Wiring headphone speakers to 3.5mm audio jack - AVS Forum | Home Theater Discussions And Reviews
Old 08-22-2009, 04:40 AM - Thread Starter
petermack56's Avatar
Need some assistance, is it possible to wire two small headphone speakers directly to a 3.5mm stereo audio jack that will be connected to an ipod? Can I wrap the two neg. (ground) leads together and attached the left & right speaker leads to their respective pins on a 3 pin jack?
petermack56 is offline
Old 08-22-2009, 12:06 PM
BowerR64's Avatar
This is tricky because most headphone cables they try to keep the wire small and flexable but still keep them seperated so they dont short. So what they do is epoxy cote the wires. Usualy they are red and green when you strip away the outside coating. You cant really solder or get any kind of a good connection because of the colored epoxy. What you have to do is use an asprin, usualy somthing like the cheap $1. store asprin or the old round white pill bayer. Sit the wire on the asprin and thin sit your soldering iron on the wire and asprin. The asprin etches away the epoxy some how and exsposes just the wire it can also tin the wire at the same time if your tip has a little solder left on it.
It works good, then you can do any repairs you want.
The plug types im not sure about i just know you my run into problems with connections unless you etch the colored epoxy off the wires.
Originally Posted by donsantos
How can you tell a point is a reflection point?
Originally Posted by maxcooper
sit in normal spot
have friend slide mirror on wall
see speaker? bingo!-Max
BowerR64 is offline
Old 08-22-2009, 05:46 PM - Thread Starter
Thanks for the reply, I will etch wire ends as you suggest. Can I wire these two speakers directly to the audio jack or do I need to provide an amp or external power supply for the speakers.
Old 08-22-2009, 09:44 PM
jettore's Avatar
What exactly are you trying to do? What do you have now on the headphones? Just a bare cable? What headphones do you have?
That questions makes me think you are trying to do more than just repair a connector or cable on a pair of headphones.
jettore is offline
Old 08-22-2009, 10:48 PM
Local399's Avatar
Use an adapter.
Local399 is offline
Old 08-23-2009, 02:19 AM
maxcooper's Avatar
Quoted: 13 Post(s)
Yes. Fortunately, this arrangement comes pre-made in nearly endless variety at very good prices. Procuring such devices is known as "buying headphones".
Clearly you are trying to do something else. What are you trying to do?
If you want to hear it from more than a few inches away, headphone speakers won't be loud enough. You'll need different speakers and an amplifier of some kind. Cheap powered computer speakers would work and are cheap, but generally don't sound very good for music (though may still be fine depending on what you are trying to do).
-Max
maxcooper is offline
Old 08-23-2009, 06:16 AM - Thread Starter
I am trying to retro fit a pair of Peltor ear protection headphones, that have speakers in place from an am/fm radio that never worked well. I make/restore furniture and need to protect my ears from shop noise. So, that is why I'd like to see if there is a simple way to add an audio jack to the head set and connect to the speakers that came with the headset. I'd like to be able to connect an ipod to the headset.
Old 08-23-2009, 08:03 AM
jettore's Avatar
Ok, I think I understand now. You have something like this.
http://www.amazon.com/Peltor-90541-W.../dp/B0013092CS
You want to add an aux in basically, so you can plug another source into the headphones. It may work, but it might not be load enough. There is a small amplifier used for the AM/FM radio. If you could figure out how to add the aux in before the amplifier it would sound fine, but that may be difficult. If you wire the speakers directly to the IPOD, it may not have enough power. A headphone amp or a headphone out from a receiver may solve the problem.
I'd say it's one of those project of trial and error, unless you can find someone else that has tried it. Good luck.
jettore is offline
Old 08-23-2009, 08:06 AM
jettore's Avatar
Could you just wear ear buds for the IPOD under the headphones? Might save a lot of trouble.
jettore is offline
Old 08-29-2009, 11:53 PM
BowerR64's Avatar
Some people dont like pushing things in their ears and alot of the ear buds dont fit some users.
Ive modified peltor ear muffs for speakers and they didnt really sound all that great. I think i used the wrong type of driver. The driver i used sounded better with an open back, once in the peltor they were like a sealed bass cabnet or somthing and they lost all their bass.
sit in normal spot
BowerR64 is offline
