Lumagen deinterlaces 1080i - finally - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #181 of 239 Old 03-15-2006, 12:45 AM
spatz's Avatar
Clarence it sure sounds that you have a misadjustment in your G90 settings.
I have setup 4 G90 this year with Lumagen HDP units and 1080p and they all worked immediately, the only thing that I needed to change are the clamp settings. All connected analog.
BTW the ZONE adjustment allows a lager shift of the image than the RGB shift does. I have the faint idea that this might be the problem.
Bring the SHIFT settings back to 128 and move your active image with ZONE
for RGB and then try again. You should display the test patterns of the Lumagen.
Reset the Lumagen, dial in 1080p at 59,94 and then try these adjustment.
Eidophor oil projector on a fork lifter connected to an original SONY BETAMAX, stunning picture, never seen anything better
spatz is offline
post #182 of 239 Old 03-15-2006, 06:28 AM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 10080
Thanks Spatz.
I reset the Lumagen to factory defaults.
I changed [M0932] from AUTO to 4=BOTH.
I switched to 1080p [M027].
Then I brought up the overscan test pattern... [M MISC TPAT PATS OK >>>>]
Then I normalized SHIFT on the G90 and used ZONE to adjust.
As you suggested, I tried the CLAMP settings on the G90:
SERVICE MENU... INPUT SETTING... CLAMP.
I changed CLAMP from AUTO to HP.
That works!
Test patterns are stable with the default HDP timings... 1920x1080@59.94 with HSYN 88 and HFRN 44.
So I saved the config on the Lumagen [M SAVE SAVE OK] and with a G90 MEMORY.
That was analog to 5BNC. I'll try DVI tonight.
Thanks again.
Clarence is offline
post #183 of 239 Old 03-15-2006, 08:52 AM
Chuchuf's Avatar
Sorry I didn't see this thread earlier, but yes as Spatz indicated it's the clamp which has to be set to HP.
I'd be curious what you think of the HDP when deinterlacing 1080i ->1080P 60 for your G90 when compared to the other scalers you have been testing.
Terry
AVS Marketplace or Videogon are the places to see F/S ads
Chuchuf is offline
post #184 of 239 Old 03-15-2006, 01:05 PM
patrick harkin's Avatar
Allan, the new update with the improved 1080i per-pixel deinterlacing you were asking about was just posted on the Lumagen website (sw revsision 030806)--this is for all the current generation of units (VisionDVI,HDP and ProHDP). There's a few other additions and bug fixes as well.
Patrick Harkin, Lumagen Inc. engineer
patrick harkin is offline
post #185 of 239 Old 03-15-2006, 08:16 PM
Allan Jayne's Avatar
Thanks, Patrick.
Remember when lines and logos burned the TV screen? I was at a concert where a musical selection made extremely heavy use of about four of the keys of the piano.
Allan Jayne is offline
post #186 of 239 Old 03-15-2006, 10:17 PM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 10080
I haven't installed today's firmware update yet, but here are my first screenshots with the HDP...
Motorola 6412 HD DVR... 1080i deinterlaced to 1080p.
9' 7" wide:
http://crtforum.com/img/hdp-osd.jpg
http://crtforum.com/img/hdp-osd2.jpg
"Flying Daggers" is just an upconvert, but it still looks pretty good.
Clarence is offline
post #187 of 239 Old 03-16-2006, 09:40 AM
Alan Gouger's Avatar
Quoted: 31 Post(s)
Liked: 57
I tried to new update last night. Is it just me, Im seeing a big improvement in PQ on this one. Far more crispness. It could be placebo effect so Id like to hear from others but this download made a big difference.
Alan Gouger is offline
post #188 of 239 Old 03-16-2006, 03:50 PM
oferlaor's Avatar
Alan,
It's not a placebo effect, they made another incremental PQ improvement (just got the word a few days ago, didn't even get a chance to try it out).
Cheers,
Ofer LaOr
www.hometheater.co.il
oferlaor is offline
post #189 of 239 Old 03-16-2006, 06:37 PM
Art Sonneborn's Avatar
Quoted: 247 Post(s)
Liked: 309
So you guys are pleased with the HD deinterlacing overall now ?
Art
My HT
For Sale: Stewart 14' wide Vistascope screen with BRIC controller
Contact me for pricing.
Art Sonneborn is offline
post #190 of 239 Old 03-16-2006, 08:38 PM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 10080
Art
Yes, I think it looks really good, Art.
I'm doing an in-depth comparison between my HD Leeza and the HDP, but I don't think I can post the link here. I do have some other observations, but I'll e-mail those to you.
I took this opportunity to compare the firmware upgrade process. The Lumagen update was very simple... nicely written... good progress bar indication. Took about 5 minutes total. Last week I'd updated the HDLeeza's firmware. Not too different, but Lumagen gets a shoot-out point for more frequent updates, clearer instructions, and better feedback during the upload.
I know you can't assess anything from screenshots, but they're fun. Here's one from my tests tonight...
Tim Allen in Shaggy Dog, 1080i from 6412 HD DVR via component to HDP to G90 at 1080p, 115" wide:
http://crtforum.com/img/hdp-eye.jpg
Clarence is offline
post #191 of 239 Old 03-16-2006, 10:59 PM
HooStat's Avatar
Interesting. I didn't think the quality was notably improved. But there seems to be a huge audio delay now. I am not usually bothered, but this is pretty bad. Perhaps it is just me but I am seriously considering going back to an earlier version. I was using one from November to give you an idea of how frequently I bother to update the software.
HooStat is offline
post #192 of 239 Old 03-16-2006, 11:01 PM
Quoted: 31 Post(s)
Liked: 57
Clarence
Post that link:)
Those pictures look dam good. I miss CRT.
post #193 of 239 Old 03-17-2006, 03:30 AM
mburnstein's Avatar
Hi Clarence,
please email me those comments comparing HD-Leeza and Lumagen 1080i deinterlacing mburnste@dmc.org
if you can't post that link
thanks
mark
mburnstein is offline
post #194 of 239 Old 03-17-2006, 06:29 AM
Several updates ago the Lumagen HDP blew away the scalers in many upscale plasmas. With the latest updates (I haven't done mine yet) and what has been said so far, the Lumagens have to be the "killer applications" of the year for budget HDTV.
All of the good de-interlacers have a video delay in the vicinity of 1/20'th second.
post #195 of 239 Old 03-17-2006, 07:03 AM
LoveMovies's Avatar
I installed the latest update and watched one movie last night with it. I also noticed a huge audio delay, but here are different programs or channels from time to time that have noticable audio delay, so I didn't associate it with the HDP. I'll do more testing today and see if the huge delay is always there.
LoveMovies is offline
post #196 of 239 Old 03-17-2006, 07:03 AM
Maggie Guy's Avatar
Clarence,
If you are reluctant to post the link that you referred to earlier could you send me a pm?
I am in the market for a 1080p scaler as well.
Alpha LS Guy
Formerly known as Maggie Guy
Maggie Guy is offline
post #197 of 239 Old 03-17-2006, 02:35 PM
jrp
jrp's Avatar
Quoted: 181 Post(s)
Liked: 300
The new "AUTO" mode for HD deinterlacing has a delay of about 54 mS (NTSC or 1080i60) or 66 mS (PAL or 1080i50) with genlock on. Before we had the HD inverse-telecine, and also with the current software if you select either VIDPP or VIDNC mode, the delay is about 6 mS with genlock on.
Since the new AUTO mode switches between video per-pixel and inverse-telecine, both have to have the same delay. However, with the VIDPP or VIDNC, the video does not get delayed.
Some (many?) digital displays add additional delay, and these seem to be the only displays that most people can notice lip-sync delay.
With genlock off, the delay can be up to 16mS (or 20mS for 50 hertz sources) longer. Genlock on can often make the lip-sync a non-issue -- depending on how bad the delay is in the display.
One option to try is having genlock on with Auto HD deinterlacing programed as MEMA, and genlock off with VIDPP deinterlacing mode for MEMB. Since genlock takes a few seconds to lock (source selection or channel selection on some settop boxes), doing general watching with MEMB, will be nice for channel surfing and general material. Then switch to MEMA when you settle down to watch a good movie or show shot as 24p.
Jim Peterson
Lumagen
jrp is offline
post #198 of 239 Old 03-17-2006, 03:54 PM
jrp
jrp's Avatar
Quoted: 181 Post(s)
Liked: 300
This release has the new per-pixel mode, we have mentioned, that uses a single field scaled (BOB) if we detect motion in the image, and WEAVE otherwise. The old method used a blend of both field for the motion case. So the motion "blurr" several people have commented on is gone.
We have seen a significant improvement here in our own testing, so I don't think this is a placebo effect at all - okay I'm just a little biased. This is going to be most noticable on a 1080p pixel-perfect projector like Alan's Ruby. For lower resolutions, or if the display cannot support pixel perfect, the image improvements will be limited by the display/projector.
Alan: Did you compare the new "1080i to 1080p passthrough" (MENU->IN->CONFIG->ADJ->SIZE->SCALE->PASS) to the default "scaled" mode? I would be interested in your (and anybody else of course) comments of reduced-artifacts (scaled) verses more detail (pass-through).
Of course 1080i to 1080p is not really just "passthough" but that's what we called it. This is deinterlacing without going through the scaling process.
Jim Peterson
Lumagen
jrp is offline
post #199 of 239 Old 03-17-2006, 03:58 PM
mburnstein's Avatar
Jim, how is the 1080i deinterlacing for video sources with the new improvements? satellite 1080i HDTV any improvement on a 1080p display?
mark
post #200 of 239 Old 03-17-2006, 04:13 PM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 10080
Originally Posted by jrp
...with the current software if you select either VIDPP or VIDNC mode, the delay is about 6 mS with genlock on.
Thanks, Jim. That explains why I didn't notice any sync delay (I'm usually VERY sensitive to it)... I set my HDP to force VIDPP last night.
Clarence is offline
post #201 of 239 Old 03-17-2006, 07:29 PM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 10080
Interesting.
SCALE->PASS toggles as expected with 1080i from my XBox360,
but with my Motorola 6412 HD DVR, I get a couple of jittery white lines across the bottom of the screen. The rest of the image is stable.
With [M0918] enabled and SCALE->PASS enabled, the V/F flag switches to "P".
I'm guessing it's related to the same reason that I get 1934x1088 instead of 1920x1080 when I extract frames from the DVR. For example:
http://img326.imageshack.us/img326/7...rzhd9iq.th.jpg http://img206.imageshack.us/img206/7756/kb11mi.th.jpg http://img216.imageshack.us/img216/246/u2063ub.th.jpg
Since I don't have a fixed-pixel projector (Sony G90 CRT), I'm guessing I should switch TIMING to a custom output resolution of 1934x1088 to match the source input (Motorola 6412 HD DVR); i.e., should I deinterlace 1934x1088i to get 1934x1088p?
Or is the Lumagen HDP deinterlacing optimized for exactly 1080i->1080p?
Clarence is offline
post #202 of 239 Old 03-17-2006, 07:40 PM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 10080
Interesting.
I'm guessing the white lines are related to the same reason that I get 1934x1088 instead of 1920x1080 when I extract frames from the DVR. For example:
Also note the gray line at the bottom of each of those frames.
Clarence is offline
post #203 of 239 Old 03-18-2006, 06:14 AM
Anyone's 1080i to 1080p de-interlacing takes in 1080i and outputs 1080p. The resulting 1080p may then be scaled as a separate operation following, say, to 720p or in the case of scale->pass, output as-is.
Who reported "1934x1088" and superimposed those digits on the video image?
The Lumagen HDP's specs state 1080p as the maximum available output resolution.
post #204 of 239 Old 03-18-2006, 06:32 AM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 10080
1934x1088 is the size of the frame that's extracted from the "1080i" transport stream from my Motorola 6412 HD DVR.
VLC (link), MPC (link), TT2 (link), VideoRedo (link), ZPP (link), all report that frame size.
The superimposed digits are added by the online photo hosting service... imageshack, but only to the thumbnail. If you click on the thumbnail, you can see the fullsize 1934x1088 frame.
Previously, I'd assumed that the 14x8 extra pixels were getting blanked by the DVR's output, but since seeing the extar artifacts when trying the Lumagen's "SCALE->PASS" mode, it seems the extra pixels are actually coming through as input.
But when I press the OK button on the remote, it reports "IN4A 1080i" input.
Clarence is offline
post #205 of 239 Old 03-18-2006, 06:37 AM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 10080
Previously, I'd assumed that the 14x8 extra pixels were getting blanked by the DVR's output, but since seeing the extra artifacts when trying the Lumagen's "SCALE->PASS" mode, it seems the extra pixels are actually coming through as input.
Clarence is offline
post #206 of 239 Old 03-18-2006, 09:17 AM
Gordon Fraser's Avatar
Quoted: 118 Post(s)
Liked: 149
Lumagen can actually output more than 1080p I think......Sure they'll do at least 1152p@50
Gordon
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #207 of 239 Old 03-18-2006, 09:38 AM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 10080
Yep. Using the TIMING menu, I set the output to 1934x1088p, but I still get the white lines at the bottom when I toggle SCALE->PASS.
I'm just curious if it should be better to bypass scaling from 1934x1088 to 1920x1080.
It seems like it'd be much cleaner to deinterlace the native resolution of the source and bypass scaling completely. And since my projector can handle 1088p just as easily as 1080p, then I can configure the Lumagen for 1088p. But if the Lumagen's optimal deinterlacing is tied to 1080i->1080p, then I'll stick with 1920x1080.
Sorry if any of these questions are straying too far from the original topic. I want to use the Lumagen's deinterlacing capabilities in the best manner possible. But if it's more appropriate to ask these questions in a new thread or at the Lumagen forum, let me know.
Clarence
P.S. Ofer, nice review at Secrets.
Clarence is offline
post #208 of 239 Old 03-18-2006, 11:13 AM
Quoted: 118 Post(s)
Liked: 149
Clarence. I think your queries are best answered by Jim or Pat. I'm sure one of them will be along at some point....
Gordon
Convergent-AV
post #209 of 239 Old 03-18-2006, 12:37 PM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 10080
I'm mainly just thinking out loud and making notes to myself here. But based on the interest on this topic I've received via PM, I thought I'd share my thought process as I put my HDP through it's paces.
I want to clarify that my queries are not Lumagen "issues"... the HDP is working beautifully. I've found that what may seem like an obscure personal query usually applies to several people... I'm sure I'm not the only one trying to find the best way to deinterlace 1080i from a Motorola 6412. But let me know when my queries stray too far from the original topic of "Lumagen deinterlaces 1080i - finally" and I'll split my ramblings into a separate thread.
Here are some quick screenshots showing
MENU->IN->CONFIG->ADJ->SIZE->SCALE->NORM
http://crtforum.com/img/hdp-cat-scale.jpg
vs MENU->IN->CONFIG->ADJ->SIZE->SCALE->PASS
http://crtforum.com/img/hdp-cat-pass.jpg
Notice the scrambled lines at the bottom? I think that's caused by my DVR outputting 1934x1088i instead of 1920x1080i
I get similar results if I use the 1080p preset [M027]
or if I use TIMING VACT=1934 HACT=1088.
However, if I use a source with normal 1080i output, like my XBox360, then SCALE->NORM vs SCALE->PASS works as expected.
Clarence is offline
post #210 of 239 Old 03-18-2006, 03:06 PM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 10080
Clarence is offline
Closed Thread Video Processors
