HDMI splitter for 3D and 7.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 04-19-2014, 07:30 PM - Thread Starter
sabre170's Avatar
I have seen many discussions on this forum that are similar to the question I have here, but none could be found that really addressed what I'm trying to do.
So, here is my setup:
Bluray player-PS3
Receiver- Onkyo tx-sr706
TV- Samsung 7100 Series
Facts: PS3 is 3D BD compatible. Receiver is NOT 3D compatible. TV is 3D compatible. Receiver is compatible with Dolby TrueHD and DTS-HD Master Audio.
I want to be able to watch a 3D movie that is equipped with 7.1 on my TV and sound system. However, some obvious hurdles face me: In order to get the 7.1 audio from the PS3, I MUST use the HDMI (since the optical out only does 5.1 max). However, the second that I connect my PS3 to my receiver via HDMI, I now loose 3D capabilities due to that lack of passthrough compatibility.
What I'm curious if it will work. Get a1 to 2 HDMI splitter. Input=PS3. Output1=Receiver. Output2=TV. This would allow the TV to still get the 3D signal, and the Receiver to still get the 7.1 signal.....in theory.
I'm looking at these 3 different splitters that all claim to be 3D and 7.1 compatible.
http://www.monoprice.com/Product?c_id=101&cp_id=10113&cs_id=1011306&p_id=7522&seq=1&format=2
http://www.monoprice.com/Product?c_id=101&cp_id=10113&cs_id=1011306&p_id=8204&seq=1&format=2
http://www.rocketfishproducts.com/products/home-theater/RF-G1182.html
Can anyone confirm or deny if one of these will accomplish what I'm trying to do here.
sabre170 is offline
post #2 of 19 Old 04-21-2014, 01:35 PM
rfpublic's Avatar
Quoted: 16 Post(s)
You can use a Radiance video processor. The normal configuration is to connect Radiance HDMI Output 1 to your AVR and HDMI Output 2 to your display. You can turn off video on Radiance HDMI Output 1 in which case the Radiance will always send blank 1080i 2D video with audio to your AVR. At the same time you can view 2D or 3D video on your display.
You can connect a 1x2 Monoprice splitter to Radiance HDMI Output 2, to drive your two displays.
See "Tech Tip 17 - Using a 2D AVR in a 3D Video System".
http://www.lumagen.com/testindex.php?module=manuals
Any Radiance video processor except the XD or Mini will do what your want. The XD has two outputs but only supports 5.1 audio. The Mini only has one output.
Best regards,
Randy Freeman
support@lumagen.com
rfpublic is offline
post #3 of 19 Old 04-21-2014, 02:23 PM - Thread Starter
sabre170's Avatar
Woah! That is one expensive gadget. Well over $1k. You are right, that would do what I want, however, at that price, I'd just get a new receiver.
I was drawn to the monoprice splitter due to the low cost.
sabre170 is offline
post #4 of 19 Old 04-21-2014, 02:48 PM
rfpublic's Avatar
Quoted: 16 Post(s)
There are many other advantages to add a video processor to your system, such as much better calibration tools and improved video quality. But it is much more expensive than a Monoprice HDMI splitter.
You could also consider purchasing a new more modern 3D capable receiver. Some of the latest receivers have lots of nice internet and video streaming capabilities.
Randy Freeman
rfpublic is offline
post #5 of 19 Old 04-28-2014, 10:16 AM
Rolls-Royce's Avatar
Quoted: 148 Post(s)
Liked: 134
Understand that the splitter will NOT demux the audio. What it will do is split the 1.4 signal and try to send it to both the receiver and display. Unfortunately, it's still 1.4 to the receiver, which will not be able to extract audio, since audio is in different portions of the datastream in 1.3 (regular Blu-ray, cable, etc) and 1.4 3D signals. OTOH, the Lumagen will extract the audio and send it to the receiver in a 1.3 format, as Randy mentioned. So you'll have that as well as the superb video processing, grayscale and CMS adjustments it offers.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #6 of 19 Old 04-28-2014, 10:21 AM - Thread Starter
sabre170's Avatar
Gotcha. Thanks for clarifying it.
Give my current budget, it looks like my best solution is to do the PS3 optical out for audio on 3d BD....I guess the little bit of audio quality lost will have to be an acceptable loss....for now.
sabre170 is offline
post #7 of 19 Old 04-28-2014, 07:43 PM
Quoted: 148 Post(s)
Liked: 134
You do have another less expensive alternative for 3D Blu-Ray playback: one of the two-HDMI-output players from Panasonic or Sony. They are made with your situation in mind in that one output can be configured to output 1.3 7-channel audio while the other outputs the 1.4 3D signal.
...Royce...
post #8 of 19 Old 04-29-2014, 06:12 AM - Thread Starter
sabre170's Avatar
True. Any recomendations as to what model Panasonic or Sony to get......budget again is key.
sabre170 is offline
post #9 of 19 Old 04-29-2014, 12:40 PM
Quoted: 148 Post(s)
Liked: 134
I have the Panasonic DMP-BDT500, as I happen to be a fan of their players. Don't really know much about the Sonys, except that they do make a 2-output model.
One thing to keep in mind with the two-output players, is that if you have an HDMI cable between the receiver and display, you'll need to disconnect it when playing 3D Blu-Rays. Otherwise, since the receiver passes along the display's 3D-capable EDID, the player will "see" an HDMI 1.4 display on each output and not do the audio extraction and reconfiguration to 1.3 spec that you bought it for...
...Royce...
post #10 of 19 Old 04-29-2014, 07:49 PM - Thread Starter
sabre170's Avatar
Great info! Thanks again!
sabre170 is offline
post #11 of 19 Old 07-25-2014, 10:58 PM
theslydog's Avatar
Did you succeed with this?
You could try a cheap $10 HDMI splitter from ebay as that is not really a lot if it does not work.
http://www.ebay.com/itm/1-in-2-out-H...item461c6707df
theslydog is offline
post #12 of 19 Old 07-29-2014, 07:30 AM - Thread Starter
sabre170's Avatar
No, I never did have success, but I never did try any of the cheap ones. Everything I gathered from this forum and others is that any of those cheaper switches will default to the "lower" of the two items connected. So, if one output was connected to 3D TV, but other was to non 3D audio receiver, the system as a whole will default to the lesser of the two....the non-3D. To get the desired effect I was looking for was going to cost quite a bit to get that type of switch.....more than just buying a new receiver.
My current solution: Since I don't have or watch many 3D blu-rays (yet), My PS3 is connected to my receiver as it always has been and sends the normal 2D HD signal AND HD audio with no problem over HDMI. When I want to watch a 3D movie, I connect my TV directly to my PS3. I then connect an optical autio out to my PS3 and connect to my receiver. Although I don't get HD audio, I still do get pretty damn good audio. Seeing that I don't watch many 3D movies, this cable swapping method was a very cheap and workable solution for me.
sabre170 is offline
post #13 of 19 Old 08-01-2014, 08:38 PM
theslydog's Avatar
Personally, I would give the $10 splitter a go because it is a powered unit and sends the signal independently to both ports. It should not be a bother to you as you only want one side to do audio.
I have one on order for a different reason - for a HDCP problem but I will give it a go as per your setup as I have a PS3. My amp is 3D compliant but I will just use it to see if can I get the DTS-HD MA out ok through the splitter while the other side goes to the TV.
Should have it next week so will let you know if it works.
post #14 of 19 Old 08-08-2014, 05:23 PM
Quaddy's Avatar
you want the nsplitter pro mkII - which forces the EDID to match the highest common deonominator, so that the lesser equipped unit in the chain can still operate
thats exactly what i bought to use with my 3d PJ and 7.1 AVR to co-exist with my 2d stereo 2.0 tv - works a treat
i am in the uk, so ordering it from europe was quite quick, i think it was about £60, so maybe $100-110 in your money
HTH
Quaddy is offline
post #15 of 19 Old 12-04-2014, 06:20 PM
HDfury's Avatar
Quoted: 845 Post(s)
Liked: 232
HTH
Yes exactly, you can surely solve this issue with EDID tools.
This way you can always present the same EDID to your PS3 no matter the EDID of next device in your video chain. Or like explained above you can simply use a splitter that offer special edid tricks.
With a little study you can even do your very own EDID
HDCP Error? Blackscreen? No Audio? No Problem with HDfury!
4K Integral: Product Page - User Manual PDF - iOS APP - Android APP
4K Linker: Product Page - User Manual PDF - Scaling Modes
How do they compare? Integral vs Linker
18Gbps/600MHz HDMI cables that always work: here.
HDfury is online now
post #16 of 19 Old 12-07-2014, 01:41 PM
CZ Eddie's Avatar
Quoted: 54 Post(s)
Liked: 32
I have no idea if this helps you guys but this splitter advertises EDID with "passthrough audio, 2 or 5.1".
http://www.amazon.com/Panlong%C2%AE-...+hdmi+splitter
"The boom is dead, long live the bass"
CZ Eddie is offline
post #17 of 19 Old 12-08-2014, 04:17 PM
aerodynamics's Avatar
Quoted: 127 Post(s)
Liked: 47
Not to threadjack but I am in a similar situation except I don't need the 3D capabilities. I am simply looking for a way to output HDMI audio and video from my PS4 to my Vizio e600i and HDMI-equipped AVR. I thought any random HDMI splitter would accomplish this until I bought one and got constant signal drops. That's when I read about the tech behind HDMI and EDID issues, etc. I would rather not go PS4>AVR>TV because the receiver doesn't do passthrough and the video processing will introduce input lag. I have a DVDO Edge which does the trick but makes my setup way more complicated than it needs to be. Are there any other, more straightforward solutions?
aerodynamics is offline
post #18 of 19 Old 12-09-2014, 06:25 AM
wildchild22's Avatar
Quoted: 27 Post(s)
Yes use the splitter 4 from www.hdfury.com
hdmi into splitter
port 1 to tv
port 2 to avr.
It has full edid and you can even upload your own. I use a dvdo duo edid on mine as it supports all the major formats.
wildchild22 is offline
post #19 of 19 Old 12-09-2014, 07:27 PM
Quoted: 127 Post(s)
Liked: 47
Thanks! I'll look in to this.
hdmi into splitter
port 1 to tv
port 2 to avr.
Reply Video Processors
