Hey Everyone,
I'm looking for a high quality headset that I can use both for work as well as decent quality audio for listening to music. I will want to use it with both my PC and my cell phone. I am willing to pay some big bucks for a solution that works for me, since it would be playing double-duty.
Must-haves:
1. Bluetooth - Need to connect to both the PC and to my cell phone.
2. Over-the-ear full cushions. High quality audio.
3. Microphone - Hopefully a boom with higher quality noise cancelling mic. I will be using for Skype/Webex type conference calls.
4. Minimum battery life should be at least 8 hours.
5. Very comfortable and lightweight. Will need to wear for several hours at a time.
Want-to-have, but I could live without:
1. Noise cancelling sound. Preferably with ability to switch on and off.
2. Ability to use 3.5mm jack and/or USB. So when battery runs low I can simply connect cable to charge.
3. It would be nice if it folded flat so I could stick it in my backpack.
4. Audio playback controls on headset.
5. Controls to Answer/end phone call from cell
I'm very excited to hear what some of you might suggest! I just hope that I can find something that works for me. I have been using a Plantronics Rig 500 wired gaming headset for some time now...and I am ready to cut the cord and upgrade the sound. So thanks again for any suggestions!
Must-haves:
