On ear headphones for $60> - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-14-2008, 03:55 PM - Thread Starter
InvaderKimimaro's Avatar
Mainly used for listening to punk rock and nu-metal.
Which are the best to get?
InvaderKimimaro is offline
post #2 of 2 Old 10-14-2008, 04:28 PM
CADOBHuK's Avatar
Search ebay for m-audio q40..the best price should be the one at $75 .. a bit over your budget, but worth it for sure, they are one of the best under $200 in sound quality and build quality, and much better than anything else under $100.
CADOBHuK is offline
Reply Headphones
