HD LEEZA - new firmware - Page 15 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #421 of 430 Old 12-20-2005, 08:31 AM
Morg111's Avatar
I have owned the HD Leeza for years now and have not been pleased at all. I can't tell anymore how many times I have pleaded with them to offer a resolution (native 1365x768) that will work for Fujitsu Plasmas. The DVDO is able to snap to the native resolution, why not Key Digital? It doesn't look like this upgrade did much of anything new..... I'm fairly sure this feature list is from an old upgrade because none of these features are new.
-M
Morg111 is offline
post #422 of 430 Old 12-20-2005, 08:59 AM
Q of BanditZ's Avatar
-M
I don't mean this in a rude way, but how's come you've kept the product for this long if you've been displeased with it?
Great ISF Job by Chad B.
Q of BanditZ is offline
post #423 of 430 Old 12-20-2005, 10:09 AM
Morg111's Avatar
I have been on the pre-order list for the Algolith Dragonfly for well over 6 months.....
Morg111 is offline
post #424 of 430 Old 12-21-2005, 01:29 PM
Morg111's Avatar
-M
Just an update and a correction.....If Key Digital is listening..........
1360x768 is the resolution I have been pleading for......(fujitsu plasmas) To be exact.....
H-Shift 144
>H-Size 1360
>H-Front 176
>H-Sync-112
>H-Back 144
>H-Total 1792
>V-Shift 8
>V-Size 768
>V-Front 8
>V-Sync 6
>V-Back 13
>V-Total 795
Morg111 is offline
post #425 of 430 Old 01-04-2006, 03:34 AM
Madders's Avatar
Anyone tried the new firmware 019C? What are the changes?
Definition of a home cinema - A dark room into which you throw money!
Madders is offline
post #426 of 430 Old 01-04-2006, 06:39 AM
Steve Richards's Avatar
Quoted: 17 Post(s)
I haven't tried it yet. I put 18c on last week and it works fine for me.
I compared the change documents for 18 & 19 and did not see any thing different, so I could only guess it was a bug fix only. They don't seem to list bug fixes anymore just additions to features.
Steve
Steve Richards is online now
post #427 of 430 Old 01-10-2006, 10:27 PM
hepcatz's Avatar
Is their site down?
Has anyone setup the Leeza with a JVC DLA-G20 projector. I need some setup advice.....using RGBHV cable.
Michael
hepcatz is offline
post #428 of 430 Old 03-25-2006, 09:55 AM
Madders's Avatar
How does the HD Leeza rate against the Lumagen HDP for HD deinterlacing these days? I know that the HDP has made some big improvements in this area with recent Firmware releases, but wondered if the HD Leeza has kept up?
Madders is offline
post #429 of 430 Old 11-09-2006, 04:30 PM
A/Vspec's Avatar
I see color banding on the Lezza with HD input into it at 1080i 60Hz? Anyone else?
-Mark AKA A/Vspec
ISF certified Audio/Video Specialist
Home of the ISF and Audyssey Pro calibrated Medieval Knight Theater:
http://www.digitalvortex.com
A/Vspec is offline
post #430 of 430 Old 11-09-2006, 08:15 PM
Quoted: 17 Post(s)
I also noticed this when I switched to new tivo s3.
works ok at 720p input but I am seeing banding also at 1080i.
I did not notice this with old directv tivo...
Steve
Closed Thread Video Processors
