I haven't seen any review of it on the web, does anyone @ AVS have one? How is it compare to Darbee Darblet?
Have you tried swapping the HDMI cables? Also, presumably the ancient firmware date is simply a bug in the file properties?I own a lot of Dvdo gear I have had nothing but problems with this product
way too many communication problems leaving "no signal" floating around
on the screen I have tried multiple TV's and commercial displays with this unit
and it has the same problems on every one.
the firmware is from 2008.
Thanks to all on this thread that have been helping us troubleshoot any initial launch issues. Seriously, products are always better with intense review.
New firmware - in the process of posting on our website but thought those on this thread would want it early.
http://www.personalizedstitches.com/iScan_Mini_FW_01.02.zip
(Sorry for strange website - its my wife's and only place I have to stash stuff like this - it will be on DVDO website in next couple days as well)
* Adds option to enable de-interlacer specifically for 1080i input (enables 1080i in EDID as well)
* Adds support for 50Hz inputs
* OSD now supported at SD resolutions
* Fixed bug: Video loss when switching back and forth between SD and HD
* Fixed bug: Improper EDID creation - symptom, no video when used with some video processors
* Fixed bug: Improper resolution and color space reporting on info screen
* Fixed bug: General instability issues
As always, we actively seek input and bug reports to improve products.
