Popcorn Hour DVD Menus Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-18-2008, 08:04 PM - Thread Starter
naggeneen's Avatar
Hey Folks!
After everything I'd read about the popcorn hour here on the forums, I put myself on the waiting list... and finally just had it arrive today.
I've now spent the past few hours playing with it. I don't seem to have any problems with pulling DVD rips from my Infrant NV+ using NFS and UPNP AV (I have my movies ripped in normal, uncompressed Video_TS folders (with .VOB and .IFO files))
But popcorn hour doesn't seem to want to play the DVD menus. I assume that it's just not recognizing or somehow seeing the .IFO files?
I've tried to convert one of the folders to an .ISO file... but popcorn hour just seems to open the .ISO to display the titles which can be played... nothing that would indicate how I should be doing things to see the DVD Menus.
Everything works just fine when I run "My Movies" on my PC (which is how these discs were ripped - with Slysoft's AnyDVD running to remove encryption).
Any help would be appreciated!
- Naggeneen
Sincerely,
Naggeneen
2.0.1 GOLD on Philips 14hr (native) and Sony 30hr (native)
TiVo subscriber since 8/99 (pre-IPO!)
naggeneen is offline
post #2 of 6 Old 04-19-2008, 03:53 AM
Hi-Jack's Avatar
Are you using UPnP or NFS? There is no way you can use UPnP over NFS and the like... From the PCH, create a SMB or NFS connection to the folder containing the ISO and DVD files and it will work. Using UPnP will only allow what UPnP can support and that excludes parsing dvd menus...
enjoy
Enjoy
Hi-Jack
www.mpcclub.com
Things can be interpreted in two ways - positively or exactly as it is!
You decide which leads to the real truth!
Hi-Jack is offline
post #3 of 6 Old 04-19-2008, 10:43 PM - Thread Starter
naggeneen's Avatar
Hey Hi-Jack,
Thanks for the advice. I found an article about setting a NFS (instead of SMB) connection in the popcorn hour menu over at the MPC Club site. Everything seems to be working perfectly now!
Thanks again!
- Brendan
Sincerely,
Naggeneen
post #4 of 6 Old 04-20-2008, 12:58 AM
Hi-Jack's Avatar
Should work with SMB just as good...
I still believe you was trying to make it work using UPnP :-)
Enjoy
Hi-Jack
www.mpcclub.com
Hi-Jack is offline
post #5 of 6 Old 05-09-2008, 04:59 PM
t3knokat's Avatar
Well, I still can't play EITHER IFO or ISO off SMB.
t3knokat is offline
post #6 of 6 Old 05-13-2008, 05:01 AM
rogmesser's Avatar
I've setup both NFS and SMB shares and have been able to play ISO and VIDEO_TS/ripped dvd's from both types of shares. It can be tricky sometimes setting up that SMB share, (If its a windows box, make sure the Guest account has the "Access this computer from the network" rights, Guest account not disabled, Guest account has rights to the share and to the folder files, etc, etc...)
rogmesser is offline
