Help!!! DVDO EDGE on the fritz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-18-2014, 10:50 AM - Thread Starter
BiggAW's Avatar
Quoted: 440 Post(s)
Liked: 108
Today, my DVDO EDGE started acting up. The picture will just intermittently just start turning on and off, sometimes around 1 or 2 hz, sometimes just once or twice and then work again. When it starts turning on and off and won't stop, I have to pull the plug and then it works fine, but not long thereafter (maybe 30-45 minutes) it starts going nuts again. Any ideas of what's going on? I'm pretty pissed if this thing is toast, as my entire home theater is wired around that one device. If it's broken, I pretty much have to rip the whole thing apart and rebuild it.
BiggAW is offline
post #2 of 10 Old 07-14-2014, 07:46 PM
sirhc55's Avatar
I had virtually the same problem and it turned out to be the power supply in the Edge. As I am in Australia and when checking for repairs it turned out to be in the $300Aus region. Far too expensive. I investigated the power supply and realised that it was available for around $60Aus. Purchased and installed within minutes - only four connections. Google DVDO Edge power supply and you will find an American supplier. Sorry but I have forgotten the actual model number for the power supply.
sirhc55 is offline
post #3 of 10 Old 07-14-2014, 07:48 PM - Thread Starter
BiggAW's Avatar
Quoted: 440 Post(s)
Liked: 108
Interesting. That's what I'm suspecting too. Mine is with DVDO for repair.
BiggAW is offline
post #4 of 10 Old 07-14-2014, 07:54 PM - Thread Starter
BiggAW's Avatar
Quoted: 440 Post(s)
Liked: 108
BiggAW is offline
post #5 of 10 Old 08-06-2014, 06:12 PM
sirhc55's Avatar
How did the repair work out BiggAW?
sirhc55 is offline
post #6 of 10 Old 08-12-2014, 09:38 PM - Thread Starter
BiggAW's Avatar
Quoted: 440 Post(s)
Liked: 108
I got it back and it works great! They never did tell me what is wrong with it though, which was rather odd. I suspect the power supply.
BiggAW is offline
post #7 of 10 Old 08-13-2014, 09:09 PM - Thread Starter
BiggAW's Avatar
Quoted: 440 Post(s)
Liked: 108
They said that they reloaded the firmware, and it tested fine. It works fine for me now. Go figure. Not sure how the firmware can just randomly crap out, but as long as it keeps working, I'm happy...
BiggAW is offline
post #8 of 10 Old 09-21-2014, 10:55 AM
HDgaming42's Avatar
Quoted: 154 Post(s)
Did they charge you for that? That's something you can do with a computer and a USB cable!
Mine just starting doing exactly this--blinking on and off randomly. I can't get it to lock by cycling inputs--I have to turn the power off and on again. Fixes the issue until it encounters a resolution change / HDCP handshake etc and then it's time to flip a coin as to whether it will lock or not. This is with any combination of 1:1 framerate, framelock etc.
I have an original beta-test EDGE unit. Is what I'm seeing consistent with people's experiences with the PSU failing?
HDgaming42 is offline
post #9 of 10 Old 09-21-2014, 11:36 AM - Thread Starter
BiggAW's Avatar
Quoted: 440 Post(s)
Liked: 108
No. I had to pay for shipping it out there though, that was like $20 or something. And wait something like a month for it back. There was no reason to suspect that it was a software problem in the first place. These things are pretty flaky- I doubt I'll ever buy another dedicated video processor, partly because of the reliability problem. Next time around I'll buy a higher end AVR and discreet speakers, and the higher end AVRs have some level of processing and scaling built in, including to 4K now...
BiggAW is offline
post #10 of 10 Old 09-22-2015, 11:46 AM
flyingvee's Avatar
too many people must have gone that way - I tried - all I got were people complaining about their Edge, and DVDO support.
I did find a guy in England who had a dealer over there. Doe anyone have a US source handy? thanks
Jon
Denon DVP - everyone else loves it.
flyingvee is offline
Reply Video Processors
