"WD TV" Cover Art for *.AVI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-15-2008, 06:25 PM - Thread Starter
chrislemay's Avatar
Has anyone out there who owns a Western Digital "WD TV" figured out how to make it display cover art for .AVI's ?
They keep touting it as a great feature, but I've tried many different ways.
Any help will be greatly appreciated.
PEACE
chrislemay is offline
post #2 of 11 Old 11-15-2008, 07:38 PM
CDLehner's Avatar
Quoted: 771 Post(s)
Liked: 1147
PEACE
I know you're new, but you should post this in the already established WDTV master thread here http://www.avsforum.com/avs-vb/showthread.php?t=1080840 . Good luck.
CD
CDLehner is offline
post #3 of 11 Old 11-16-2008, 09:31 AM - Thread Starter
chrislemay's Avatar
I know I'm new too, but I've been following that original post, which is now 15 pages long.
Several people have asked the same question within that post.
I just didn't want the question to get lost in the shuffle.
PEACE
post #4 of 11 Old 11-16-2008, 09:57 AM
CDLehner's Avatar
Quoted: 771 Post(s)
Liked: 1147
PEACE
Well...is cover art embedded in your file? Or does WDTV use a db?
CD
CDLehner is offline
post #5 of 11 Old 11-17-2008, 08:41 AM
bpmarkowitz's Avatar
Appendix p. 69 of the manual lists thumbnail support. AVI is not one of the video formats which supports thumbs. The only luck I have had is importing mpeg4s into iTunes and adding cover art there. This will show on the WD TV HD. Hopefully they will come up with a solution for AVIs and MKVs.
bpmarkowitz is offline
post #6 of 11 Old 11-17-2008, 03:58 PM - Thread Starter
chrislemay's Avatar
Thanks bp.
I guess all I can do is hope they include the ability to show JPGs as thumbnails in a future firmware update.
I have taken the time to get all the cover art and name it the same as the AVIs.
Here's the awesome site I used, in case it can be of value to anyone else.
www movieposterdb com
PEACE
post #7 of 11 Old 03-08-2009, 01:02 PM
utjackal's Avatar
In other players I've been able to just put the .avi/.mkv into a folder, and then put folder.jpg in there with it and then see the higher level folders with the cover art. It seems this doesn't work for WDTV. Anyone figure out a way around this yet?
utjackal is offline
post #8 of 11 Old 01-25-2010, 02:59 AM
lewis_jsy's Avatar
Hi chrislemay,
I asked a friend of mine who's a developer to write an app that looks at all the movies in a folder then creates the movie art with the same file name jpg's, for my WD Media player.
He successfully created it and it works like a charm , you can find it here, hope this helps:
w w w .seesharpdot.net/?p=199
Cheers,
Lewis_jsy
lewis_jsy is offline
post #9 of 11 Old 01-25-2010, 05:02 AM
eiker_ir's Avatar
mmm i have hundred of .avi files and the thumbnails work perfectly, haven't had a problem with them ever
eiker_ir is offline
post #10 of 11 Old 01-25-2010, 09:41 AM
mr_jbloggs's Avatar
Here are some others posted in the main WDTV Live thread :
http://thumbgen.blogspot.com/ - Thumbgen
http://wdtvforum.com/main/index.php?topic=3613.0 - WDTV ImageGrabber
http://www.danhinsley.com/MetaX.htm - MetaX
mr_jbloggs is offline
post #11 of 11 Old 01-25-2010, 09:46 AM
milhousen's Avatar
Here's good program to add thumbs to your library:
http://ipod-sync.com/wdtvtn/
milhousen is offline
