*New* Western Digital - WD TV HD Media Player - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 9960 Old 11-03-2008, 02:23 PM
SuperUser's Avatar
No subtitles for VOBs. Looks like it will ignore all and any additional data included in DVD stream. It will just play VOB end to end. It will however allow you to select different audio tracks. It supposed to support "Subtitle- SRT (UTF-8)".
More specs: wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=2697
Display Resolution: It will output in selected format only, no matter what source material is.
In "Auto" mode resolution will match HDMI display data channel. In my case when set to auto it will output 768P even when there is no such thing in the menu.
Cheers!
SuperUser is offline
post #92 of 9960 Old 11-03-2008, 02:42 PM
ChayesFSS's Avatar
bought the last one at the BB!
ChayesFSS is offline
post #93 of 9960 Old 11-03-2008, 02:50 PM
yzheng25's Avatar
I just tested out the WD TV HD Media Player, and ti can play the following format:
1. File recorded by Panasonic HD camcorder (HDC-SD1) in .m2ts format (1080i)
2. File recorded by Sony HD camcorder (1080i)
3. File recorded by Hauppauge HD PVR (720p and 1080i). But need to rename the file extension from .ts to .m2ts
4. File in .MKV (720p) downloaded from web
5. File in WMVHD (720p and 1080i)
Very happy with it
yzheng25 is offline
post #94 of 9960 Old 11-03-2008, 03:03 PM
sandun's Avatar
Does anyone know if this device can output PAL (e.g for HD plasma/lcd displays based in UK, Australia). (or is it irrelevant when using HDMI?)
- Sandun.
sandun is offline
post #95 of 9960 Old 11-03-2008, 03:27 PM
Mario66's Avatar
When playing on my projector 92" the Mkv's etc all fit incorrectly an inch missing on each side a couple inches etc, seems if I magnify the image to x2, then go back to the normal x1 size it fits the screen correctly.
Anyone else have this issue. Rather annoying I have to magnify the image to x2 then go back for it to fit properly.
Picked it up tonight plugged in the Hdrive and off it went no issues besides getting it to fit the screen correctly. THis beats the C**P out of transcoding/encoding etc for Xbox360 Tversity.
Mario66 is offline
post #96 of 9960 Old 11-03-2008, 04:21 PM
ChayesFSS's Avatar
DAMN, I'm in love!!! Nice optical out, throwing every mkv file I'm throwing at it!!!!!!!!
post #97 of 9960 Old 11-03-2008, 04:22 PM
eteled's Avatar
User Guide for WD HD Media Player
eteled is offline
post #98 of 9960 Old 11-03-2008, 04:23 PM
salado's Avatar
Well, no RMVB support either...
salado is offline
post #99 of 9960 Old 11-03-2008, 04:24 PM
Mario66's Avatar
Still having the screen issues it played one wmv I had but not the other 2. Strange Mkv's no problem.
I seem to have to switch between normal/widescreen and do the magnify and back to normal each time.
Mario66 is offline
post #100 of 9960 Old 11-03-2008, 04:25 PM
eteled's Avatar
Sorry, system requires 3 messages from me to put a download link. This is #3. Next will be a link.
eteled is offline
post #101 of 9960 Old 11-03-2008, 04:27 PM
eteled's Avatar
OK, here it is
User Guide for WD HD Media Player.
eteled is offline
post #102 of 9960 Old 11-03-2008, 04:28 PM
ChayesFSS's Avatar
Yea, I'm having problems with Kung.Fu.Panda.NLsubs.WVC1.1080p-VisualScumBagz.wmv but it's just one file so far, I can look for a different format
post #103 of 9960 Old 11-03-2008, 04:31 PM
ChayesFSS's Avatar
Originally Posted by eteled View Post
OK, here it is
thanks
post #104 of 9960 Old 11-03-2008, 04:56 PM
djbrettb's Avatar
It DOES support DTS passthrough! Just tested it with both a 1080p file and a regular DVD rip.
djbrettb is offline
post #105 of 9960 Old 11-03-2008, 04:57 PM
djbrettb's Avatar
Also, tested it with a short 1080p 15mbit x264 file. Video played smoothly, but the audio kept cutting out. HOWEVER, not sure if this is because I was playing it from a flash drive or not. I'll get the file to a hard drive and re-test it.
djbrettb is offline
post #106 of 9960 Old 11-03-2008, 05:18 PM
djbrettb's Avatar
I am completely stunned. Just played a .m2ts file ripped straight from Blu Ray (I, Robot to be exact). Switched audio streams flawlessly. DTS working and Dolby Digital working. This movie is AVC encoded at a VERY high bitrate, and this thing played it without a problem. I am truly amazed.
djbrettb is offline
post #107 of 9960 Old 11-03-2008, 05:39 PM
nownot's Avatar
just hooked this up and here are some things
1) 1080p mkv from hfs+ partition is unwatchable, artifacting (<- spelling) all over, going to try 1080p mkv ntfs in the next few hours.
2) im using optical and i got dts and dd from spdif
3) will not play blu ray backups that have been converted to iso has to be .m2ts files. this sucks b/c i have backed up my collection but if i want to watch on this i have to un-iso them.
4) have a back up (superbad) with single hd audio stream, it will not play it b/c it cant down convert like powerdvd.
so far not to impressed with it, the mkv off hfs+ sucks, but if it works on ntfs oh well. and the non iso playback is going to probably make me return this unfourtinally.
p.s. this is probably a duh but i tried to hook up my external blu ray but its said unrecognizable usb device, so that is a no go .
nownot is offline
post #108 of 9960 Old 11-03-2008, 06:09 PM
Mario66's Avatar
Is there a harmony remote code for this? Probably a dum question it's in the harmony software but doest turn the media player on or off, nor could I get it to learn the code.
nevermind works now
Mario66 is offline
post #109 of 9960 Old 11-03-2008, 06:23 PM
blimey's Avatar
There are several confirmations of DVD (ISO/IFO/VOB), but does it just play the video, or does it also fully support DVD menus? And if so, does chapter skip/rev work for DVD sources?
blimey is offline
post #110 of 9960 Old 11-03-2008, 06:42 PM
Bill's Avatar
Quoted: 90 Post(s)
Liked: 54
Does it output 1080i HDMI and audio out from the RCAs at the same time? I have a TV with DVI in.
Bill is offline
post #111 of 9960 Old 11-03-2008, 06:46 PM
ChayesFSS's Avatar
Not sure but I'm using optical out and it's working great, very nice
post #112 of 9960 Old 11-03-2008, 08:03 PM
BobSalita's Avatar
Location: CHI, CLD, PAR, PHX, PDX, NKC, AUK, MEL, SYD, BUE, SCL
bitstream through hdmi? 5.1, 7.1, hd audio formats?
Former Top 1000 Amazon reviewer bemoaning the loss of objective user reviews. Amazon, stop your complacency!
BobSalita is offline
post #113 of 9960 Old 11-03-2008, 08:34 PM
djbrettb's Avatar
I just wrote a (somewhat) detailed review here:
http://maddhat.com/?p=31
More pictures to come later.
djbrettb is offline
post #114 of 9960 Old 11-03-2008, 08:46 PM
Mario66's Avatar
Is there an easy way to add DVD Art to my Mkv's etc?
Mario66 is offline
post #115 of 9960 Old 11-03-2008, 11:14 PM
M-Desantos's Avatar
anyone have a USB hub and a couple of external drives?
I want to know what happens if you hook up more than one drive.
M-Desantos is offline
post #116 of 9960 Old 11-03-2008, 11:45 PM
oldpainless68's Avatar
I know why they did it, but the lack of a lan connection kills it for me. However, it's telling when a big name like WD throws it's hit in the media player ring.
K
oldpainless68 is offline
post #117 of 9960 Old 11-03-2008, 11:58 PM
I'd be interested to hear if it works via a usb hub, at least that would kinda solve one issue.
K
post #118 of 9960 Old 11-04-2008, 12:18 AM
blimey's Avatar
K
I was at least slightly shocked that WD released this product. WD released those 'book' network drives that restricted access to media files based on file extension, out of fear of contributing to copyright infringement. And now they release this thing, which is arguably a bit-torrenter's wet dream.
The lack of network connectivity is no issue to me. I understand why some like it, but I don't see the sense in leaving a computer running all the time to essentially serve as a dumb drive for a player in another room.
Isn't there anyway to sort of made a kludge network for this thing by networking a nas drive that is connected to the wdtv? If playback compatibility is as good as it appears to be, people will probably come up with something to get around sneaker networking.
blimey is offline
post #119 of 9960 Old 11-04-2008, 12:30 AM
pastishe's Avatar
Looks neat, seems a few things aren't 100% cleared up though
1 - DVD menus?
2 - high bitrate (15mb/s) mkv's ok?
3 - internally decode dts streams
4 - subtitles in DVD's
5 - subtitles in MKV's
6 - Thumbnail view - Will it pick up folder.jpg art (or cover.jpg) for music and for movies
7 - Thumbnail view - Will views stick for certain directories e.g. music directory I want thumbnail view and for music directory I want list?
pastishe is offline
post #120 of 9960 Old 11-04-2008, 12:34 AM
djbrettb's Avatar
1 - DVD menus?
5 - subtitles in mkv's
DVD menus, AFAIK, do not work.
It plays 15mbps MKV x264 files just fine. It also plays 30mbit AVC Blu-Ray M2TS files just fine.
I don't know if it can internally decode DTS, but it does do passthrough. Why would you want to internally decode anyway?
Subtitles in DVDs are reported to not work.
I haven't tested subtitles in MKVs.
djbrettb is offline
