DVDO iscan vp30 issue.... retro gaming RGBs - AVS | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Fudoh
post #1 of 10 Old 12-03-2014, 07:46 AM - Thread Starter
Liked: 0
So I have a vp30 with the abt102. The issue is that I have the following cables:
Sega Saturn stereo csync RGB SCART cable for NTSC model Saturn lead cord
Sega Genesis 1 Megadrive 1 stereo RGB SCART with boosted sync TV lead
AND
So the question is how can I hook these up? I wanted to run my SNES through here as well as the genesis and sega saturn I have. I mistakenly tried the RGBHV ports in the back with the cable included and that showed nothing due to the fact I believe it only takes 480p and up.
Will it fix this if I purchase bnc->rca adapters and run the cable into the component/RGBs input as well as the sync input. Here is a picture of the rear IO of the vp30:
I know its possible because I talk to a guy on youtube that has his NES and SNES hooked up to the vp30. Please help me figure this out so I can use my RGB/scart cables.
Thank you
xthetrainx is offline
post #2 of 10 Old 12-03-2014, 02:33 PM
Fudoh's Avatar
Quoted: 12 Post(s)
Liked: 24
yes, that's the way to do it.
xthetrainx likes this.
Fudoh is offline
post #3 of 10 Old 12-03-2014, 05:59 PM - Thread Starter
Liked: 0
Thanks a lot bro
post #4 of 10 Old 12-06-2014, 04:47 PM - Thread Starter
Liked: 0
Originally Posted by xthetrainx View Post
Thanks a lot bro
So I got a fantastic picture from the vp30 using the saturn. I cannot get my genesis model 1 to display a picture.. its just a black screen... I'm using the following cables:
The vp 30 is equipped with the abt102 and the scart cable for the genesis says it has boosted sync. Not sure if any of this causes any issue but please let me know.. The saturn has worked great so far with a few games I test
post #5 of 10 Old 12-06-2014, 04:47 PM - Thread Starter
Liked: 0
post #6 of 10 Old 12-06-2014, 04:47 PM - Thread Starter
Liked: 0
I tried to send you a private message but it didn't let me
post #7 of 10 Old 12-06-2014, 04:52 PM - Thread Starter
Liked: 0
aa
post #8 of 10 Old 12-06-2014, 04:52 PM - Thread Starter
Liked: 0
bb
post #9 of 10 Old 12-06-2014, 05:28 PM - Thread Starter
Liked: 0
I'm thinking about trying this one instead for the same reason
http://www.retrogamingcables.com/seg...e-tv-lead.html
post #10 of 10 Old Today, 10:48 AM
Liked: 0
Did you solve your issue?
I am having the same issue with my vp30+102 and Genesis model 1 rgb scart lead - black screen.
My Saturn displays fine.
I was using a crt previously, converting the rgb signal to component via a cyp converter - everything worked fine!
Pdiggitydogg is online now
Reply Video Processors
