Review of ABT102 Precision Deinterlacing Card for DVDO iScan VP30 - Page 15 - AVS Forum | Home Theater Discussions And Reviews
post #421 of 432 Old 11-04-2006, 05:38 AM
John P.'s Avatar
OK - thanks for the tip.
I just went through the passages in question again, and tried all the available deinterlacing options, and the moire didn't go away no matter which one I chose.
So I guess it's in the source then.
Isn't that a little... unprofessional though? Or is it hard to avoid sometimes?
All I want is perfection. Is that so much to ask?
John P. is offline
post #422 of 432 Old 11-04-2006, 09:18 AM
Josh Z's Avatar
Quoted: 2134 Post(s)
Liked: 1432
Originally Posted by John P. View Post
OK, I've just watched Mission Impossible III, PAL R2 (Norwegian).
Info screen on VP30 says input is 576i, and output is 1280x720p (1:1 native rate of my TV).
ABT102 card is set to Film Bias.
Several places on this DVD, there is moiré. First I noticed was the first shot from Rome; a brick wall on the left. Then at 45:01, there's a flight of stairs. Then a little later there's moiré on the airvents on the Lamborghini. Then later on there's moiré on the railings of a bridge.
There seems to be a strange encoding problem with all video copies of MI3. The NTSC DVD has the same issue. The HD DVD and Blu-ray do as well, though to a much lesser extent (the jitter is really only noticeable on the Vatican staircase).
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #423 of 432 Old 11-05-2006, 11:02 PM
vernonbc's Avatar
Hello all
I just finished watching MI3 on my DLP front projection system and this has to be the worst DVD I have ever seen. I have seen TV on DVD that looks better than this. There is moire throughout the movie and I have also noticed jitter and even some jaggies. I am actually considering returning it or giving it away.
I have played with the settings on the VP30 (ABT102) and no improvement. I find it hard to believe that they would let something like this make it to DVD.
I found it difficult to watch this movie without looking for all the flaws in the transfer and I don't consider myself to be a videophile.
If you are thinking of buying it.....DON'T......just rent it.
There, now that I got that off of my chest I feel a whole lot better.
vernonbc is offline
post #424 of 432 Old 04-23-2007, 10:57 AM
bobloblaw's Avatar
Hi all,
I'm curious if anyone has compared the performance of the VP30/ABT102 to the Silicon Optix ReonVX.
I'm considering an upgrade to Onkyo's TX-SR905 receiver when it's released later this year, if the ReonVX offers similar performance to my VP30/ABT102 (assuming the Reon implemented correctly), I could eliminate the DVDO solution to simplify my setup.
BDP-83 EAP (first 50)
bobloblaw is online now
post #425 of 432 Old 04-23-2007, 08:21 PM
Josh@dvdo's Avatar
The ReonVX can only handle 2:2 and 3:2 cadence detection.
The ABT102 can handle any cadence.
Josh Allen
DVDO Product Manager
Josh@DVDO.com
Josh@dvdo is offline
post #426 of 432 Old 04-24-2007, 06:48 AM
bobloblaw's Avatar
Thanks for chiming in Josh, that's definitely helpful.
post #427 of 432 Old 01-11-2008, 04:32 AM
Ludvig_S's Avatar
Originally Posted by bobloblaw View Post
Hi all,
Maybe a bit off topic, but I have evaluated the Onkyo TX-SR875 (which has the same ReonVX software as the NR905) to the Denon 3930 which carry the Silicon Optix Realta.
The Denon has slightly fewer scaling artifacts than the Onkyo. It also keep focus during object moving and pannÃ*ng scenes little better than the Onkyo. So if ABT102 is on par or better than the Silicon Optix Realta, don't expect the ReonVX based Onkyo to perform alike.
Ludvig_S is offline
post #428 of 432 Old 01-11-2008, 07:13 PM
eisenb11's Avatar
Quoted: 44 Post(s)
Liked: 33
I'm pretty sure the SO products are significantly better than the 102.
I've seen the output of an upscaled DVD being played on the Toshiba HD-AX2 (Reon VX) and it looks much better than what I have coming out of my VP30/102 combo.
eisenb11 is offline
post #429 of 432 Old 07-17-2008, 04:17 PM
jpnn80's Avatar
My VP30 with ABT102 has firmware 1.14, and when it receives an interlaced source, I can choose only between Auto, Film bias and video modes in the deinterlacing menu, whereas 2:2 Even, 2:2 Odd, Game Mode 1 and 2 are greyed.
Does it mean that the card is defective, or not properly installed? Or is this a firmware issue?
jpnn80 is offline
post #430 of 432 Old 07-17-2008, 08:43 PM
Josh@dvdo's Avatar
It sounds like the card is not properly seated on the header on the main video board.
Josh Allen
Josh@DVDO.com
post #431 of 432 Old 12-03-2013, 02:39 PM
Josh128's Avatar
Quoted: 259 Post(s)
Liked: 104
Does anyone know if the DVDO VP50 series has all the de-interlacing features of the ABT102 add on card built into the unit?  I'm assuming it does, as it does
contain game modes 1 & 2.
Displays: Samsung PN51F5300BFXA, PN51F4500AFXA, PN51F4500BFXA
Josh128 is offline
post #432 of 432 Old 12-04-2013, 05:07 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Fudoh is offline
Reply Video Processors
