Algolith Dragonfly Reviews - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 07-10-2005, 08:48 AM
Stacy Huff's Avatar
They have a pro rear projection monitor based on the HD2K that uses a Realta based scaler already.
That intriqued me so I went looking on the JVC Pro website. It took awhile, but I found it. The DLA-HRM1U, coming in October. At a suggested list of $42,995 !!!
The fact that they are using the HQV processing does make me wonder if something might be in the works for the consumer 1080p sets. But if it takes $40,000.00 to get HQV built in, I'll take a dozen of the Algoliths. (I do wonder how similar the processing actually is...)
"Being unable to assume an initial premise with any tolerable degree of accuracy, I am loathe to assert a conclusion fearful lest I should err."
Stacy Huff is offline
Old 07-10-2005, 11:15 AM
Snail's_Pace's Avatar
Originally Posted by rabident
For now, yes. Dennon used the chip already in one of their DVD players. Lumagen was rumored to be working on a scaler based on the chip. JVC was also as well as a replacement for the rebadged Faroudja 1010 scaler they bundle with their HD2K. They have a pro rear projection monitor based on the HD2K that uses a Realta based scaler already. I thought I remembered hearing an audio processor was going to use it, but I can't remember the details (or if it's even true). I may be missing some others. More are sure to come, but the DragonFly looks like it's going to be the first available general purpose scaler based on the chip.
I believe NEC's forthcoming TheaterSync will also incorporate the Realta/HQV processing which, from the sounds of the description in the press release, will also be a stand-alone processor/scaler.
Snail's_Pace is offline
Old 07-11-2005, 02:26 PM
Q of BanditZ's Avatar
Ridiculous.
Great ISF Job by Chad B.
Q of BanditZ is offline
Old 07-11-2005, 10:48 PM
Morg111's Avatar
Originally Posted by Q of BanditZ
Ridiculous.
Second!
Morg111 is offline
Old 07-11-2005, 11:05 PM
Morg111's Avatar
And another thing......What SDI to DVI/HDMI converter is Algolith going to offer with the Dragonfly as they will not have an SDI input. Please tell me its not going to be the "Ridiculous" price of $800 or more as I have seen all over the place.
-M
Morg111 is offline
Old 07-12-2005, 04:40 AM
PedroV's Avatar
MSRP for the SDI/HDMI 480i converter will be $495. It will be called "Tick"
From the Preliminary Spec sheet I got from Algolith:
Video Input:
Input signal: SMPTE 259M-C (270 Mbps)
Return Loss: > 15 dB up to 270 MHz
Cable Length: 90 m (300’) (Belden 8281 or equivalent)
Connector: 75 BNC
Video Output:
HDMI 480i (High-Definition Multimedia Interface V1)
Processing:
Full 10-bit signal path
Fully Transparent Color Space Conversion (Y, Cb, Cr –> RGB)
Processing of the Sink EDID and source emulation
Front Panel LED:
One led flashing when powered on, stable on carrier Detect.
Connectors:
· One BNC 75 Ohms
· One HDMI
· External DC power supply
· Optional HDMI male-male 6ft cable
Power:
· External AC Adaptor
· Input: 90-240 VAC 1A
· Output: 12VDC 4. 5A
· Low profile fan less chassis
Dimensions:
· Width: 2 in
· Depth: 3 in.
· Height: 1 in.
· Weight: 0,25 lbs
Pedro
PedroV is offline
Old 07-12-2005, 08:36 AM
Morg111's Avatar
Video Input:
Connector: 75 BNC
Video Output:
Processing:
Front Panel LED:
Connectors:
· One BNC 75 Ohms
· One HDMI
Power:
Dimensions:
· Width: 2 in
· Depth: 3 in.
· Height: 1 in.
· Weight: 0,25 lbs
Thanks Pedro, very informative. Though for that price I'd might as well go and get a new HDMI DVD player that outputs native 480i HDMI.
Morg111 is offline
Old 07-12-2005, 09:34 AM
kraigk's Avatar
I agree Morg (buying a 480i player). In addition to the cost it uses one of the HDMI ports which is less than ideal.
-kraig
kraigk is offline
Old 07-12-2005, 10:19 AM
Keenan's Avatar
Quoted: 2231 Post(s)
Liked: 2029
Man, that's expensive, you'd think it would be easier and cheaper to use an add-on board, similar to what DVDO does...you wouldn't need the box, power supply, etc....it seems as if an SDI connection was an extremely after thought, after the fact, addition..
Keenan is online now
Old 07-12-2005, 12:30 PM
Morg111's Avatar
Actually they had plenty of time and notification of the issue. They just chose to lay the cost and responsibility on us the consumers. Frankly it was a great business decision on their part. They knew that there was going to be no competition so they could pick and choose what the didn't feel like adding. The more I think about the short comings of this unit the more I would love to hear from DVDO that they were going to release a Realta based processor. I'd cancel my preorder and wait. Further.....Algolith hasn't gotten back to me yet as to the Dragonfly's compatibility (1 to 1 pixel mapping) with Fujitsu panels which are not 1366x768 but rather 1360x768.
I know previous DVDO models can sync to the native resolution. :rolleyes:
-M
Morg111 is offline
Old 07-12-2005, 12:51 PM
Keenan's Avatar
Liked: 2029
The totally unsubstantiated rumor is that he new DVDO unit is looking around Q4/05.
Josh from DVDO has said there will be a press release 'soon" about the new equipment....
Old 07-12-2005, 03:09 PM
Mark Petersen's Avatar
It's only $200 or so more than the DVDO add-on card, but one thing that is nice is that you can keep your converter if you ever change scalers. With the DVDO add-on you're stuck with using it only with the HD+. I'd call this a strength rather than a weakness. Not only that, but because it uses HDMI into the scaler rather than SDI you can demultiplex your SDI sources directly in the mosquito/dragonfly combo rather than buying a separate SDI switch box.
Mark Petersen is offline
Old 07-12-2005, 04:04 PM
Dale Adams's Avatar
Not true.
The DVDO SDI module is used in both the iScan HD and HD+. This same SDI module will also work in (at least) the next DVDO scaler, so you can carry your SDI investment forward if you choose to upgrade to that product.
- Dale Adams
Dale Adams is offline
Old 07-12-2005, 05:24 PM
Keenan's Avatar
Liked: 2029
Originally Posted by Dale Adams
Not true.
- Dale Adams
Thanks for confirming what I expected the case to be.
Besides, if anybody's like me, the last thing I want is...another...box...separates are nice, but at this level it gets a little ridiculous....I don't see why Algolith could not have done the same thing.
Old 07-12-2005, 10:33 PM
Morg111's Avatar
I hope that this DVDO news announcement comes out before my Dragonfly preorder is filled. I further hope that it is VERY detailed so I can make an educated decision. Times-a-ticken!
-M
Morg111 is offline
Old 07-12-2005, 11:30 PM
D&D
D&D's Avatar
-M
Me too.
D&D is offline
Old 07-13-2005, 02:50 PM
Not true.
- Dale Adams
It's good to hear that the new DVDO scaler will use the same add-on SDI card. My point though is that there is still a loss of flexibility. If someone changes scalers down the road (non-DVDO or HD+++) they will lose their investment. The Tick is not even the most expensive route for someone who has more than one SDI input, because they would still need to purchase another box for SDI demux'ing. Adding more boxes is definitely a pain, but for those of us who like to experiment with different hardware, flexibility is also a feature to consider.
Old 07-15-2005, 12:41 AM
rabident's Avatar
Quoted: 340 Post(s)
Liked: 110
I don't think it was so much of an after thought as it was just not wanting to commit resources to a niche. I have an RP-82 SDI, so I'm in that niche and really would have liked to see a 1 box solution for both Mosquito filtering and SDI input, but I can't blame them for leaving it out. It's more expensive for us to buy a bunch of boxes, but it lowers the cost of their core products.
At $800, I think a lot of people will simply switch to an HDMI DVD player. Maybe that's what they're hoping for.
rabident is offline
Old 07-15-2005, 02:25 AM
PedroV's Avatar
MSRP is $495 not $800.
The problem with HDMI players is that most do not output 480i.
Pedro
PedroV is offline
Old 07-15-2005, 10:12 PM
rabident's Avatar
Quoted: 340 Post(s)
Liked: 110
That said, it looks like Lumagen is going after the SDI niche, and then some. REWJR posted a pic in this thread that shows 2 SDI inputs and a plethora of others inputs on Lumagen's upcoming Realta based scaler.
rabident is offline
Old 07-15-2005, 11:04 PM
Oh! Oh! A new HQV based scaler that we can tear apart on the forum ;)
I like the inclusion of SDI but only two DVI inputs and no HDMI? What gives? Also what about audio switching? How do they get around the long (and variable!) HQV audio lag without an audio input?
Old 07-16-2005, 12:48 AM
AndreYew's Avatar
I don't think that's a new product from Lumagen. That's a picture of the HDP Pro:
http://www.lumagen.com/images/prohdp_back.jpg
--Andre
AndreYew is offline
Old 07-16-2005, 11:28 AM
Doh! We fell for it ;)
Old 07-18-2005, 11:30 AM
So it looks like the Dragonfly has been delayed until September :(
Old 07-18-2005, 11:35 AM
Morg111's Avatar
Where did you hear that? I know that they are not including the customizable output resolutions to speed the product to market (later software release). It must be a manufacturing issue.
:mad:
Morg111 is offline
Old 07-18-2005, 11:57 AM
:mad:
Just remember: Better to have them delay it now, a little bit, then to rush a buggy/incomplete product to market and then you're at the mercy of waiting for firmware.
Old 07-18-2005, 12:00 PM
Morg111's Avatar
I don't think it has to do with design. They already are planning on firmware updates to complete the product several months after shipping starts.
Morg111 is offline
Old 07-18-2005, 01:16 PM
wjchan's Avatar
Liked: 29
All signs point to a delay. The pre-order is gone from here and from their site. Either it's a delay or it's selling like hotcakes and they can't keep up with the demand. Most likely it's the former.
wjchan is offline
Old 07-18-2005, 03:24 PM
:mad:
Alan announced the delay in the AVS club forum. I hope he doesn't mind me posting it here too.
I also hope that the unit will be relatively bug free. It is Algolith's first scaler though so cross your fingers that they get it right.
Old 07-18-2005, 04:23 PM
thebland's Avatar
Quoted: 1501 Post(s)
Liked: 852
Is there RS-232 control with the Dragonfly?
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
