HD Leeza Release April 14 or 24 - Page 9 - AVS Forum | Home Theater Discussions And Reviews
Old 05-08-2003, 11:03 AM
michaellucky's Avatar
Originally posted by asinshesq
Right, I heard the same thing from the other guys that did the first beta test -- the unit automatically switches off when it notices the fan going in the wrong direction, but you just switch the wires around and you're all set.
We look forward to your report.
Dear Alan,
Only 15 units shipped with fan problem! So far 65 units on the field!
Thank you
michael@keydigital.com
michaellucky is offline
Old 05-08-2003, 11:10 AM
joaquin's Avatar
Quoted: 39 Post(s)
Liked: 31
Originally posted by michaellucky
Dear Alan,
Thank you
Michael, is there a way to identify those 15 units? like with serial numbers etc.
joaquin is offline
Old 05-08-2003, 11:30 AM
Alan Gouger's Avatar
Quoted: 31 Post(s)
Liked: 57
As mentioned a small price to pay to be an early adapter.
I think most would still want to get their units in their hands now so they can play and fix it them selfs instead of waiting a few more weeks.
For those wanting the proper step by step instructions to correct this if you do end up with this problem please email me: alan@avscience.com
Alan Gouger is offline
Old 05-08-2003, 03:00 PM
Dean Roddey's Avatar
Quoted: 388 Post(s)
Liked: 294
I was told a batch shipped with the fan in reverse operation and you need to remove the cover and reverse the wires. A simple fix.
That sucks... no wait, it blows... no I guess it sucks... or does it blow? I guess it depends on how you look at it.
Dean Roddey
Chairman/CTO, Charmed Quark Systems, Ltd
www.charmedquark.com
Dean Roddey is offline
Old 05-08-2003, 03:11 PM
Cclear's Avatar
:D
Cclear is offline
Old 05-08-2003, 03:58 PM
Quoted: 31 Post(s)
Liked: 57
Dean
Wow 9092 posts. Youve been busy.
Old 05-08-2003, 04:51 PM
Quoted: 388 Post(s)
Liked: 294
I'll probably lose about 1500 of them when the Iraq Crisis section gets dumped, assuming that that will remove all of those posts from our post count.
Dean Roddey
Old 05-08-2003, 05:43 PM - Thread Starter
joeycalda's Avatar
Quoted: 49 Post(s)
After all the anticipation I was expecting adjectives like unbelievable and breathtaking. Unfortunately they seem to be replaced with good and fine. I guess nobody knows how to set it up properly. Not. Lets get some reviews on picture quality, s-video and component in.
JC
joeycalda is offline
Old 05-08-2003, 05:57 PM
asinshesq's Avatar
Originally posted by joeycalda
After all the anticipation I was expecting adjectives like unbelievable and breathtaking......
OK, it's unbelieveble and breathtaking that no one has yet got the thing up and running the way it's supposed to run long enough to properly test it and report back here. But it's just a matter of time.....
Alan
asinshesq is offline
Old 05-08-2003, 06:03 PM
Tony Costanza's Avatar
From Michaellucky
"Only 15 units shipped with fan problem! So far 65 units on the field!
Thank you."
When was the fan introduced? It was my understanding that there would be no fan. What DB @ 4'? If the fan is noticeably noisey it's going back!
Frankly I'm getting skeptical...
TonyC
Tony Costanza is offline
Old 05-08-2003, 06:18 PM
rluciano's Avatar
I couldn't hear the fan at 2'. Of course the unit shut down after 5 minutes of operation because it overheated, but I don't think the fan which is only for the power supply, will be an issue for many. The fan noise won't be an issue for me based on what I heard in the time I had the unit. It is on the bench at KD now being tested. When I get it back and get things working properly I'll post my impressions and photos.
rluciano is offline
Old 05-08-2003, 06:54 PM
asinshesq's Avatar
Originally posted by Tony Costanza
...When was the fan introduced? It was my understanding that there would be no fan. What DB @ 4'? If the fan is noticeably noisey it's going back!....
I think the fan is just part of the power supply. Not like the big pc fan that the Digital Leeza had. But I'm waiting like you are for the real scoop.
Alan
Old 05-08-2003, 11:32 PM
Quoted: 31 Post(s)
Liked: 57
Alan the fan is mounted on top of the power supply. It only took me 5 minutes to fix the problem we had with the fan.
Worked perfect after the fix. Unless your right ontop of the unit it is silent.
Old 05-09-2003, 01:56 AM
Daniel Hutnicki's Avatar
I think that the old Leeza had 2 or 3 fans which could make it noisey. I had one of the original ones without the updated faceplates and after I sent it, for a minor bug, they modified it to quiet it down which it did
Daniel Hutnicki is offline
Old 05-09-2003, 04:38 AM
thebland's Avatar
Quoted: 1499 Post(s)
Liked: 852
Mine is coming today, I am looking forward to some experimenting over the weekend. I'll certainly post results.
Jeff
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
Old 05-09-2003, 06:03 AM
Donf's Avatar
Alan,
Is there any way to tell if the fan is working correctly before installing? Air flow direction? I would like to just plug it in and be able to check the air flow prior to hooking up all the connections.
Also, since the unit is coming from AVS will I get an e-mail on the fix.
Looking forward to playing with it.
Don Frier
Donf is offline
Old 05-09-2003, 06:36 AM
KevD's Avatar
TonyC,
The fan is completely un-noticeable. I plugged the unit in to make sure the fan was working properly before installing it. I had to put my ear about 3 inches from the top vent on the unit to hear it running. Don't worry..... I will be installing it with a G90 tomorrow, too bad I didn't have a Faroudja to do a side by side.
KevD
KevD is offline
Old 05-09-2003, 07:45 AM
Quoted: 31 Post(s)
Liked: 57
Don
Just set it on the counter and plug it in. Let it sit for an hour. If it does not shut down your all set.
If you have any trouble call me. Its easier to walk you through it.
585 454 1460 ext 205
Old 05-09-2003, 07:52 AM
cougar75's Avatar
Quoted: 38 Post(s)
Liked: 31
Someone should rename this thread now that the HD Leeza is shipping and shortly to be reviewed in detail by the lucky members that have them.:)
cougar75 is online now
Old 05-09-2003, 08:08 AM
asinshesq's Avatar
I agree...Alan, would you like to do the honors in an 'offical' way?
Alan
Old 05-09-2003, 08:30 AM
oferlaor's Avatar
Why not start a separate thread and move the discussion there?
I think most of this thread contains our wishes that the product come out already.
This is just the right time to create a new thread with reviews, questions, etc. that are relevant now that the product is shipping.
What do you think?
Cheers,
Ofer LaOr
www.hometheater.co.il
oferlaor is offline
Old 05-09-2003, 08:32 AM
helfy's Avatar
I vote for a new thread!!!
Michigan's Best Home Remodeler!
helfy is offline
Old 05-09-2003, 08:38 AM
cougar75's Avatar
Quoted: 38 Post(s)
Liked: 31
This thread is 14 pages. New one is in order. Might want to move relevant posts from this thread to new thread.:)
