HDfury Integral... - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 541Likes
post #61 of 4546 Old 11-06-2015, 11:12 AM
CSPerera's Avatar
Quoted: 81 Post(s)
Liked: 40
Originally Posted by HDfury View Post
User manual of your TV states that max accepted res is 4K30 but since you have "upgraded to HDCP2.2" may be this have changed ? Do you know if it will take 4K60 4:2:0 through this input ?
And what kind of sound format do you want/need in your setup ?
Sony bought out a firmware update that supports the following: 4K 60p (3840X2160p (59.94/60Hz) YCbCr 4:2:0 8bit, 4096X2160p (59.94/60Hz) YCbCr 4:2:0 8bit) on all ports. However
as I stated HDMI 4 on the TV is the only one that has HDCP 2.2. Now my receiver I beleive will only passthrough a 4k30p signal. As far as sound goes I would like to use the receiver to play all the HD sound formats. I have a feeling that since my receiver only passes 4k30 then the downside is that I wont be able to use my TV to the maximum potential if I go through the receiver. Would that be the case? Or any suggestions that you would recommend?
shepdog likes this.
CSPerera is offline
post #62 of 4546 Old 11-06-2015, 11:45 AM
MultimediaGeek's Avatar
Quoted: 29 Post(s)
I have the Samsung uh9000 and the sony str-da5800es
My tv shows the input signal as 3840x2160 / 60p with the x10 media server
My tv shows the input signal as 4096x2160 / 60P with the sony DVD using 4k upscale
I can force the signals to be 30P and the tv shows that too.
So I believe that my str-da5800es is passing 4k60p signal at 8 bits (4:2:0)
I can't respond to using your TV at its maximum potential considering there is talk of 4K with 60P and 4:4:4
I am not sure what receiver you have.
MultimediaGeek is offline
post #63 of 4546 Old 11-06-2015, 11:48 AM
scarabaeus's Avatar
Quoted: 334 Post(s)
Liked: 331
Originally Posted by Manni01 View Post
You don't need anything to watch UHD Bluray in 1080p. This is what will happen if the display doesn't support HDCP 2.2. However, you will likely get rec799, 8bits 4:2:0, not P3, 10bits 4:4:4.
Also, if you are on a service like VUDU, the stream itself falls back to 1080p, and you'll lose other features like Atmos audio. It would be nice to be able to trick the Roku 4 into playing back the UHD streams at 1080p to get Atmos.
Not sure how that will be with UHD Blu-ray, if that allows to fall back to 1080p and keep Atmos, since e.g. Disney seems to bundle Atmos exclusively with UHD as well.
scarabaeus is offline
post #64 of 4546 Old 11-06-2015, 12:21 PM
Manni01's Avatar
Quoted: 3364 Post(s)
Liked: 3120
Don't know about streaming, but for UHD Bluray/Bluray they can't make any difference as you bitstream the Dolby TrueHD track anyway. It's the processor/AVR which is going to decode the stream, but I don't see why they would downgrade you to 5.1 from TrueHD. Bluray supports Atmos, so I would expect UHD Bluray downscaling to 1080p to give TrueHD (hence Atmos) as well. I guess we'll find out soon
Manni01 is offline
post #65 of 4546 Old 11-06-2015, 01:17 PM
scarabaeus's Avatar
Quoted: 334 Post(s)
Liked: 331
Yes, they could still decide to output only an error screen if your display is not UHD/HDCP2.2, but that would be a very bad move of the BDA.
BTW, does anone know if the UHD Blu-rays will come bundled with a HD Blu-ray, kind of like the bundled DVDs a lot of Blu-rays have now, to encourage people to buy the movies in UHD before they have a player?
post #66 of 4546 Old 11-06-2015, 02:43 PM
Manni01's Avatar
Liked: 3120
The leaked Sony document clearly indicates that the plan is to provide 1080p when HDCP 2.2 isn't detected with UHD Bluray, so hopefully they'll stick to that: http://www.pocket-lint.com/news/1343...blu-ray-player
I heard that they will bundle a bluray but no DVD with UHD Bluray titles. Of course I guess we'll see exceptions, but that's the plan as I understand it. It is certainly my plan to buy UHD Blurays from day one, whether I have a player yet or not. I have stopped buying blurays a while ago, I only buy those with an Atmos, DTS:X or Auro 3D track (which means very few), or those which I know are very unlikely to ever get a UHD Bluray release. All the others titles only get a rental for now.
Manni01 is offline
post #67 of 4546 Old 11-06-2015, 05:43 PM
HDfury's Avatar
Quoted: 1763 Post(s)
Liked: 348
Originally Posted by CSPerera View Post
Ok So My Sony TV is a KDL 55X900A (XBR 55X900A in United States). HDMI 4 on the TV has been upgraded to HDCP 2.2. However my receiver is a Pioneer Sclx 86 (Elite SC 68 in the US) and has 4k passthrough that supports of 4k24p, 4k25p & 4k30P. So can you please tell me how the integral can assist me in transferring a 4k signal (Say a 4k Bluray player or a Roku 4) via my receiver and then onto the TV.
This setup currently needs a choice, best video or best sound.
Best sound: SOURCE > INTEGRAL > PIONEER > SONY XBR
You will only get 4K30 4:4:4 in this setup since the Pioneer AVR is limited to 4K30 4:4:4 but FULL sound.
Best video: SOURCE > INTEGRAL > SONY XBR
Video will be at 4K60 4:2:0 (SONY XBR MAX) but only 5.1 sound output from integral to AVR
We might have a solution for you and others with 4K60 4:4:4/4:2:0 display and 4K30/1080p AVR in the future so you could get the best of both video and audio simultaneously in such setup with Integral. Do not take my words on it yet, work is currently being done for that but we cannot guarantee yet that it will succeed.
CSPerera likes this.
IMPORTANT: Due to recent discoveries, we are working on a new way to handle Dolby Vision, in the meantime please use AUTOMIX/SINK mode for DV support.
Do not use DV forced flags on Integral, it cannot work with all DV equipment, simply use automix with max video algo and you will be fine until we push new updates out.
HDfury is offline
post #68 of 4546 Old 11-07-2015, 02:27 PM
GGA
GGA's Avatar
Quoted: 249 Post(s)
Liked: 65
Can I do this?
Send HDCP UHD 2.2 Netflix from Samsung H6500 to Integer Input 1
Send HDCP 1.4 from Lumagen XS processor to Integer Input 2
Then:
Send HDCP 1.4 UHD or1080p from Integer Output 1 to JVC RS67 pj
Send HDCP 1.4 from Integer Output 2 to Datasat audio processor for Netflix DD+
Thank you.
GGA is offline
post #69 of 4546 Old 11-07-2015, 03:45 PM
HDfury's Avatar
Liked: 348
Originally Posted by GGA View Post
Can I do this?
Then:
Thank you.
Not sure if you want to do this in splitter mode or matrix mode but answer is the same:
As long as incoming resolution is supported by sink devices connected it will work.
With the exception that you can run Full 4K60 4:4:4 IN/OUT and have 4K60 4:2:0 OUT on secondary channel. (Splitter Mode Only, and Matrix Mode limited to 4K60 4:2:0 MAX)
HDfury is offline
post #70 of 4546 Old 11-08-2015, 05:22 PM
GGA
GGA's Avatar
Quoted: 249 Post(s)
Liked: 65
Thank you but I am not sure what Matrix mode does. I reread the manual and there is no explanation, just instructions on how to select it over changing inputs. Can you please provide some details?
GGA is offline
post #71 of 4546 Old 11-08-2015, 07:04 PM
HDfury's Avatar
Liked: 348
Matrix Mode is 2 active inputs pass through to 2 outputs. Can cross signals.
Splitter Mode is 1 active input replicated to 2 outputs. Can switch active inputs.
HDfury is offline
post #72 of 4546 Old 11-09-2015, 03:34 PM
GGA
GGA's Avatar
Quoted: 249 Post(s)
Liked: 65
Thank you. Now I need a definition for non-active input.
Obviously active means any movie that is being streamed or BRD being played.
Is a static Menu for say Netflix or a BRD considered non-active if you are not scrolling around? If a component is in standby is that considered non-active or does it have to be powered down to be non-active?
If both inputs are active how does the Integer choose which one to use?
The reason I am asking these questions is because I am going to have to switch between the two Integer inputs (matrix does not work for me) and am trying to understand if I can accomplish this switching non-manually or without using my iPad.
GGA is offline
post #73 of 4546 Old 11-09-2015, 04:59 PM
HDfury's Avatar
Liked: 348
As simple as it means, active input means a signal is going through. non-active means no signal (the source connected is off).
You can switch manually between active inputs with push button on unit, IR control, USB app or Android APP (iOS around Xmas hopefully)
Integral also have autoswitch option, if you turn off the current active source, it will switch to the other and if you turn one source on it could switch on it. [+] We have a new option in upcoming firmware called "input priority" which give further settings for source that still send signal even in standby mode.
HDfury is offline
post #74 of 4546 Old 11-09-2015, 07:41 PM - Thread Starter
Jon S's Avatar
Quoted: 925 Post(s)
Liked: 303
Looks like the 25% pre-sale discount has expired... Is that correct?
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #75 of 4546 Old 11-09-2015, 11:08 PM
HDfury's Avatar
Liked: 348
Unfortunately yes, currently one could get up to 3 times 5% discount by sharing links to social network from the checkout page.
The discount plug-in is not working well for all browsers or all conditions. If you are having issue, try to log on social network before trying the sharing buttons.
Android Total Control APP version 1.0.3 for 4K Integral is available on Google Play Market. You should get the update notification from google market automatically if you already have it installed.
New Firmware and new USB GUI for Windows will be available this week, more on that later.
HDfury is offline
post #76 of 4546 Old 11-10-2015, 02:18 PM
TimGoodwin's Avatar
Quoted: 34 Post(s)
Liked: 26
I'm having issues with the latest version. The android app won't recognize my Integral. Keeps giving me a Bluetooth error? The Bluetooth is on our my Samsung Note 4, so that's not the issue.
TimGoodwin is online now
post #77 of 4546 Old 11-10-2015, 03:44 PM
HDfury's Avatar
Liked: 348
Did you try the "clear previous connection" option in top right menu ? if not give it a try please.
If that doesn't help and if error is right after update, you should be able to get rid of it by uninstalling, reinstalling the APP.
If you have a 600MHz signal going through Integral, the BT range will be very short, if that's the case, make sure you are close to the Integral unit when you attempt to connect.
300MHz range is about 5m, 150MHz (1080p alike) is about 8m, no signal range is about 20m.
We are studying an add on hardware for people who want to keep long distance BT with 600MHz signal.
EDIT: no worry about BT settings, if it's OFF on your phone/tablet, APP will prompt to turn it ON at start.
Do not link phone/tablet to Integral using android BT menu. Otherwise APP will not be able to connect to Integral.
HDfury is offline
post #78 of 4546 Old 11-13-2015, 06:36 PM
TheFreeman's Avatar
SHIELD 4K60 444 > INTEGRAL > TOP OUTPUT TO VIERA WT600 @ 4K60 444
BOTTOM OUTPUT @4K60 420 TO DENON NR609 (HDMI1.4a 1080p MAX) IT WORKS PERFECTLY!
It gives FULL audio to AVR (no video on AVR, just FULL sound)
This AVR is using Marvell Qdeo, more 1080p AVR with Qdeo should work this way.
TheFreeman is offline
post #79 of 4546 Old 11-13-2015, 11:20 PM
Manni01's Avatar
Liked: 3120
@HDfury Any chance to get an option to switch the LEDs off? In a dedicated room, the blue LEDs light the room like a Christmas tree and kill on/off contrast, even hidden behind a desk. I've had to use black electrical tape, but it would be nicer to just switch all the LEDs off. Thanks!
Otherwise, it works fine but I haven't been able to test it with an HDCP 2.2 protected source yet.
Manni01 is offline
post #80 of 4546 Old 11-14-2015, 07:20 AM
HDfury's Avatar
Liked: 348
Hello Manni,
Sure, give it a few days and you will have an option to turn LOGO LIGHT ON/OFF from the GUI.
Btw, we just added ARC support and many others, we will post a list soon, work underway.
HDfury is offline
post #81 of 4546 Old 11-14-2015, 07:26 AM
Manni01's Avatar
Liked: 3120
Wow, that's great, thanks for the quick reply. It would be great if you could create a short document explaining what can be achieved with the HDR option. Is it to emulate an HDR display so the source sends the HDR content without converting to SDR? Thanks
Manni01 is offline
post #82 of 4546 Old 11-14-2015, 09:50 AM
HDfury's Avatar
Liked: 348
Integral can pass-thru HDR like any HDMI2.0a device should do. That's basic.
What it can do regarding HDR that no other device can do (except expensive equipment in lab):
It can activate HDR ON/OFF at will on any HDR display and it can switch between BT2020/709 at will (and others mode if available) of any capable display.
In the future, we will be happy if some partners/dev using our infoframe injector API/DLL could make some high end no-HDR display (and especially PJ) react to HDR signaling, keep in mind, the display must be a capable one, for custom infoframe injection of colorspace AVI infoframe or HDR metadata, display must be at least a wide color gamut capable to have visible change.
The day you get a HDR display, with your integral, you will be able to do more than just watching HDR movie/content like others can do in a HDR setup. You will be able to control HDR at your fingertips and control your display color space mode at will.
Watching movie, picture, internet, gaming, whatever. Just Press a button (on unit, via USB or with phone/tablet) > And you are in HDR mode! press an other and you switch colorspace!
PS: We have a dedicated page coming for this.
HDfury is offline
post #83 of 4546 Old 11-14-2015, 10:09 AM
Manni01's Avatar
Liked: 3120
Integral can pass-thru HDR like any HDMI2.0a device should do. That's very basic.
What it can do regarding HDR that no other device can do (except 4 or 5 digits priced equipment in lab):
It can activate HDR ON/OFF at will on any HDR display and it can switch between BT2020/709 at will (and others if supported by display) of any capable display.
In the future, we will be happy if we (or some partners/dev) can make some high end no-HDR display (and especially PJ) react to HDR signaling using our Infoframe injector, but keep in mind, the display must be capable, for custom infoframe injection of colorspace AVI infoframe or HDR metadata, display must be at least a wide color gamut capable to have visible change.
Sounds great!
I was wondering if it would help a non-HDR PJ like the JVC X500 (RS49) to display HDR content with a custom DCI/P3 gamut and BT2486 gamma curve, as otherwise the source would detect the PJ isn't HDR capable and would send rec-709 SRD instead of P3/HDR. Looks like the HD Fury might be able to achieve this.
I should get an X7000 (rs500) HDR/P3 capable device soon, but it would be really nice to be able to compare what one can get with each device.
Looking forward to the dedicated page on the website, please let us know when it's on.
Manni01 is offline
post #84 of 4546 Old 11-16-2015, 11:58 PM
ZippZopp's Avatar
Quoted: 91 Post(s)
Liked: 30
HDfury Integral...
I just got the integral today. I'm hooking up a gtx950 video card to the integral. I'm then outputting one hdmi cable to my 4K Samsung js9500 for video and another hdmi cable from the integral to my denon x4000 for audio. My avr isn't 4K so I need to split my audio and video.
Prior to hooking up the integral I had my PC output 3840x2160 @ 60 hz and it was outputting full range RGB. I hooked up the integral and now in the nvidia control panel it is set to YCbCr420 in limited range. If I slide the edid slider to 'automix mode' I got access to set it to rgb full range. However now for some reason I get a black screen when set to automix mode. The green Integral text doesn't light up at all now even when I set the edid slider back to 'custom use'. At least with it in custom use I get audio and video but something doesn't seem right here
ZippZopp is offline
post #85 of 4546 Old 11-17-2015, 10:23 AM
HDfury's Avatar
Liked: 348
Hello ZippZopp
I have read your thread here
So it seems you have blackscreen with PC > JS9500 even on a straight connection.
It does looks like a HDMI cable issue.
To make sure, please try the following:
PC output to Integral Bottom Input.
TOP Integral output to JS9500
Disconnect AVR for the moment.
EDID Slide on FIXED
This should give you a 1080p picture.
Then move EDID slide to Custom > this should give you a 4K60 4:2:0 > the default middle position EDID is limited to 4K60 4:2:0 to ensure everyone have a picture out of the box, on next fw, we even put a 4K30 so 4K30 HDCP1.4 display owner also have a picture out of the box.
If both of the above works for you. then you can move to AUTOMIX, if you lost video (blackscreen) it means your HDMI cables are not good enough for 600MHz.
You can use our support forum if you want more help. We will be happy to get you running.
HDfury is offline
post #86 of 4546 Old 11-17-2015, 10:26 AM
ZippZopp's Avatar
Quoted: 91 Post(s)
Liked: 30
Hello ZippZopp
EDID Slide on FIXED
Thanks so much for the prompt reply. I will test these settings out tonight. I'm pretty sure my cables are good. I have mediabridge 18gbps cables hooked up. maybe i need something better?
ZippZopp is offline
post #87 of 4546 Old 11-17-2015, 10:42 AM
HDfury's Avatar
Liked: 348
You will find out by doing the above tests if your cables are good enough or not.
In case of issue, you can also try to reset the integral (long press on reset button for +10s)
You can also update to the latest firmware (we have a mandatory update coming this week)
Let us know.
By the way, can you confirm the following:
Since your AVR is 4K30 only, it means that if you get audio thru, then your Denon is capable of accepting 4K60 4:2:0 and decode the audio while being a 4K30 Max AVR. Just like the NR709 reported above.
This is good news for 4K30 AVR Owners ! may be most 4K30 Max Denon AVR can decode audio from a 4K60 4:2:0 stream, it is very interesting.
HDfury is offline
post #88 of 4546 Old 11-19-2015, 06:38 AM
Manni01's Avatar
Liked: 3120
@HD Fury: I installed the latest f/w (0.46.0.22) and I saw that the switching on/off of the LED was mentioned in the release notes (that was fast!), but I couldn't find a way to disable the LED in the GUI. Am I missing something, or do we need a new version of the GUI to take advantage of this feature? Thanks!
[EDIT: there is now a link to a new V1.4 but it still points to the old V1.3 file]
[EDIT2: got V1.4 now!]
[EDIT3: I guess I was looking while you were putting the files on line, the LED on/off works great, thanks for implementing it so quickly. Now I only have to mask the blue LEDs.].
Manni01 is offline
post #89 of 4546 Old 11-19-2015, 06:05 PM
HDfury's Avatar
Liked: 348
Integral 0.46.0.22 FW Update and GUI 1.4 are available from the Download Tab: here
Make sure to install silabs driver first if you haven't yet done so.
This update IS mandatory if you are having an issue, we will ask you to run this version.
If everything works fine in your setup you can wait further improvement to upgrade your unit.
Total Control APP 1.0.4 for Android is available from the Download Page and should be live on Google Market in the next hours. (It does not yet include the below additions, approx 2 weeks from now, you will have all below features supported from the APP.)
Here is a summary of what's new since we last announced an update on this thread.
More details are available in the ReadMe file of each download.
Integral Firmware Update 0.46.0.22 and USB GUI PC Windows Software 1.4
- IF/HDR auto demo mode improved (IFX demo final)
- HDR MODE ON/OFF Demo now available for Samsung JSxxxx owners or LG HDR display owners, or any HDR display owners! Turn the HDR MODE ON/OFF from your TV whenever you want
- GUI shows information about the Source device if it sends the SPD infoframe.
- GUI includes detection for 10-bit 4k60 420 mode.
- GUI includes detection for color spaces.For example, when using Shield in 10bit mode it reports BT2020 color space.
- Integral LED LOGO on/off
- 4k60 600MHz -> 4:2:0 force mode support broke on shield since its last update. It has been verified working on PC Desktop from TOP and BOT outputs.
Known issue: There is some issue with Shield non-processed BOT output still in this mode.
- Added / replaced the custom selectable EDID tables with the following:
4K30 4:4:4 + Full Sound (default)
4K60 4:2:0 8bit 709 + Full Sound (300MHz)
4K60 4:2:0 10bit BT2020/HDR ON+ Full Sound (371MHz)
4K60 4:4:4 8 bit 709 + Full sound (600MHz)
4K60 4:4:4 8 bit BT2020/HDR ON + Full sound (600MHz)
- Added HDR HOTKEY mode now set CEC SP as HDR DEMO MODE ON and CEC LP as HDR DEMO MODE OFF.
- Added Input Priority mode for autoswitching enhancement.
- Added BT2020 forced flag option for EDID automix.
- Added HDR Data packet in automix mode: 2.0 / 5.1 / Full Audio / HDR data packet / BT2020
- Added Manual or Auto AVI Infoframe Injection
- Added "HDR mode force" that will send out AVI mods + HDR IF everytime there is a resync.
- Improved robustness built in mode detection (might slightly help in HDMI cables issue)
Known issues:
ARC: some early fw do have ARC support but its not fully functional, work in progress.
CEC: Channel switch, work in progress.
Take Care:
The Default CUSTOM EDID is now 4K30 4:4:4 after update (instead of 4K60 4:2:0 previously). We did that to allow 4K30 display owners to also have a picture out of the box.
If the previous custom EDID was perfect for your setup, you can use it or any other from the above list (or your own) by simply selecting it from the GUI dropdown menu (as per picture attached)
Please note that all EDID tables are already within the Integral Unit, so you do not need to READ/WRITE/CHECKSUM and all the advanced options for advanced users, just pick the one you want from the dropdown and that's it, it's in use !
Some sources device like SHIELD will default to 1080p60 with a 4K30 4:4:4 EDID unless you select resolution over frame rate preference in settings.
If you have a HDR display, you should have fun and good time testing this release (a video is following shortly)
@MultimediaGeek : I'm sorry the CEC solution for your setup is not yet on this package, we know what have to be done for your setup, it's underway. (see PM)
@Manni01 : Do you want Blue Led ON/OFF too ?
ID:	1068538   Click image for larger version
ID:	1068546   Click image for larger version
AidenL and Manni01 like this.
HDfury is offline
post #90 of 4546 Old 11-20-2015, 05:57 AM
Manni01's Avatar
Liked: 3120
@Manni01: Do you want Blue Led ON/OFF too ?
Yes, it would be great to be able to switch all LEDs off, but you might want to make it a separate option as while the integral LED is purely cosmetic, the blue LEDs can be useful to some. I just don't have a choice in my bat cave, all LEDs have to be switched off...
Manni01 is offline
Reply Video Processors
K8500
