Convert 480p to 480i - AVS Forum | Home Theater Discussions And Reviews
Old 02-10-2003, 12:17 PM - Thread Starter
fsckd's Avatar
Is there a cheap/easy way to convert component output 480p to 480i? This is mostly a convenience thing, so that I wouldn't have to run some components via S-Video and others via component, and constantly juggle inputs on my old-school NTSC set.
fsckd is offline
Old 02-11-2003, 01:05 PM
Allan Jayne's Avatar
No.
The easiest thing to do is use S-video for everything, given that convenience of switching is your main concern. All 480p DVD players I know of will also output 480i component video with the flip of a switch.
(What else do you have that outputs 480p but not 480i component or S-video?)
Video hints:
http://members.aol.com/ajaynejr/video.htm
Remember when lines and logos burned the TV screen? I was at a concert where a musical selection made extremely heavy use of about four of the keys of the piano.
Allan Jayne is offline
Old 02-12-2003, 12:57 AM
duffin's Avatar
What about the other way, s-video to 480p component would be an improvement. Anything available under $300 for a single line source?
duffin is offline
Old 02-12-2003, 05:19 AM
delusion602's Avatar
Yes, check out avtoolbox.com. They have a $100ish line doubler, and a decent scaler (AVT-3700) that does about every imaginable resolution between 480p and 1080i for a couple hundred more.
"Fry, you're wasting your life sitting in front of that TV. You need to get out and see the real world."
"But this is HDTV. It's got better resolution than the real world!"
delusion602 is offline
Old 02-12-2003, 09:54 AM
duffin's Avatar
None of the avtoolbox items have component 480p output. It is all VGA or XGVA output.
Any other ideas for s-video to component 480p output?
duffin is offline
Old 02-12-2003, 01:05 PM
Mike Lindberg's Avatar
You can get a transcoder of some kind and use the VGA out.
-Mike Lindberg-
Mike Lindberg is offline
Old 02-12-2003, 05:24 PM
Dylan's Avatar
I'd look for a used iScan. It'll do a fine job and will meet your price.
-Dylan
Dylan is offline
Old 02-12-2003, 06:34 PM
duffin's Avatar
Yep! iScan it is.
duffin is offline
