Quadscan v2.10 filter removal? - AVS Forum | Home Theater Discussions And Reviews
Old 12-30-2000, 11:23 AM - Thread Starter
Jerry's Avatar
Thanks smddoc,
And thanks as well for the email.
I hope everything works great for you and the quadscan as well.
Jerry
Jerry is offline
Old 12-30-2000, 09:18 PM - Thread Starter
Jerry's Avatar
Hi,
I'm considering a quadscan v2.10. I have a crt fp and have heard that this particular version softens the picture somewhat.
Since I may buy this unit used is it possible to make a modification myself or is it necessary to return the unit?
Any help or suggestions are appreciated as this may affect my purchase decision.
Thanks, Jerry
Jerry is offline
Old 12-30-2000, 09:30 PM
smddoc's Avatar
I just spoke to phil at taw he say's the filters are in the newest units which are still ver 2.10 . He also said that the mod is as easy as clipping out a jumper in the unit and is very easily performed, however you should check with FE to make sure it's ok so you don't void your warranty. Apparently this mod makes a big difference with crt projectors.
When mine arrives I'm going to set it up with out making any changes and see how it looks. I'll decide from there whether or not to do the mod on mine.
smddoc is offline
Old 12-30-2000, 10:15 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1011
My company's video tech, Mike Parker in MD (a forum member) performs the mod. We spent 5 hours tracing the circuts and fiquring out what to do. I believe he removes two levels of filtering. The difference (improvement)on a good CRT (Electrohome 8000, 8500, 8500LC, 9500LC)is staggering. Very significant with the DWIN 700 too. The unit is sharp as a teck with the mod. It is very soft above trippled TV with out it and is soft at trippled TV. The warranty is not an issue as long as it is dealer performed (at least that is what the techs at FE have told us). The issue is academic as to performing the mod in the future as FE will exchange the .10 for free with the better newer unit when it comes out.
mark haflich
mark haflich is offline
Old 12-31-2000, 08:13 AM
smddoc's Avatar
Any word when the newer unit will be out from FE ?
I'd also like to know how much you charge for the mod.
[This message has been edited by smddoc (edited 12-31-2000).]
smddoc is offline
