ABT VRS Precision Deinterlacing vs. Silicon Optics Realta with Terranex - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-30-2007, 05:43 PM - Thread Starter
Manchild's Avatar
Is there a consensus winner for best deinterlacer/video processor? If one likes the HQV chipset you can go with Algolith Dragonfly or Lumagen...whereas the ABT VRS is exclusive to the DVDO iScan line. I know lots of folks rant and rave about particular featuresets, but do either of the underlying chipsets have any advantage over the other in terms of raw performance?
Presumably all Realta chipset video scalers should be able to handle the HQV benches flawlessly...do the VPxx video processors?
Manchild is offline
post #2 of 15 Old 01-30-2007, 09:40 PM
Joelc's Avatar
Point of clarification...the new Lumagen RadianceXD will be based on the Gennum chip rathere than the Realta chip...and, to be more specific, it will be the Gennum 9450.
Joel
Some people choose to have a pool, I choose to have a home theater!
Joelc is offline
post #3 of 15 Old 01-30-2007, 11:51 PM
TomHuffman's Avatar
Quoted: 813 Post(s)
Liked: 707
The deinterlacing performance is very similar. The VP50 offers an enormous improvement in this regard from the previous generation of DVDO processors.
The DVDO solution is perhaps slightly better. The really profound difference is with noise reduction. The Realta-based Vantage-HD offers world class noise reduction and the VP50 has none.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #4 of 15 Old 02-04-2007, 04:31 AM
StooMonster's Avatar
Yes the VPxx ones do pass flawlessly on regular tests, but not the noise reduction one (as there is no noise reduction featureset).
StooMonster
StooMonster is offline
post #5 of 15 Old 02-04-2007, 07:27 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
Which performs better when watching film and video? In real life. No tests on those discs to test and judge scaling. Well, to me, the VP scaling is soft. It rings and that isn't as good if there were no ringing. i am trying to be political here.
mark haflich is offline
post #6 of 15 Old 02-04-2007, 08:53 AM
steviec's Avatar
StooMonster
For the best of both worlds try using the DVDo VP50 with the new tosh XA-2 player that has the realta noise reduction.
steviec is offline
post #7 of 15 Old 02-04-2007, 10:09 AM
Liked: 1012
Why? For HD discs the xa-2 outputs 1080p already. Do you mean with a standard DVD at 1080i? Noise reduce that and then send it to the VP50? Why? The film deinterlacing of both is equal. Really no real differences. Video is close but I think may be a little better with the VP50. But with 480i you have to scale with the VP50 "proven" to ring algs. The Realta scales with less ringing.
Why do you conclude this is the best of both worlds? It would appear to add NR to your chain but at the cost of scaling degradation.
post #8 of 15 Old 02-05-2007, 05:34 PM - Thread Starter
Manchild's Avatar
Seems like the best bet is to wait for the Lumagen...haha...why does all this stuff need to be so bloody expensive?! I might just rather get a 2nd FP!
Manchild is offline
post #9 of 15 Old 02-05-2007, 06:59 PM
Liked: 1012
All this stuff has gotten much cheaper over the years. Its life that has gotten more expensive.
post #10 of 15 Old 02-05-2007, 07:15 PM - Thread Starter
Manchild's Avatar
Or PQ obsessive-compulsive disorder...which I am unfortunately afflicted with.
Manchild is offline
post #11 of 15 Old 02-11-2007, 05:45 PM
Erik_Cdn's Avatar
Would using a Mosquito prior to sending the feed to the VP50 solve the NR problem???
Also, does anyone think that the Realta chip has more potential than the dvdo, but is just not being used properly by makers of realta based vp's...
Erik_Cdn is offline
post #12 of 15 Old 02-11-2007, 05:51 PM
Liked: 1012
Yes. But it won't help the ringing scaling in the VP50. I think based on scaling, the Realta does a better job. On film deinterlacing both are about equal. On video deinterlacing, the results depend on the tests employed.
post #13 of 15 Old 02-11-2007, 06:34 PM
Erik_Cdn's Avatar
the new xa-2 has the Reon HQV chip -- not the realta with Terranex architecture... this could impact performance (???)
Erik_Cdn is offline
post #14 of 15 Old 02-13-2007, 08:04 AM
rmlowz's Avatar
Hello,
I am going to get a video processor for my 12S4 is noise reduction a big feature ? Is it most beneficial with SD DVD?
rmlowz
rmlowz is offline
post #15 of 15 Old 02-25-2007, 01:47 AM
jeff_tyrrill's Avatar
One clear benefit from a VP50 and an XA2 is zooming in to widescreen, non-anamorphic DVDs. The XA2 does not have a letterboxed mode when upscaling. Then you get the benefit of the XA2's three types of noise reduction and detail enhancement, and part of the scaling benefit.
Another reason to use the VP50 is that the XA2 doesn't have 24p output yet (although this feature is expected in a firmware update).
jeff_tyrrill is offline
Reply Video Processors
