Denon Video Processor - Page 32 - AVS Forum | Home Theater Discussions And Reviews
post #931 of 956 Old 07-06-2011, 09:58 AM
imws's Avatar
I noticed above someone tried 1080p24 with sports and didn't like it. This is expected as sports are typicalmostly video and do not have a 24 frame per second cadence to process. If you stick to film based material when using 24P you won't be disappointed and the Denon 602 is super smooth and rickety solid with 24P.
imws is offline
post #932 of 956 Old 07-08-2011, 01:04 AM
lsarver's Avatar
Uh . . . sure you mean to say "rickety"?
lsarver is offline
post #933 of 956 Old 07-13-2011, 08:59 PM
imws's Avatar
I meant to say rock solid as in very smooth and stable cadence like what you would see in a theater. The typos are courtesy of a Samsung Droid Charge and its awful keyboard, which miss-interprets what I type and corrects incorrectly most of the time.
imws is offline
post #934 of 956 Old 07-14-2011, 02:28 AM
lsarver's Avatar
You darn yooting ah ment rickety as in rockety soolid... Yiu know rockey rickey sokid... ah hopes its ckear to yius now
OK, Cletus, got it.
lsarver is offline
post #935 of 956 Old 07-15-2011, 08:25 AM
imws's Avatar
Sorry
imws is offline
post #936 of 956 Old 07-24-2011, 08:36 PM
mfogarty5's Avatar
Quoted: 61 Post(s)
Liked: 48
The other day I turned on my tv, Cisco cable box and Denon 602CI, but no picture was displayed on the tv. I looked at the display on the front of the Denon and it showed 1080i --> 576p. I thought to myself how did it get set to output 576p? I looked in the manual and it said if this happens to make sure the unit is set to NTSC, not PAL. My unit was set to NTSC.
So I called Denon. They thought it might be HDMI related so they asked me to unconnect the Denon, the Cisco cable box and the tv(which is on the wall), power them off for 10 minutes and reconnect them. If that didn't work, then call them back.
It didn't work.
So I called them again and they walked me through how to perform a hard reset on the unit(I think I held the Setup and Return buttons on the front of the unit simultaneously until all the lights on the front panel blinked).
The hard reset didn't work either.
I disconnected the cable box from the Denon so there were no inputs into the Denon, only an HDMI cable from the Denon to my Sony XBR5 tv. The on screen gui should appear on the Sony when there are no inputs, correct?
Does anyone have any suggestions short of sending my unit to Denon? I purchased mine through the AVS buy last year and have enjoyed the picture improvement to my bit starved Time Warner Cable signal so any advice forum members can provide is appreciated.
EDIT: Right before I posted this message, I tried connecting my Denon directly to the tv one last time. The on screen gui still didn't appear, but I decided to power off the unit and try HDMI output/monitor 2 and guess what?!? The onscreen gui appeared! I guess HDMI output/monitor 1 on my unit went bad.
I will call Denon tomorrow to confirm, but I have a feeling my unit is going in for repair.
mfogarty5 is offline
post #937 of 956 Old 07-28-2011, 11:39 AM
Murilo's Avatar
Quoted: 126 Post(s)
Liked: 30
My hdmi outputs oddly went bad, but its just 4,5,6, Hdmi out 1 and 2, and hdmi 1,2,3, still work.
Since thats all i was using i declinded to pay shipping and go without.
Murilo is offline
post #938 of 956 Old 08-05-2011, 02:33 PM
ashwinbrao's Avatar
I seem to be having a weird problem with my denon 602. When watching standard definition programs, I notice a lot of clay-facing and image streaking. This issue does not arise while watching high definition pictures. When I switched the 602 with the edge, the problem disappears (which suggests that the issue is with the denon).
Has anyone else had this problem? Any suggestions on dealing with this problem would be appreciated
ashwinbrao is offline
post #939 of 956 Old 08-06-2011, 07:05 AM
EWL5's Avatar
What were you watching? Could be the source material.
Pioneer broke my heart.
Denon broke my wallet.
Oppo broke my thinking.
EWL5 is offline
post #940 of 956 Old 08-06-2011, 09:23 PM
ashwinbrao's Avatar
It happens when I watch dish network. The problem persists across all SD channels
post #941 of 956 Old 08-07-2011, 11:20 PM
lsarver's Avatar
. . . The problem persists across all SD channels
So stop watching SD channels. . . .
(Sorry: couldn't resist. But we quit watching SDTV. DVDs are another matter. . . )
You really haven't provided enough information:
1. Do you have the same material going through the two processors? (For example, it is recorded?) How do DVDs look?
2. Do you have comparable input and output settings on the two processors?
lsarver is offline
post #942 of 956 Old 08-08-2011, 06:30 PM
ashwinbrao's Avatar
lsarver:
The problem only shows up on the denon (the same material when passed through the edge does not show streaking). Changing output on the denon from 720 to 1080 or vice versa does not result in any visible improvement. The same is true regarding noise reduction settings (the problem persists at all noise reduction settings).
I have not seen a sd-dvd for ages, but sd-video from roku seemed to be fine. Most of the problems seem to arise while watching south asian channels (I watch the remaining channels in HD)
Its hard to compare the input and output settings of the two processors. I have matched the output resolution and color space while the input video comes in at 480i and 4:2:2
post #943 of 956 Old 08-08-2011, 07:30 PM
EWL5's Avatar
lsarver:
The content wouldn't by any chance be anime? Perhaps the odd cadences are giving the Realta fits? Are you getting combing?
EWL5 is offline
post #944 of 956 Old 08-09-2011, 05:05 PM
lsarver's Avatar
Good point! ABT processors are supossed to be especially adept with odd cadences.
lsarver is offline
post #945 of 956 Old 08-11-2011, 05:02 PM
ashwinbrao's Avatar
The programming is not Anime. Its mostly bollywood movies. The broadcast standard in India is PAL. Could the problem be related to the the PAL to NTSC conversion required for the US broadcast?
post #946 of 956 Old 08-11-2011, 07:58 PM
cpcat's Avatar
Yes, very likely.
cpcat is offline
post #947 of 956 Old 04-01-2012, 04:30 PM
musk771's Avatar
Hi everyone,
I am looking for a Denon DVP-602ci processor, of course in perfect condition, anyone have it for sale? I live in Italy but I'm available to receive from everywhere
Contact me if you have one to sell
musk771 is offline
post #948 of 956 Old 04-08-2012, 12:45 PM
imws's Avatar
I bought two back in 2010 from Jason at AVS and they are still amazing to my eyes.... The build quality is just amazing and hope they will last a good long time. The PQ is amazing...My previous VP left a lot to be desired in terms of build quality and reliability. I'll never go down that route again.
imws is offline
post #949 of 956 Old 06-11-2012, 12:53 PM
JackB's Avatar
Quoted: 478 Post(s)
Liked: 76
Hope there are 602 owners still subscribed to this thread. I am having a problem where my 602 drops the Optical 1 audio connection when changing from HDMI 1 to Component 1 and back. Basically, I am using Optical 1 for both my Directv HDMI input and my Directv Component input. I'm doing this because my JVC RS40 projector hooked to HDMI 1 was having handshake problems so the factory tech suggested bypassing the 602 to see if that made any difference. It did. No more handshake issues. However, by doing this I have to use the component out of the Directv receiver for my second TV in the room and this seems to create the audio setting change in the Denon. My audio receiver is non-HDMI so I have to use optical for all audio and the 602 seems to have a problem sharing Optical 1 simultaneously or in sequence between the two different inputs, HDMI 1 and Component 1. When I go into setup after switching back to either input I must go to Source Select/HDMI1/Optical and select Optical1 as the setting had reverted to None after having switched from HDMI to Component. There must be a way to lock these in to prevent this. Any knowledge or experience here?
Sorry for the messy explanation. There is probably a simple method that I am missing.
Jack
JackB is offline
post #950 of 956 Old 06-11-2012, 05:47 PM
sfm
sfm's Avatar
Quoted: 27 Post(s)
Liked: 44
Unfortunately you're out of luck (best I can tell from messing with my 602)... The Denon is another in a long line of brain dead dumb vp/avr firmware implementations that restricts an audio (and/or video) connection to be assigned to one and only one configurable input. With the Denon, if you pick an optical audio for a video input and the same optical audio input is already picked for another video input it will set the other video inputs audio selection to none (i.e. it will not allow you to assign, for example, optical one to both component 1 and component 2).
Amazing to me that in this day and age these silly restrictions are still enforced by most AVR/VP implementations (granted, it maybe due to hardware constraints/implementations in some boxes but I'm guessing for most the restriction was simply a poor software/firmware implementation choice).
sfm is offline
post #951 of 956 Old 06-11-2012, 05:55 PM
JackB's Avatar
Quoted: 478 Post(s)
Liked: 76
Thanks for the reply. I was afraid of that. Guess I will have to live with the handshake problem on my projector. Will be dropping it off at JVC on Wednesday to see if they can impact handshaking with EC or firmware change.
Jack
JackB is offline
post #952 of 956 Old 06-11-2012, 06:26 PM
HDgaming42's Avatar
Quoted: 163 Post(s)
Originally Posted by musk771 View Post
Hi everyone,
For anyone who hasn't dealt with the Italian post office--they are notorious for losing items. And your recourse--even with insurance--is next to zero. Just something to consider when doing business abroad.
HDgaming42 is offline
post #953 of 956 Old 08-29-2012, 11:26 PM
RonF's Avatar
Quoted: 257 Post(s)
Liked: 258
How does the excellent noise reduction (with virtually invisible negative effects) on the 602ci compare to what the Lumagen Mini 3D gives you in that area? I may ultimately go to the latter with the auto cal Chromapure bundle. But I would hate to lose the Denon's NR if the Mini is not as good, for cable when needed. Guess I could keep it in line as a switcher feeding the Lumagen.
RonF is offline
post #954 of 956 Old 01-29-2015, 06:42 PM
JackB's Avatar
Quoted: 478 Post(s)
Liked: 76
New problem with my 602 that I hope someone has had experience with. I have a Sony BR player that is connected to an Onkyo receiver that passes monitor output to 602 that then passes video to JVC projector. Problem is this. 602 passes video from BR disc playing movie but not from Sony menu system. So if I want to change my settings or watch Netflix I get nothing. The same thing happens when I use my Sony PS3. I have a Directv AVR also connected via the same chain and it has no problems. I have switched input HDMI connections on the Onkyo and get the same results. It seems like the Sony devices send out different signal strengths for the disc versus the menu system.
Any ideas or similar experiences?
Jack
JackB is offline
post #955 of 956 Old 01-29-2015, 09:06 PM
uderman's Avatar
Quoted: 91 Post(s)
Liked: 44
Bd films are in 1080p24 that is 24 frames a sec. Menus, netflix etc are generally upscaled to 1080p60. It almost sound like one of your gear in this chain doesn't like 1080p60 which is higher bandwidth than 24. This doesn't mean they don't support it. It could be just one of the devices incorrectly introducing itself not 1080p60 capable. When you have multiple hdmi devices hooked up in chain, they read each others edid info and arrange themself for the least capable of them.
uderman is offline
post #956 of 956 Old 01-29-2015, 09:13 PM
uderman's Avatar
Quoted: 91 Post(s)
Liked: 44
I have the lumagen radiance 2144. I also have a yamaha receiver with hqv vida which has a newer version of noise reduction found in hqv realta in the denon unit(realta has more processing power so it might still be better). I also have the king of all noise reduction, algolith mosquito hdmi.
Lumagen allows more tweaks. I apply much more subtle noise reduction. There is no loss of detail or any artifacts introduced. Mosquito noise is eliminated. Very subtle random noise removed. Hqv vida at even lowest settings is too aggressive for me. Mnr is good but dnr definitely removes detail even at low. Algolith has the mist tweak. Excellent in all cases plus it can process analog video noise too. Lumagen is a close second on digital noise reduction.
uderman is offline
Reply Video Processors
