New DVDO iScan VP50PRO
________________________________________
This is the definitive spec sheet on the DVDO iScan VP50PRO:
The iScan™ VP50PRO is the world’s first video processor to be HDMI 1.3 enabled. The iScan VP50PRO converts standard definition, high definition and PC signals from your DVD player, HD-DVD player, Blu-Ray Disc player, HD DVR, game console, or PC to any output resolution up to 1080p.
The iScan VP50PRO incorporates several of Anchor Bay’s acclaimed Video Reference Series, VRS™, technologies including:
Mosquito Noise Reduction - Reduces random noise which appears along the edges of compressed images in SD and HD content
Fine Detail Enhancement – Extracts fine detail in low resolution or compressed SD or HD content
Edge Enhancement – Sharpens edges without adding ringing
Precision Deinterlacing™ – 480i/576i/1080i 10-bit Motion, Edge & Source Adaptive Deinterlacer
• Five-field motion adaptive deinterlacing
• Edge adaptive processing to produce smooth diagonal edges
• Three frame video processing delay (Max)
• Game Modes with very low latency (sub-1 frame delay, 2 frame delay with Edge adaptive processing)
• Arbitrary cadence detection (any:any) to detect non-standard cadences in input signals.
o Reliable 2:2 pull-down detection for 50Hz countries
o Detection of 2:2 to/from 3:2 crossfades and out of phase 3:2 crossfades
o Detection of multiple source types within a frame for example video titles over film
o Bad edit detection and compensation to minimize artifacts caused by sequence breaks in film content
PReP™ - Progressive ReProcessing of 480p, 576p and 1080p input signals allows poor deinterlacing of any source to be undone and done correctly using Precision Deinterlacing™.
Precision Video Scaling II™ -10-bit Scaling up to 1080p
Progressive Cadence Detection™ of 480p, 576p, 720p and 1080p input signals – Allows source-locked framerate output of film-based content (24/48/72Hz)
Rightrate™ – High-Performance Framerate Conversion which enables 24/48/72Hz or 25/50/75Hz output of film-based content. Outputs include 1080p-24 and 1080p-48.
Precision Gamma Correction™ - Individual R/G/B Adjustments
Precision A/V Lipsync™ - Intelligent digital audio delay technology to match Audio and Video timing
AutoVFR™ – Intelligent Component Video Inputs with Automatic Video Format Routing
AutoCUE-C™ – Automatic Chroma Upsampling Error detection and correction
• THX Video Certification - The World's First and Only Video Processor to earn this certification
• ISF ccc Day/Night Modes
• 4 HDMI 1.3 Inputs which process 480i/p, 576i/p, 720p-50/60, 1080i-50/60, 1080p-24/25/50/60, and VGA-SXGA@60Hz signals
• Analog HD Transcoding and Processing
Input Aspect Ratio Controls
•Presets: 4:3 full frame, 4:3 letterbox, Panorama (non-linear stretch), 16:9 full frame or user-defined aspect ratio (10)
•Flexible Horizontal and Vertical Zooming & Panning controls
•Overscan Adjustment per input
Output Aspect Ratio Controls
•Presets: 4:3, 16:9, 2.35:1 or custom output aspect ratio
•Separate Display/Lens/Screen Adjustments
•Underscan Adjustment to eliminate Overscan inherent in a display
•Panamorph Mode 1 and Mode 2 compliant
10 User-Defined 'Display Profiles' – For multiple display, framerate, and image shift configurations
•10-bit 300MHz Instrumentation Quality DACs (2x Oversampling for 1080p)
•Full-frame Timebase Correction
•High performance, multi-standard video decoder (10-bit: 480i/576i; 12-bit: 480p/576p/720p/1080i)
•High-quality super-adaptive comb filter with 2D Y/C separation
•Flexible Digital and Analog Audio switching and routing – 4 HDMI audio/video inputs, 5 assignable audio inputs (4 digital, 1 analog) with 1 HDMI audio/video output and 2 active digital audio outputs.
•Software Upgradeable
• Predefined output resolutions for Plasma, DLP, LCD, LCOS, and CRT-based displays:
480p (720x480)
576p (720x576)
720p (1280x720)
1080i (1920x1080)
1080p (1920x1080)
VGA (640x480)
SVGA (800x600)
XGA (1024x768)
SXGA (1280x1024)
848x600
852x480
1024x576
1024x1024 (ALIS)
1280x768
1280x960
1365x1024
1366x768
1365x768
1400x788
1400x1050
1440x960
1440x1152
• User customizable output resolution from 480p (720x480) to 1080p (1920x1080)
Technical Specifications
Inputs
Twelve Video Inputs Available
• Two Composite (NTSC/PAL/SECAM)
• Two S-Video (NTSC/PAL/SECAM)
• Two Component (YPbPr or RGB/S) processes 480i/p, 576i/p, 720p, 1080i
• One RGBHV/Component (BNC-style connectors) processes 480p, 576p, 720p, 1080i, VGA/SVGA/XGA/SXGA@60Hz
• Four HDMI 1.3 processes 480i/p, 576 i/p, 720p, 1080i, 1080p-50/60, VGA/SVGA/XGA/SXGA@60Hz
Nine Audio Inputs
• Four HDMI (HDMI v1.3)
• Two Coaxial Digital
• Two Optical Digital
• One Analog Pair (L/R)
Outputs
One Analog Video Output
• Using High Quality BNC-style connectors
• Configurable for YPbPr, RGBHV, RGB/S, or RGB
One Digital Audio/Video Output
• Using HDMI (High Definition Multimedia Interface) connector
• Configurable for YCbCr or RGB
• Also carries audio (HDMI v1.3)
Two Digital Audio Outputs
• One Coaxial Digital
• One Optical Digital
Controls
Front Panel
• Infrared remote control with direct access codes or manual controls on front panel
• Functions accessible via either On Screen Display (OSD) or 2 line, 20 character front-panel LED display
• RS232 port for software downloads and automation.
• Fully programmable controls for each separate video input with non-volatile memories:
- Automatic input source detection & input priority selection
- Picture controls with memory for each input: Fine Detail, Edge Enhancement, Brightness, Contrast, Saturation, Hue, Y/C Delay, CUE-Correction
• Output Controls: Analog/Digital, Format/Resolution, Aspect Ratio, Sync Type, Colorspace (RGB or YPbPr), Frame Lock, Display Profiles (10)
• 35 Built-in test patterns for ease of set up
Power
• Universal AC mains input: 100 – 240 VAC @ 50-60 Hz
• Consumption
480p (720x480)
576p (720x576)
720p (1280x720)
1080i (1920x1080)
1080p (1920x1080)
VGA (640x480)
SVGA (800x600)
XGA (1024x768)
SXGA (1280x1024)
848x600
852x480
1024x576
1024x1024 (ALIS)
1280x768
1280x960
1365x1024
1366x768
1365x768
1400x788
1400x1050
1440x960
1440x1152
Inputs
Nine Audio Inputs
Outputs
Controls
Front Panel
Power
• Consumption
