My Flea is Hot! - AVS | Home Theater Discussions And Reviews
post #1 of 12 Old 01-02-2007, 08:22 PM - Thread Starter
mburnstein's Avatar
Literally! I had it connected for component HDTV before it went to HD Leeza. darn, I could barely touch it. I'm not using it now--not going to risk a fire! Anyone experience or hear of that with Algolith Flea, analogue version.
mark
Top Home Theater's I hope to see: The Bland's
Art's and my buddy Steve Bruzonsky! And Oneobgyn if I ever make it to NorCal!
mburnstein is offline
post #2 of 12 Old 01-02-2007, 08:38 PM
Simkins's Avatar
Yes, I had one for about a year, it runs VERY hot. According to Algolith this is not an issue.
Simkins is offline
post #3 of 12 Old 01-02-2007, 08:39 PM
vinodk's Avatar
Quoted: 32 Post(s)
Liked: 25
My Flea HDMI runs hot but not to the point where it is untouchable.
Vinod
vinodk is offline
post #4 of 12 Old 01-02-2007, 08:40 PM - Thread Starter
mburnstein's Avatar
Thanks for the response. Well, I may have squandered the $1000+ but I'm not keeping that thing plugged in. Maybe I'll connect it and when i watch TV, I'll plug it in??
Mark
mark
post #5 of 12 Old 01-02-2007, 08:53 PM
Simkins's Avatar
You could do that. Algolith has released a new firmware that allows the user to press the main button for three seconds that turns the unit off, instead of unpluging it. Firmware upgrade is on the Algolith site. The only "downside" to the upgrade is it does not allow the user to switch between DNR and MNR, but it does add a contrast enhancer.
Simkins is offline
post #6 of 12 Old 01-02-2007, 09:00 PM - Thread Starter
mburnstein's Avatar
Thanks for the tip!! If I reconnect it, I'll place it on the outside of my cabinet, more cool air!
mark
post #7 of 12 Old 01-02-2007, 09:16 PM
Simkins's Avatar
I once worried about the heat being an issue to, try not to worry about it, I eventually stopped touching it to see if it was hot / cold. Just enjoy the unit, its great.
Simkins is offline
post #8 of 12 Old 01-02-2007, 11:09 PM
bfdtv's Avatar
If you think the Flea is hot, you should touch some components found in many PCs. They can give you a second-degree burn, but even that isn't going to cause a fire. The heat on the Flea is nothing to worry about.
bfdtv is offline
post #9 of 12 Old 01-03-2007, 04:57 AM
ceenhad's Avatar
Liked: 24
The Flea has some very powerful processing going on inside it and the small package size makes it inevitable that it will run warm. The unit should never get so hot that you can't handle it though and if that is the case then you should talk to your dealer about a replacement.
HTH,
Neil
Neil Davidson - Visit my facebook page
ceenhad is online now
post #10 of 12 Old 01-03-2007, 05:35 AM
thebland's Avatar
Quoted: 520 Post(s)
Liked: 243
Does it have RS-232 control or are you using a IR remote that can use a macro to control it?
Mark,
How is the room coming?
My Home Theater of the Month- Le Petit Trianon
There are more than a handful of [op amps] that sound so good that most designers want to be using them as opposed to discreet transistors. Dave Reich, Theta 2009
thebland is offline
post #11 of 12 Old 01-03-2007, 09:16 AM - Thread Starter
mburnstein's Avatar
Mark,
Hi Jeff,
The stretch fabric wall with sound panels are going up. Waiting for the columns, ceiling treatment, crown moldings, and new sets of doors to be made/installed. See room pdf.
Happy New Year!
T-1 THEATER PLAN v2.pdf 163.8154296875k . file
mark
post #12 of 12 Old 01-04-2007, 04:05 PM
Huey's Avatar
Why not add an 120 mm PC fan (Yate Loon L series is quiet and moves decent air for a cheap solution--there are more expensive and more efficient 120 mm fans) hooked to the air intake vents using a 12v wallwart AC/DC converter?
Huey ;-]
Huey is offline
Reply Video Processors
