 PM
uderman's Avatar
Quoted: 108 Post(s)
Liked: 51
any news on the 4k in / 4k out super processor?
uderman is offline
post #79 of 331 Old 09-07-2014, 09:02 PM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
I been waiting for this for a couple of years now, but I understand the wait. I always planned on buying one before I get a 4k projector. What would be perfect if they release a mini version that's cheaper of course. Anyway, I can't wait to get one within the next 12 months. Just hope it's not too much more than the 21xx series.
blee0120 is online now
post #80 of 331 Old 09-07-2014, 09:53 PM
jrp
jrp's Avatar
Quoted: 230 Post(s)
Liked: 476
Nothing new to discuss publicly at this time. We hope to have some news toward the end of the year.
RickAVManiac likes this.
Jim Peterson
Lumagen
jrp is offline
post #81 of 331 Old 09-08-2014, 01:49 PM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 082014 Firmware Update
Release Notes
Bugfix for configuring analog composite inputs (2143, 2144 only). The menu would show settings being made for these inputs without corresponding changes to the picture. (Update time ~3 minutes @57k)
Download Link
post #82 of 331 Old 09-09-2014, 02:25 PM - Thread Starter
Liked: 2082
CalMAN 5.4.0 build 1632 Open Beta Released @ 09 September 2014
Release Notes
This is an early open beta of CalMAN 5.4.0 which contains support for the new Lumagen 21xx series and the 17x cube sizes.
In adding this support, we needed to make some changes which could potential affect the older Radiance models. We have not seen evidence of that in our internal testing, but please let us know if anything pops up.
Download Link
post #83 of 331 Old 09-13-2014, 02:14 AM - Thread Starter
Liked: 2082
LightSpace CMS 6.6.3.1972 (12 September 2014) Closed Beta
Light Illussion has released a Closed Beta Version of LightSpace CMS that supports the Lumagen 21xx uploading of 17-Point Cube 3D LUT Tables.
Because I don't have a Lumagen 21xx here to test it, If any LightSpace user with Lumagen 21xx need to test it, I can provide him the download link via a simple PM.
post #84 of 331 Old 09-20-2014, 02:09 AM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 091014 Firmware Update
Release Notes
Fix for a bug which under some circumstance could give strange colors in grayscale intermittently. (Update time ~15 minutes @57k)
Download Link
post #85 of 331 Old 09-22-2014, 11:31 PM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 091114 Firmware Update
Release Notes
Fix for an issue that changes a 17x17x17 CMS to an 8 point CMS when copying from a CMS location to another. (Update time ~3 minutes @57k)
Download Link
post #86 of 331 Old 09-23-2014, 10:13 PM
911turbojk's Avatar
LUMAGEN 2143 + DATASAT RS20i I/O question
Guys,,
I about to install the LUMAGEN 2143 + DATASTA RS20i for my system , just checking in to see how everyone routes their HDMI ?
I assume all the source are routed to the 2143 , then 2143 -> Projector Input ,
However what happens to the SOUND? Do we pass it through back to the RS20i Via output 2 ?
oR A) Sources -> RS20i -> Lumagen 2143 -> Projector
B) Sources -> Lumagen 2143 -> Projetor
(but what do we do with the HD Audio)
What is the best route ?
HELP ~~~~~
911turbojk is offline
post #87 of 331 Old 09-24-2014, 01:16 AM
Quoted: 166 Post(s)
Liked: 180
Guys,,
HELP ~~~~~
Well with devices like that i'd have hoped your dealer would be able to sort it out for you. My own experience installing datasat and lumagen with a Sony vw1100 is that if you want consistent working audio and video you should send the sources to the scaler then one output from scaler to display and second output to rs20 carrying just audio.
Convergent-AV
post #88 of 331 Old 09-30-2014, 03:04 PM - Thread Starter
Liked: 2082
CalMAN 5.4.0 build 1752 Open Beta Released @ 01 October 2014
Release Notes
The only real change is the new Radiance 21xx series should work at the higher baud rate across the USB port.
Note - There's currently an issue that is you connect to the Radiance as a Source after you connected to it as a display, it may not use full speed.
We're still looking at the performance issues some of you have reported.
Download Link
post #89 of 331 Old 10-09-2014, 03:31 PM - Thread Starter
Liked: 2082
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 100514 Firmware Update
Release Notes
Fix for not correctly handling Pal (576i) video on analog inputs and not being able to power up on an analog input. This update is only helpful for units with analog inputs (2124/2144). (Update time ~3 minutes @57k)
Download Link
post #90 of 331 Old 10-22-2014, 12:37 PM
uderman's Avatar
Quoted: 108 Post(s)
Liked: 51
Is it gf9450 or gf9452 version for the vxp chip used in later radiance products?
I watch a lot of sd content. How does radiance compare to dvdo abt deinterlacing?
uderman is offline
Reply Video Processors
