Wish List of Features for the Upcoming Algolith Dragonfly - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 221 Old 09-28-2004, 11:47 AM
AlanMFriedman's Avatar
To answer the previous question, I would definitely like SDI inputs (at least two). I presently use an SDI modded RP-91 to feed my scaler. I have been using an SDI modded DVD player for about three years. I am very happy with the picture quality.
Until there is a prevalent alternative that surpasses it in quality, for me, SDI is a must.
AlanMFriedman is offline
post #92 of 221 Old 09-28-2004, 07:39 PM
Emery's Avatar
I absolutely agree about SDI "in" on the processor. I was the one who originally asked for it in this thread. What I was trying to answer was the comment by Emery who asked for SDI "out" on the processor or an optional SDI "out".
The only reason I mentiond SDI out would be for professional applications, not HT. I know this product is being designed for HT but I work in the broadcast world where everything is SDI. A dual purpose product might be a good idea. They could possibly have two versions. A home theatre version and a pro version with more I/O. Its just a thought but it may be a good idea being the only difference in engineering would be the I/O.... just opens up their market.
Emery is offline
post #93 of 221 Old 09-29-2004, 12:14 AM - Thread Starter
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Thanks. But even in the pro world, what is the point of an SDI out on a processor? SDI is for 480i only, correct? What would you want to feed in to the processor to down rez to 480i?
mark haflich is offline
post #94 of 221 Old 09-29-2004, 02:28 AM
rabident's Avatar
Quoted: 335 Post(s)
Liked: 107
So to summarize...
Want:
1) Mosquito NR incorporated into Dragonfly
2) SDI Input (1 - 2 ports)
3) HDMI / HDCP / DVI input (multiple ports)
4) HDMI / HDCP / DVI output
5) RGBHV over BNC outputs
6) 48 / 72 Hz output rates for judder free film sourced output
7) All the other "standard" scaler features
Not needed in a consumer device:
1) HD-SDI input - expensive to implement. There are no consumer sources, nor will there ever be.
2) SDI output - opens the door for possible legal issues. Plus no value add in the consumer space.
rabident is offline
post #95 of 221 Old 09-29-2004, 07:42 AM
bluevision's Avatar
Mark,
Some folks use the term "SDI" to mean both SDI (480i) and HD-SDI (1080i).
bluevision is offline
post #96 of 221 Old 09-29-2004, 11:47 AM
JJay's Avatar
I think rabidnet's summary is pretty good except I would make the sdi inputs optional. I would have 2 hdmi inputs standard with the option of adding up to 2 hdmi or 2 sdi inputs (or 1 and 1).
Jaime
If you can't say anything kind at least have the decency to be vague...
JJay is offline
post #97 of 221 Old 09-30-2004, 01:32 AM
rogo's Avatar
Quoted: 1591 Post(s)
Liked: 1790
I'm very fine with 2 HDMI on board and the chance to add 2 more (in lieu of SDI, 1 and 1, etc.) as JJay suggests. That would meet everyone's needs and allow for a sufficiently small backplane. The SDI / HDMI module, however, would have to be cleverly designed and / or connected internally using ribbon cables.
There's a saying about "everything in moderation". If only it was applied to well, you know...
rogo is offline
post #98 of 221 Old 10-01-2004, 10:15 PM - Thread Starter
Liked: 1010
If more than one Realta chip is necessary to give us the ultimate in deinterlacing, scaling, and MNR, then please do it all in one box with multiple chips.
post #99 of 221 Old 10-02-2004, 05:38 PM
Tong Chia's Avatar
That is a great idea which I am going to take one step further and suggest
the use of expansion daughterboards. So we can keep adding
more Realtas are we pile on the different functions and only
pay for the processing power as we need them.
Tong Chia is offline
post #100 of 221 Old 10-02-2004, 06:17 PM
Ray Lego's Avatar
Just a note that HD-SDI, being the current professional broadcast standard for HD 1.5Gb/sec internal transmission in post and broadcast, CANNOT transport 1080p60. So, even if you had HD-SDI I/O in your set top box, you would always be limited to 1080i59.94. In the high-end post areas like Lucasfilm and ILM, they use 'dual-link' HD-SDI paths, for an aggregate total of over 3Gb/sec data transfer. Currently this is the only way to get 1080p60 and 4:4:4 signals around a facility.
There are also copy protection issues with home use, HUGE ones, that I won't go into here.
Having seen a lot of 1080p60 lately, I'm sold on it. Can't wait to see this at home.
Ray Lego is offline
post #101 of 221 Old 10-02-2004, 07:36 PM
bluevision's Avatar
Both component analog and DVI support 1080p60.
post #102 of 221 Old 10-02-2004, 09:29 PM
Ray Lego's Avatar
I understand. Just pointing out the limitations of HD-SDI.
Ray Lego is offline
post #103 of 221 Old 10-03-2004, 10:20 AM
kromkamp's Avatar
Quoted: 88 Post(s)
Liked: 70
Realistically, though, true 1080p content is likely to be film sourced for a long while, so only 24Hz needs to be supported. True 60Hz material (sports, etc) is likely to come from 720p/1080i formats.
kromkamp is offline
post #104 of 221 Old 10-03-2004, 12:14 PM
odyssey's Avatar
It’s not the source format as much as the format after de-interlacing. The best way to de-interlace 1080i 60 Hz content is to 1080p60. This is a limitation with the current Teranex boxes.
odyssey is offline
post #105 of 221 Old 10-03-2004, 03:24 PM
Ray Lego's Avatar
1080p60 is a limitation with the Teranex I/O hardware only. The Teranex array processors are capable of whatever resolution we map to. We demostrated a 'data box' at IBC last year that could process 2K images through the Teranex processor from a server. 4K was a possibility but we dropped the project because of the small market size (right now at least).
Note that this was non-real time processing, about 7 fps, and film-based. We have also done 1080i to 4K upconversions using the Teranex algos with excellent results.
Hollywood doesn't currently have the ability to record super hi-rez (4k) real time so everything is stored as data files.
Ray Lego is offline
post #106 of 221 Old 10-03-2004, 04:24 PM
odyssey's Avatar
Ray,
I understand and as you mentioned, single link HD-SDI does not support 1080p60. Support of dual link HD-SDI would still be a good feature of the present Teranex products and the digital cinema projectors can handle that input. That market is getting larger and alternative content processed through Teranex would be attractive. I am using a 6RU unit and the only alternative is to convert 1080i60 to 720p60 for 60 Hz content to avoid a lot of judder.
odyssey is offline
post #107 of 221 Old 10-03-2004, 04:30 PM - Thread Starter
Liked: 1010
Right. As a consumer who watches a lot of live video sports at 1080i with a 60hz refresh, I would like 1080p at 60. My projector can handle that, no problem. Thanks in advance for giving it to me.
post #108 of 221 Old 10-03-2004, 05:51 PM
bluevision's Avatar
It won't be long before you see 1080p60 over SDI in the studio. It will take some time to get to the consumer level but it's coming!
post #109 of 221 Old 10-03-2004, 05:57 PM - Thread Starter
Liked: 1010
I don't need it HD-SDI. I need it analog only. Hell I have it now from 480i. I want to get it from 1080i in. Just give me motion compensation 1080p from 480i and 1080i please. :)
post #110 of 221 Old 10-03-2004, 06:22 PM
bluevision's Avatar
It would be nice to avoid the A-D, D-A and A-D conversions. Mark, I agree with you, 1080i60 directly in to the display. A VXP processor does the digital 1080i30-p60 conversion and them out to the display. :)
A word of caution, motion compensated processing does as much bad as it does good.
post #111 of 221 Old 10-04-2004, 05:39 AM - Thread Starter
Liked: 1010
Off topic, but perhaps you can explain the difference between motion adaptive and motion compensation? I thought motion compensation is the ultimate in deinterlacing but that the computing capacity needed is the factor preventing its implementation at the consumer level.
post #112 of 221 Old 10-04-2004, 11:29 AM
oferlaor's Avatar
Mark,
That's correct, Motion Compensation is the ultimate in deinterlacing. It's still slightly out of reach even for the Realta, from what I understand.
Cheers,
Ofer LaOr
www.hometheater.co.il
oferlaor is offline
post #113 of 221 Old 10-04-2004, 01:52 PM
HQV
HQV's Avatar
Please note that the HQV motion adaptive algorithm is the best there is because it's so refined; remember that it has been tested over and over again by the professional markets (Hollywood/broadcast/post, etc).
Mark is dead on when he says:
It only does "as much bad as good" if you try to do it without the processing power required (i.e. Teranex supercomputer). It's better than motion adaptive because it shifts the fields that are spatially misaligned due to motion so that they are on top of each other so to provide full resolution. I've seen many a jaws drop when they see it in action for the first (and 2nd, 3rd, 4th...) time.
Hollywood Quality Video
HQV is offline
post #114 of 221 Old 10-04-2004, 07:50 PM
bluevision's Avatar
Mark,
You are absolutely correct! Motion compensated processing does provide you with the ultimate in de-interlacing when done right! It definitely requires an extreme amount of processing prower. As a benchmark, even the HQV with its "performance on the level of teraOPs" still only does motion adaptive de-interlacing (as pointed out by HQV in the previous post). :)
I'll try to explain the differences between the two methods. For more information, YubYub's Video Processor FAQ has a lot of information on this subject matter.
Motion Adaptive (MA)
- Detects motion between fields. The more fields that are used, the more accurate the motion vector.
- Uses historical data points to try to extrapolate the future position.
- One or multi-dimensional filters are used.
- Filters along edge and temporal directions.
- Performed on a field, block or pixel basis.
- Good performance (about 98% accurate when done on a per-pixel basis over a number of fields).
- Good temporal resolution, sharp details, less temporal flicker and artifacts.
- Moderate complexity.
Motion Compensated (MC)
- Estimates motion between fields.
- Uses historical data points to try to predict the future position.
- Filters along detected temporal direction.
- Performed on a block or pixel basis.
- Very good performance (over 99% accurate when done right).
- Very good temporal resolution with sharp details.
- Very high complexity.
When trying to predict the future location in MC algorithms, you are bound to guess wrong some of the time (hence my comment that it can do as much bad as it does good). The 'black magic' is in what you do when you guess wrong that adds complexity to the algorithm. This technology will get to the consumer level in time (Moore's Law).
I hope that this helps explain the difference to you.
post #115 of 221 Old 10-04-2004, 11:01 PM - Thread Starter
Liked: 1010
Thanks for the explanations.
post #116 of 221 Old 10-05-2004, 11:25 PM
rabident's Avatar
Quoted: 335 Post(s)
Liked: 107
Thanks for the explanations on deinterlacing modes, but I have to disagree with you on the statement above. With the copy protection concerns, we'll never see 1080p running over an unencrypted transport like HD-SDI in the consumer space. That's what HDMI is for.
rabident is offline
post #117 of 221 Old 10-06-2004, 12:20 AM
oferlaor's Avatar
rabident,
I don't see where you two are disagreeing. SDI/HD-SDI are strictly professional transport mediums. The fact that we're piggybacking on SDI is not making it any more consumer oriented.
HD-SDI will not compete with HDMI, although it is a far better transport, IMO.
Cheers,
Ofer LaOr
oferlaor is offline
post #118 of 221 Old 10-06-2004, 09:18 PM
Algolith's Avatar
Good evening AVS forum users, thank you very much for all the wonderful constructive advise. Following your input. I'm going to do a first here (I believe) and tell you what we plan as connections for the Dragon Fly based on all your input, and a focus on main stream current and future needs. Unfortunately No SDI, or BNC's. I know some of you will be upset, but we believe HDMI inputs will serve 480i digital needs and HDMI output will give best possible PQ output, also available at the o/p component on RCA and RGBHV on HD-15 to drive analog devices. An electrical and optical audio delay is part of the product. Features will be competitive. Now I need your help one more time, since we have HDMI in and out for various devices, could you provide us with what you feel is the most common HDMI DVD player, set top box and display
Inputs
1 YC(SVHS)
1 Composite on RCA
1 Component on 3 RCA's
2 HDMI
Outputs
1 Component on RCA
1 RGBHV on HD-15 (VGA type connector)
1 HDMI
Control;
USB
IR
wired rmt
RS232
Ethernet
Algolith is offline
post #119 of 221 Old 10-06-2004, 10:36 PM
Steve Goff's Avatar
Quoted: 323 Post(s)
Liked: 152
Well, too bad. No SDI in and no BNCs makes this a less than serious product for videophiles. I guess I'll look elsewhere. Again, there are only three dvd players I know of that will output 480i over HDMI: the Pioneer, and two Arcams. You'll really hobble your fine product with these choices.
Steve Goff
Steve Goff is online now
post #120 of 221 Old 10-06-2004, 10:45 PM
rogo's Avatar
Liked: 1790
And I think -- by contrast -- this will be a fine product for videophiles, but....
.... there needs to be a companion HDMI switcher with more ports. I'm not going to press multiple buttons, please... At a bare minimum, work with the switcher folk to make this a single solution. Please :)
As for set-top, display, and DVD, that's such a moving target it's pointless to even say.
Today, Toshiba and Panasonic lead in low-end DVD players with HDMI, Denon is a serious player as you move up the value chain.
Set tops? The DirecTV/Tivo w/HDMI comes to mind.
Displays? Too many to mention. I am currently using a Sharp panel and considering a Sony projector.
Mark
rogo is offline
Closed Thread Video Processors
