Runco Ultra Scaler/Processor - Better Choices ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-04-2000, 06:51 AM - Thread Starter
mzn50's Avatar
Location: Plugging cables behind rack in Ottawa, Canada
In my discussions with my dealer on either a Rnco 930 or 940, the Scaler/Processor of choice is always the Ultra series. I ould like to buy a processor that supports 720P, so I am limited to either the VHD 4403 or 4404
Any better, possibly cheaper alternatives out there that performs to the same level or better and does 720P ?
Thanks.....Matt
___________________
mzn50@amdahl.com
Thanks.....Matt
mzn50 is offline
post #2 of 4 Old 08-04-2000, 12:58 PM
adidadi's Avatar
Quoted: 97 Post(s)
Liked: 46
I have been very happy with my Crystal Image from AV Science. It produces a filmlike picture at 720p. Very clean, especially with a clean DVD transfer. Also, it is well priced. Check it out at the AVS store. Also has VGA pass through for HD or other sources.
Silence is overrated!
FS: Sony VPL VW5000ES. Two Weeks old REDUCED: $ 32,900.00
http://www.avsforum.com/forum/218-di...-ve5000es.html
adidadi is offline
post #3 of 4 Old 08-04-2000, 11:25 PM
Aerlith's Avatar
I think I'm confused...why in particular would you want a processor to run at 720p? The 930's EMF/smaller spot size might reward the higher figure, but wouldn't that be a bit too much for the 940 (Barco)? In addition, does the 720p rez mentioned have anything to do with HDTV uses, and if so isn't the processor bypassed? Anyone-what might be the best processor settings (let's assume 60Hz for the moment)for these two projectors? Does this change with aspect(4x3 vs. anamorphic vs. Ltrbx)?
-Aerlith
-Aerlith
Aerlith is offline
post #4 of 4 Old 08-05-2000, 06:23 AM - Thread Starter
mzn50's Avatar
Aerlith,
Good question, my Proceed PMDT Transport/DVD has a feature path of 720P in the future, although no DVDs support that level, I would think once the technology is made available, this will become reality.
Thanks.....Matt
___________________
mzn50@amdahl.com
Thanks.....Matt
mzn50 is offline
Closed Thread Video Processors
