Want to convert S-video to component - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-22-2003, 11:12 AM - Thread Starter
ericholtman's Avatar
I have a Samsung 63" plasma. I'm running the DVD and the HDTV from cable to component inputs. I have another video source (TIVO) which won't do component out.
It's impossible to program a macro on my remote to gracefully switch the video source on the TV between component and s-video. So I'd like to convert to s-video from the tivo into component, so I can feed that into my receiver and let it do the switching.
What's a decent, low cost way to do this? (I'm willing to bet "decent" and "low cost" do not play well together).
Eric.
ericholtman is offline
post #2 of 10 Old 12-23-2003, 12:47 AM
oferlaor's Avatar
Try kramer electronics, they usually have that sort of thing.
Cheers,
Ofer LaOr
www.hometheater.co.il
oferlaor is offline
post #3 of 10 Old 12-23-2003, 10:41 AM
Gshepherdogs's Avatar
Ofer,
I thought it was not possible to convert s-video to component?
Gshepherdogs is offline
post #4 of 10 Old 12-23-2003, 12:08 PM
yubyub's Avatar
Of course it is possible. It's done by an external comb filter. Hometheater Hifi has a review (a bit old, though) here, where they review then compare the Crystal Vision VPS1 to the Faroujda VP-100:
http://www.hometheaterhifi.com/volum...talvision.html
-Y
"First things first, but not necessarily in that order." - Dr. Who
yubyub is offline
post #5 of 10 Old 12-25-2003, 10:43 AM
rrg
rrg's Avatar
If interlaced component output (480i) is okay, then the Matrix V3 from Projection Specialists might also solve the problem for you.
Ron Gomes
rrg is offline
post #6 of 10 Old 12-29-2003, 12:55 PM
tvtech1's Avatar
A comb filter seperates the chroma from the luma in a composite signal.
An s-video signal is already seperated into Y and C, no comb filter is necessary, in fact, the elimination of the comb filter is one of the reasons to use s-video.
To convert s-video into a component signal. The Chroma signal has to be demodulated and decoded into the I and Q signals, which are furhter processed into Y, R-Y, and B-Y.
tvtech1 is offline
post #7 of 10 Old 12-29-2003, 12:57 PM
By converting to component, are you then losing any of the picture quality. It seems that may lead to data loss?
post #8 of 10 Old 12-29-2003, 01:04 PM
tvtech1's Avatar
Component is capable of greater resolution then either composite or YC. Converting composite to component won't result in quality loss, the reverse will.
tvtech1 is offline
post #9 of 10 Old 12-29-2003, 03:30 PM
yubyub's Avatar
tvtech1,
Doh - I must've missed my coffee that day. You are, of course, correct. I must've been thinking of composite...
-Y
yubyub is offline
post #10 of 10 Old 12-30-2003, 11:24 AM
Don O'Brien's Avatar
Purchase a used Iscan at audiogon and set the unit to output component video instead of RGBHV. 250 dollars
Cheers,
Don O
Don O'Brien is offline
Closed Thread Video Processors
