Poor man's SDI - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 744 Old 06-20-2003, 03:11 PM
J_Nemeth's Avatar
I seem to remember people saying that Zurg's red eyes in the opening scene of Toy Story 2, where Buzz is fighting Zurg was a definite indicator of the chroma bug.
Jay
"Can I please just watch this the way it was meant to be seen?"
J_Nemeth is offline
post #452 of 744 Old 06-20-2003, 03:13 PM
mavromatis's Avatar
mavromatis is offline
post #453 of 744 Old 06-20-2003, 03:20 PM
jamesmil's Avatar
Quoted: 44 Post(s)
Liked: 40
This is the best discription I've seen of it:
http://www.hometheaterhifi.com/volum...ug-4-2001.html
For all the concern about it, it seems like a pretty minor issue.
jamesmil is offline
post #454 of 744 Old 06-20-2003, 03:46 PM
mavromatis's Avatar
That's exactly what I was looking for!!! I take it most processors fix the problem... Rock, HD Leeza, DScaler... so it's a moot point now...right?
post #455 of 744 Old 06-20-2003, 07:34 PM
Atman's Avatar
The Chroma filter of DScaler can fix the chroma bug problem.
Atman
Atman is offline
post #456 of 744 Old 06-21-2003, 03:15 PM
nachin's Avatar
HUMAX DV-1100S
DIGITAL RECEIVER WITH DVD PLAYER
2 common interfaces
DVD – CD – MP3 player
5000 channels
Upgrade via satellite and serial port (RS232)
2 scarts ..
360,00 €
I´m trying to get pictures of the interior, I can´t promise anything but I´ll try.
It could be a good an economical solution!!!
Nacho.
nachin is offline
post #457 of 744 Old 06-21-2003, 03:31 PM
Roberto Koelewijn's Avatar
Nacho,
It all depends on the datastream present. A picture of the interior can be helpful, but when there is a video encoder present, you cannot see on the picture what datastream it's using because these modern video encoders support multiple datastream modes. Only probing with a scope can determine if modding is possible.
regards,
Roberto
Roberto Koelewijn is offline
post #458 of 744 Old 06-21-2003, 03:44 PM
nachin's Avatar
I have read somewhere that is "like" the Humax 5100 and the 5100 is SDI modifiable.
The doubt now if is the DVD and the Sat receiver use the same encoder, Don´t you?
Nacho.
nachin is offline
post #459 of 744 Old 06-25-2003, 05:13 PM
PillPu$her's Avatar
Has anyone modified an RCA satellite box yet?
PillPu$her is offline
post #460 of 744 Old 06-27-2003, 03:06 AM
Atman's Avatar
Hi Danny,
Your mailbox is full so I can't reply your message by PM. Just to tell you it is ok to keep the capture card longer.
Atman
Atman is offline
post #461 of 744 Old 06-27-2003, 10:22 AM
mavromatis's Avatar
post #462 of 744 Old 06-28-2003, 04:09 PM
power's Avatar
sorry but have to ask....
which dvd players are eligible for the SDI mod and which ones aren't. In my case, the SDI mod for a Panny XP50 is what i need. The mod should work but i have to ask.
Serge Breton
htauthority.com
Home Theater Authority
power is offline
post #463 of 744 Old 06-28-2003, 09:16 PM
Atman's Avatar
I have created a web page to list the SDI modification methods for various DVDP/STB. http://www.pmsvideo.com/index_topic....ath=/1636/2523
Please send me (email: atman@pmsvideo.com) your SDI modification experience, pin assignment and/or pictures so that other videophiles can share your experience. Thank you very much for your support.
Atman
Atman is offline
post #464 of 744 Old 06-29-2003, 12:48 AM
Hello Atman,
Great start for a database. I really like the clear pictures and instructions.
thanks,
Roberto
post #465 of 744 Old 06-29-2003, 04:58 AM
nachin's Avatar
In your web page
you talk about the National Semiconductor SDV020EVK SDI Board but is still in Preliminary Status at the National web page.
Anybody knows when it will be abailable?
Nacho.
P.D.: Only $100:)
nachin is offline
post #466 of 744 Old 06-29-2003, 05:11 AM
Nachin,
The sd020evk is based on the clc020 chip. This is an old version of the clc021. I don't think this board is available anymore.
regards,
Roberto
post #467 of 744 Old 06-29-2003, 05:27 AM
nachin's Avatar
Thank you Roberto.
The new ones
SD021-3EVK
SD021-5EVK
are also non available or preliminary status,
There is a realease date for them? and more important ...
Which are the correct for each player?
I have also see the SD901EVK receiver,
Could we in a future modify our DVD recorders to record the SDI signal from our mod SDI satellite receivers?
And about the HDTV
SD130EVK
SD131EVK
Dou you think are they compatible with DVD players?
Nacho.
nachin is offline
post #468 of 744 Old 06-29-2003, 06:26 AM
I haven't seen one using the new development boards. However there are a number of forummembers who are selling comparable sdi transmitter boards. for example the board of atman is very reasonable priced and is shipping worldwide. Also forummember Tester007 is going to sell sdi transmitter boards, however i don't know his pricing.
btw these boards can only be used when the player has a bt656 datastream available. All other players can be categorized into 2 groups;
1) no datastream exposed, for example the latest versions of cheap dvd players using a single chip solution where the analog video is coming directly from the chip. There is no way you can add a sdi output.
2) no bt656 datastream. If you are lucky it's a bt601 stream with vsync and hsync. Other possibilities are unmultiplexed videostreams with whatever sync signals present.
This tread got reactivated again by Mavromatis by his quest to get a SDI mod for his Pioneer DV07. It has resulted in a mod which accepts a bt601 stream with hsync and vsync. However we noticed these kind of videostreams and sync signals are not well defined by standards. You have to modifiy the code of the fpga for every different player.
The SD901EVK receiver could be used to mod a dvd recorder with a sdi input but it all depends on the recorder ;)
the national hd-sdi chipset could be used to modify a dvd-player, but why use it when sd-sdi chipsets are still available.
post #469 of 744 Old 06-29-2003, 08:38 AM
nachin's Avatar
I have found one place to buy the SD021-5EVK card with 5 volts operation.
Anybody knows if is indicated for the Panasonic RA82 or other DVD player?
Nacho.
nachin is offline
post #470 of 744 Old 06-29-2003, 09:15 AM
you can use the board for a ra82
post #471 of 744 Old 06-29-2003, 11:06 AM
mavromatis's Avatar
Just to give you all an update... Roberto, Dan and myself successfully converted a bt.601 stream to bt.656... so my Pioneer DV-F07 300+1 DVD now outputs perfect SDI. YEA!!
The intent was to make this solution available to everyone, but we have noticed (like Roberto stated in a previous thread) that timing is different across devices. So we are working on a device that will solve this and possibly make it a drop in unit for all devices. We now understand how this all works and think there is a way make it universal. The outcome should be an easy and inexpensive solution to get SDI out from any device that has an accessible bt.601 stream. Everyone should be able to watch the best possible picture at a reasonable price. We will call it... "THE ULTIMATE SDI MOD".
I know there are a bunch of you interested in a converter board right now, but it would be a pain for you guys to setup your system to compile verilog and then tweak the code until you find the perfect timing values. Plus, this would also require a JTAG cable to program the FPGA... adding to the cost.
So bare with us as we figure an easy solution for everyone... wouldn't it be sweet if all DVD players had SDI out as a standard feature and we didn't need to hack them!
post #472 of 744 Old 06-29-2003, 07:09 PM
Atman's Avatar
Hi Danny,
Good job!
Atman
Atman is offline
post #473 of 744 Old 07-01-2003, 11:37 AM
WTS
WTS's Avatar
Quoted: 37 Post(s)
Hi;This might be slightly off the topic, but maybe someone who has posted in this thread can give some insight to the following;
I have a few questions;
About the comparison(s) between SDI(sd/hd) and DVI. They're both
digital formats, although DVI can communicate in both directions.
SDI seems like the easiest one to implement, so why did the
industry opt for DVI. Was it because of the 2 way com. of DVI.
There seems to be alot of interest in SDI mods for dvd players
and digital boxs. Why not just mod them for DVI, or is DVI presently
by license only? I haven't done alot of research into DVI chips,
but it appears that only TI and Silicon Images are the only two
companys making DVI chips. The SDI mods seems to be getting great
results, as they should be, by bypassing the analog stages it should
be a huge improvement. So why did the industry not use SDI for a
format, or is that a loaded question with a 100 different answers.
The trend now seems to be that DVI is appearing as o/p's and i/p's
on alot equipment. Obviously these are compatable to be just be
connected together, ie; a DVD player directly to a projector, so why
the necessity for a piece of equipment in between these two, like
a Leeza or the aSimilator, for scaling etc. Could this not be easily
done in the front end of the projector, the DVI interface has the ability to ask the DVD/digital box what it's output is and then it could adjust the scaling accordingly to match the format of the display. After all, the projector already does the functions like 3:2 pull down etc etc, so why not the scaling too.
If more inputs are required-DVI inputs only of course, a simple input switcher (hence inexpensive) could be inserted between the two for this purpose. The ability to do the scaling too, may add a little more to the end price of the projector, but in this age of LSI chips it shouldn't add that much more and it should be a whole lot less than having to buy another piece of gear like a Leeza or aSimilator. Of course this would hurt the bottom end of some of these companys that market such eqiupment now needed for scaling purposes.
I hope the industry is headed in this direction in the near furture.
It's not like the manufacturers of projection equipment don't have
the know-how when it comes to implementing these changes into the projector.
One other note, there seems to be alot of people stating that using component connections gives better results than using Dvi connections when it comes to the i/ps for a projector.
Any feedback would be great.
Walter
WTS is offline
post #474 of 744 Old 07-01-2003, 08:43 PM
CH Yeow's Avatar
Hi,
Can a Pioneer 626D dvd player be modified with SDI? Anyone with success?
CH Yeow
CH Yeow is offline
post #475 of 744 Old 07-01-2003, 10:24 PM
wts,
SDI is a well defined pro-video standard with no copy protection implementation. The movie industry would never accept this standard for consumer products. Only because HDCP, DVI is accepted as a high definition digital output. DVI is primarily designed to drive a display device.
Why are the SDi mod's popular. Well there are a number of video processors (including SDI-Silk/Dscaler and H3D I/II) available which accept SDI. To get the best connection between you player and the processor you want to stay in the digital domain and avoid any unnecessary digital-analog-digital conversions.
Until recently there where no processors with DVI inputs and players with DVI output.
The biggest problem are the players with DVI output because they have to process interlaced video into progressive video. The processing in the player is only a part of the player and therefor subject to compromise in regard how production costs of the player are distributed.
A video processors soul purpose is to process video therefor no compromise has to be made. (of course it all depends how much the product retail price is) The same apply to projectors.
However with the introduction of the new highly integrated "video processor on a chip" chips could tip the scale in favor of integrated video processing solutions.
just my 2 cents.
regards,
Roberto
post #476 of 744 Old 07-02-2003, 10:52 AM
Atman's Avatar
CH,
I have the Pioneer DV-F727 BT656 pin assignment. But I am not sure if it is the same as Pioneer 626D.
Atman
Atman is offline
post #477 of 744 Old 07-02-2003, 10:54 AM
mavromatis's Avatar
Atman... the F727 is the 300 changer... just like the DV-F07 Elite and it has a BT.601 stream (with hsync and vsync lines). I have both modded and they work perfect (with the FPGA mod). I don' think it's the same as the 626...but it's easy to find out... pop the cover off and see what type of encoder it has :)
post #478 of 744 Old 07-02-2003, 06:31 PM
Atman's Avatar
Hi Danny,
Philips SAA7201 is a MPEG decoder used in sat receiver.
http://www.semiconductors.philips.co.../SAA7201_3.pdf
It seems that it outputs BT601. Can it be SDI-modified with your FPGA?
Atman
Atman is offline
post #479 of 744 Old 07-06-2003, 01:47 AM
CH Yeow's Avatar
Dear Atman,
Thanks. Let me check again.
I send you a PM.
CH Yeow
Originally posted by Atman
CH,
Atman
CH Yeow is offline
post #480 of 744 Old 07-06-2003, 01:54 AM
CH Yeow's Avatar
May I know what are the pin assignments. i am new to these stuff.
CH Yeow
CH Yeow is offline
Closed Thread Video Processors
