HDFURY Linker new firmware - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #1 of 44 Old 07-13-2017, 09:02 AM - Thread Starter
Quoted: 243 Post(s)
Liked: 48
@HDfury I was wondering if the new firmware version is expected soon still? I look forward to testing.
bobof is online now
post #2 of 44 Old 07-13-2017, 09:32 AM
HDfury's Avatar
Quoted: 1778 Post(s)
Liked: 355
Yes sorry we have been a little bit delayed by some unexpected events including the X1S Dolby Atmos support that came in at the same time.
Integral new FW and GUI is up, we will now work on Linker and provide you with update asap or at least test file directly for X800
I'll get back to you shortly.
billqs and bobof like this.
HDfury is online now
post #3 of 44 Old 07-13-2017, 01:06 PM - Thread Starter
Quoted: 243 Post(s)
Liked: 48
No hurry, as much as anything wanted to make sure there was somewhere to post the update...
Thanks for your continued support.
billqs and MGBPUFF like this.
bobof is online now
post #4 of 44 Old 07-15-2017, 04:39 PM
Nalleh's Avatar
Quoted: 1255 Post(s)
Liked: 673
@HDfury : now that the Linker has Dolby Vision update, will this somehow show up in the GUI if the disc has it?
Triple Atmos Receivers
Atmos 13.1.8/DTS:X 9.1.8/AURO 3D 12.1
My setup:
http://www.avsforum.com/forum/29-wha...l#post41323201
Nalleh is online now
post #5 of 44 Old 07-15-2017, 06:02 PM
HDfury's Avatar
Liked: 355
Dolby Vision is EDID signaling only. On Linker you just have to load a custom EDID with DV datablock which we are supplying with latest fw and gui update.
Then your source will see DV capable display and output DV, this is why today with such limited available material and equipment supporting it, we are not sure if it can be bundled with current edid or not.
It's supplied separately until we have enough feedback.
On Integral it is added in EDID flags and in Automix routines detection.
Nalleh likes this.
post #6 of 44 Old 07-16-2017, 08:00 AM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
What wall plug did I need with the Linker, and why wasn't it in the original package?
Sent from my SM-G928T using Tapatalk
Erod is offline
post #7 of 44 Old 07-16-2017, 01:04 PM
billqs's Avatar
Quoted: 318 Post(s)
Liked: 181
The wall plug ships in a separate white box, so they can place a power supply good for wherever you are in the world.
HDfury likes this.
JVC RS500, Denon 7200WA, 7.2.4 Atmos/DTSX dedicated Theater. 133" Dalite 1.3 screen. M&K S150 + K7 ear level, 4 Tannoy DC overheads.
billqs is offline
post #8 of 44 Old 07-16-2017, 02:47 PM
claw's Avatar
Quoted: 1073 Post(s)
Liked: 991
Did you order direct from HDFury.com or from a reseller? HDFury.com includes a power adapter for the region you select. They have no control over what resellers do or don't.
HDfury likes this.
CJ
claw is offline
post #9 of 44 Old 07-16-2017, 05:30 PM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
Does it have to be plugged in full time, or is it rechargeable?
Erod is offline
post #10 of 44 Old 07-16-2017, 07:58 PM
claw's Avatar
Liked: 991
There is no battery in the Linker. It has to be powered either by USB connected to a PC, or by USB connected to the power adapter that is plugged into an electrical outlet.
HDfury likes this.
CJ
claw is offline
post #11 of 44 Old 07-16-2017, 09:22 PM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
Ok, so if I changed the settings in the Linker already, will those changes stick since I haven't had it powered the last several days?
There was a USB cable, just no wall plug included.
Erod is offline
post #12 of 44 Old 07-17-2017, 06:55 AM
HDfury's Avatar
Liked: 355
Any changes will survive powercycle, you will only lost settings if you HARD RESET the unit (hold RST for 8sec) or apply new firmware.
If you ordered from HDfury.com, there is a wall plug adapter included. If you ordered from any others place, then it's up to them.
post #13 of 44 Old 07-17-2017, 07:22 AM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
OK, so all I need is a wall plug. How do I just buy a US wall plug without spending $50 for that charging kit? Can I just use a plug from an iPhone or something?
Erod is offline
post #14 of 44 Old 07-17-2017, 07:30 AM
HDfury's Avatar
Liked: 355
Sure, anything with 5V and at least 2A will work just fine.
billqs likes this.
post #15 of 44 Old 07-17-2017, 08:25 AM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
OK, thanks. I didn't want to fry the board or not give it enough juice.
Erod is offline
post #16 of 44 Old 07-17-2017, 06:01 PM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
On another note, why can't I get my Linker to save my settings? I'm changing EDID to 10 and disabling the HDR, but when I close the window and bring it back up, those changes are gone.
Erod is offline
post #17 of 44 Old 07-17-2017, 08:04 PM
HDfury's Avatar
Liked: 355
That is new, i just tried and EDID 10 and Disable HDR are well saved if i close and re open GUI right after, with or without powercycle of the unit in between.
which FW and which GUI version are you using ?
post #18 of 44 Old 07-17-2017, 08:09 PM
claw's Avatar
Liked: 991
Verify that the EDID Mode slide/switch on the side of the Linker is set to the middle position: Custom/GUI use EDID.
CJ
claw is offline
post #19 of 44 Old 07-17-2017, 09:12 PM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
0.21
Erod is offline
post #20 of 44 Old 07-17-2017, 09:13 PM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
They are.
Erod is offline
post #21 of 44 Old 07-17-2017, 09:16 PM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
It says "Error writing values" on the bottom when I click disable.
Erod is offline
post #22 of 44 Old 07-18-2017, 06:28 AM
HDfury's Avatar
Liked: 355
0.21
They are.
Use Firmware 23 and GUI 0.20 and you won't have any issue. you have to use the GUI that match the FW version.
post #23 of 44 Old 07-18-2017, 02:24 PM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
I don't see it on your website. Most recent is Firmware is 20 and GUI 0.19.
Erod is offline
post #24 of 44 Old 07-18-2017, 04:18 PM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
Never mind. Found it.
Erod is offline
post #25 of 44 Old 07-18-2017, 06:24 PM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
OK, now I'm getting frustrated. I am using FW23 and GUI20, but when I check Disable on the HDR injection, it unchecks itself after a couple of seconds. What am I doing wrong?
Erod is offline
post #26 of 44 Old 07-19-2017, 04:10 AM
HDfury's Avatar
Liked: 355
hehe, i don't know, but take some screenshot of your GUI settings and i should find the problem.
Make sure you flashed firmware and that GUI report as 0.23
post #27 of 44 Old 07-19-2017, 07:45 AM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
OK, here you go.
BTW, does the Linker have to be connected to the projector for the HDR Disable to hold, or can I program it first from my computer, then connect after?
Erod is offline
post #28 of 44 Old 07-19-2017, 11:51 AM
Quoted: 91 Post(s)
Liked: 67
I can't seem to find the HDFURY Linker main thread but I'll post my question here.
I'm looking to see if the Linker is all I need to purchase. My goal is to output 4K to my tv while the Linker outputs 1080p non-hdr to my gaming monitor.
XBox/PS4/ - > Yamaha 3060 ->HDMI 1 to TV (4K)
->HDMI 2 to Linker (1080p) ->Monitor
Will this work or do I need another piece?
ziocomposite is offline
post #29 of 44 Old 07-20-2017, 06:36 AM - Thread Starter
Quoted: 243 Post(s)
Liked: 48
@HDfury , would be nice to have a fw to test X800 with this weekend (hint hint... )
bobof is online now
post #30 of 44 Old 07-20-2017, 06:24 PM
Erod's Avatar
Quoted: 158 Post(s)
Liked: 53
I guess not. Back it goes.
Erod is offline
Reply Video Processors
