DVDO Introduces iScan Micro UHD/4K Upscaler/Enhancer - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #31 of 64 Old 05-03-2015, 06:20 PM
David Susilo's Avatar
Quoted: 636 Post(s)
Liked: 592
Just compare native 4K vs your Vizio upscaling BD to 4K vs Sony 900 upscaling BD to 4K. You WILL see that the Sony's upscaler is far superior than the Vizio as the Sony upscaler yields the closest upscaled picture compared to the native 4K.
tgm1024 likes this.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #32 of 64 Old 05-04-2015, 06:00 AM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
Apologize for the off track post, but how does the Oppo 103D upscaling compare?
hernanu is online now
post #33 of 64 Old 05-04-2015, 08:15 PM
krichter1's Avatar
Quoted: 2048 Post(s)
Liked: 2293
David - I would imagine this would also hold true for a JVC "Faux4K" setup w/ Darblet (being superior to this device in the JVC mix)?
Kevin
You only live once, but if you live it right, once is enough.
==> Our 4K/3D Immersive Theater
krichter1 is offline
post #34 of 64 Old 05-04-2015, 08:19 PM
Quoted: 636 Post(s)
Liked: 592
The Oppo 103D upscaling is better than the iScan Micro. Also tested it against JVC X700 and the projector wins hands down.
my home theatre
post #35 of 64 Old 05-05-2015, 04:47 AM
hernanu's Avatar
Quoted: 682 Post(s)
Liked: 1218
Thanks David. The projector makes sense.
post #36 of 64 Old 05-05-2015, 04:08 PM
Glimmie's Avatar
Quoted: 762 Post(s)
Liked: 637
Yet another Marseille chip somebody put in a little box?
Glimmie is offline
post #37 of 64 Old 05-06-2015, 06:58 AM
tgm1024's Avatar
Location: Sorry, chances are excellent that you're an idiot.
Quoted: 2484 Post(s)
Liked: 2264
Oh goody. One. More. Remote.
Just can't get enough of those.
You're the wife. You're the dead wife. Give me my @#$%ing coin, dead wife.
-Mad Sweeney
tgm1024 is offline
post #38 of 64 Old 05-06-2015, 05:31 PM
Quoted: 349 Post(s)
Liked: 59
I am curious, the TV I have now is the Sony Xbr65850b which has a good upscaler, is this using the same technology or should I return this TV and get that version instead? The upscaling technology on this tv works better than Nvidias DSR, which I'm super happy with. I'd be willing to shell out more for even more of an upgrade.
Chase Payne is offline
post #39 of 64 Old 05-06-2015, 05:59 PM
Quoted: 636 Post(s)
Liked: 592
The only difference between the 850 vs the 900 series is the upscaling from 720p, even that is minimal. It's not worth upgrading from 850B to the 900.
PS: the 850B is a better upscaler than the Micro.
my home theatre
post #40 of 64 Old 07-28-2015, 02:32 PM
Mamasboy's Avatar
The iScan does not use a Marseille chip. Marseille is coming out with the Technicolor certified mCable at the end of August that will improve on upscaling of most all 4k TVs out there.
The mCable should not to be confused with the Seiki cable which Marseille specifically made and tuned for the Seiki 4k TVs with notoriously bad internal upscaling.
I feel infinite
Mamasboy is offline
post #41 of 64 Old 07-29-2015, 08:14 AM
tgm1024's Avatar
Liked: 2264
Agreed. Sony has always been phenomenal at upscaling. Even SD/ED->FHD is impressive. I can't wait to see the 940c in person.
-Mad Sweeney
tgm1024 is offline
post #42 of 64 Old 08-04-2015, 04:46 PM
J.Mike Ferrara's Avatar
Quoted: 153 Post(s)
Liked: 179
David, I sure appreciate your informed posts. Here is my situation. I have a LG 9300 OLED panel. Terrific picture when calibrated, but as typical with LG, the video processing leaves a lot to be desired (this is my 2nd LG panel). I use the OLED panel to watch FIOS, and output the Motorola box at 1080i. Even with the True Motion blur setting set to max, I still see jerky panning on most channels. I don't watch 1080p24 - that's for the big theater downstairs.
I noticed your comment on LG having less than stellar video processing. Since I don't need upscaling, I'm wondering if the Mini does a better job with 1080i de-interlacing than the LG. If so, I want one. Thx.
J.Mike
Those who die with the most toys ... are still dead!
J.Mike Ferrara is offline
post #43 of 64 Old 08-13-2015, 06:21 PM
mishari84's Avatar
Quoted: 120 Post(s)
Liked: 25
How can I get a video processor as good as Sony without paying premium? I have LG TV, I dont want to change it now
mishari84 is offline
post #44 of 64 Old 08-17-2015, 04:52 AM
Mamasboy's Avatar
You will need to get a 3rd party upscaler. Cheaper than buying another 4k TV!
I feel infinite
Mamasboy is offline
post #45 of 64 Old 09-22-2015, 07:09 AM
dealer6871's Avatar
Quoted: 13 Post(s)
I've had the Darbee for two years and love it. One for blu ray on my Pioneer Kuro and the other tied to my time warner cable box and Panasonic GT50. Not going to touch my calibrated Pioneer, but would I get any benefit by adding a micro into the loop with my Darbee and Time Warner Box? Can pick up a micro for under $100.00. Thanks.
dealer6871 is offline
post #46 of 64 Old 09-22-2015, 08:13 AM
tgm1024's Avatar
Liked: 2264
My simple and cheap 2K BDP-S590 (Sony) upscales SD/ED->FHD beautifully. But then of course we're talking about blu-ray.
Perhaps a Sony 4K BDP will do similarly with FHD->4K?
lucacow likes this.
-Mad Sweeney
tgm1024 is offline
post #47 of 64 Old 09-22-2015, 07:54 PM
Liked: 0
I have a question, so I play a bluray on my ps4 it is sending a 1080p signal to my TV which up converts to 4k so what happens if I put this dvdo thing in between? Would it be OK to do that? Would it improve the pic or no? Thanks
Deech1983 is offline
post #48 of 64 Old 11-11-2015, 09:56 PM
Liked: 0
Does this do 1080p 60hz to 4K 60hz?
I'm looking at getting an external upscaler due to my cheap Tempo 4K tv introducing a 200-300ms lag with its internal upscaler. If I feed it a native 4K signal the lag goes away and the picture is pristine.
I just got a new AppleTV and it outputs 1080p/60hz, which I note that the Marseille mCable does not support. Anyone have any experiences with this one or another device capable of scaling 60hz?
Or is that just too much to ask with current technology?
Erik Veland is offline
post #49 of 64 Old 01-26-2016, 08:27 PM
blb1274's Avatar
How does the DVDO Micro compare to the upscaling on the Samsung JS8500? Specifically with streaming services?
blb1274 is offline
post #50 of 64 Old 01-29-2016, 01:05 PM
larrimore's Avatar
Quoted: 94 Post(s)
Liked: 41
How does this product differ from using a Darbee? It appears that the iScan may do some of the same things as the Darbee but not the other way around. I have the Darbee but would consider using this instead if I do not give up too much performance if I get other benefits. Can the two be used together in a complimentary fashion?
Living the HT Dream in 4D.
3D DLP Cinema 110"@9ft w/5.4.2 Atmos Sound and 6 Aura Bass Shakers
larrimore is offline
post #51 of 64 Old 01-30-2016, 08:34 AM
Mamasboy's Avatar
Anyone try the mCable for 1080P to 4K upscaling?
I feel infinite
Mamasboy is offline
post #52 of 64 Old 02-10-2016, 09:24 PM
Quoted: 636 Post(s)
Liked: 592
The deinterlacing between the two are indistinguishable.
my home theatre
post #53 of 64 Old 02-10-2016, 09:25 PM
Quoted: 636 Post(s)
Liked: 592
Mcable is literally just like Seiki upscaling cable. Better than nothing but I ain't paying $50 for either of them.
my home theatre
post #54 of 64 Old 03-03-2016, 08:04 AM
Mamasboy's Avatar
The Seiki cable was made specifically for the Seiki TVs that had serious issues with upscaling. The mcable is much new technology and made for all tvs. I saw an A-B demo using a dual output Oppo blu-ray player and 2 identical Samsung TVs at CES. The difference it made was quite noticeable.
I can't find any serious 3rd party reviews. Here is a blurb in sound and vision about it http://www.soundandvision.com/conten...s-been-looking
I feel infinite
Mamasboy is offline
post #55 of 64 Old 04-22-2016, 10:49 AM
PlatinumSV's Avatar
Quoted: 280 Post(s)
Liked: 171
Hello all, is there a trick to get this thing to Output 4K. I'm using it on my Cablevision cable box outputting to a Samsung un65js9500 and the input signal on my TV is still showing as 1080i regardless of where I put the edge enhancement. All this is doing is adding Edge enhancement. I've tried calling dvdo repetitively over the past 3 days and no one answers their phone
PlatinumSV is online now
post #56 of 64 Old 05-04-2016, 05:56 PM
bluswillz's Avatar
Quoted: 132 Post(s)
Liked: 36
Hello all, so what is the general consesus on this? Is it worth getting if I have a p75 vizio looking to improve pq from time warner?
bluswillz is offline
post #57 of 64 Old 05-09-2016, 06:27 AM
Mamasboy's Avatar
Most likely the DVDO can not upscale interlaced signals. If possible, set your cable box to output 720P instead of 1080i and let the DVDO upscale that resolution.
I feel infinite
Mamasboy is offline
post #58 of 64 Old 05-09-2016, 06:45 AM
dandiego's Avatar
Quoted: 59 Post(s)
Liked: 36
Someone over on the Vizio 2016 P Series Owners thread confirmed that the Micro will not upscale 1080i; it just passes it through (http://www.avsforum.com/forum/166-lc...l#post43890546).
bluswillz likes this.
dandiego is offline
post #59 of 64 Old 05-09-2016, 07:14 AM
dlbsyst's Avatar
Quoted: 161 Post(s)
Liked: 123
If it can't convert 1080i to 1080p the device is pretty worthless imo. That is exactly what many people will want it for, to convert and up convert poor quality cable and broadcast signals.
dlbsyst is offline
post #60 of 64 Old 05-09-2016, 07:29 AM
Mamasboy's Avatar
Even if it could upscale from 1080i to 1080p you wouldn't notice much difference. The biggest bang for the buck would be upscaling 720p or 1080p to 4k.
If your cable box can can switch output to 720P, give that a try. The DVDO should be able to upgrade that 720P to 1080P for you.
I feel infinite
Mamasboy is offline
Reply Video Processors
frontpage
