Firmware - Western Digital - WD TV HD Media Player - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 2569 Old 02-02-2009, 06:11 PM
mvallevand's Avatar
linuxjacques, have you tried any iperf testing with the USB wired ethernet? I am not expecting high throughput on the SMB8634 but it would be nice to be surprised.
Martin
mvallevand is offline
post #92 of 2569 Old 02-03-2009, 12:30 AM
CuE_'s Avatar
Great job guys!
The Spanish Community is expectant of what you can achieve with your work. We hope you will do it a better product
CuE_ is offline
post #93 of 2569 Old 02-03-2009, 10:13 AM
linuxjacques's Avatar
Martin
It's on my todo list but I haven't had as much free time lately as I thought.
linuxjacques is offline
post #94 of 2569 Old 02-03-2009, 10:16 AM
ayasystems's Avatar
Originally Posted by CuE_ View Post
Great job guys!
Yes!!
Regards from spain!
ayasystems is offline
post #95 of 2569 Old 02-03-2009, 10:17 AM
Originally Posted by linuxjacques View Post
I'm happy to provide anything I have - I just need a place to put it.
The important things to build working modules are:
1) toolchain - I have tried the toolchain included in the latest WD GPL file
and a toolchain I built with buildroot and they create identical modules.
The buildroot config file might be useful.
2) kernel config file - I derived one through trial and error. I'm sure many
other people can do the same, but this might save some time.
I'd like to see WD release the "real" kernel config file.
I've uploaded a small tarball containing my kernel config file, buildroot config file,
and very simple kernel build notes to mediafire:
http://www.mediafire.com/?x31axhnekgs
post #96 of 2569 Old 02-03-2009, 12:41 PM
Buddy Casino's Avatar
I'm curious if it is possible to replace the Sigma audio microcode with the one from the PopcornHour A-110, thus enabling DTS mixdown.
Or is that blocked by some encryption scheme?
I'd try it myself, but I don't (currently) have linux or serial access, and I'm worried that I might brick my WD TV.
Buddy Casino is offline
post #97 of 2569 Old 02-03-2009, 12:44 PM
mcflyyy's Avatar
Thanks linuxjacques for your help !
mcflyyy is offline
post #98 of 2569 Old 02-03-2009, 01:03 PM
HitDyl's Avatar
I think it's possible just the drivers that need to be changed
But I'm not an expert
HitDyl is offline
post #99 of 2569 Old 02-03-2009, 01:22 PM
Well, ignoring for a second the potential legal implications...
(this would be illegal to do in the US, not sure about other countries)
From my reading it seems the Sigma chip can be "bound to a certificate."
If this is done (probably by the device manufacturer) then only microcode
which is signed by that certificate can be loaded.
If the chip is not bound to a cert, it might be possible to load any properly
signed microcode.
I don't know how to tell whether the WDTV is bound to a cert.
post #100 of 2569 Old 02-03-2009, 03:19 PM
esrefb's Avatar
I don't have the technical knowledge to answer this question. But I know that ISTAR doesn't have DTS decoding neither but some of the users used the Popcornhour firmware and they can now successfully decode DTS.
Since WD uses the same Sigma chip, I'm guessing there's a chance. Still, we need confirmation from a person who has technical knowledge.
esrefb is offline
post #101 of 2569 Old 02-04-2009, 08:39 AM
powerleakin's Avatar
guys if you look at this made in china player, it has same chipset also but plays rmvb? can it be done with our wd tv?
powerleakin is offline
post #102 of 2569 Old 02-04-2009, 10:40 AM
ripkey's Avatar
Yesterday, I compiled one module and put it on the firmware update (I haven't access over serial) to put serial over USB. It didn't work and the firmware upgrade freeze.
Then I switched off the wd hd and put on the pendrive the original firmware upgrade 1.01.02. It works and the upgrade finished correctly.
My wd is alive.
I think that it possible to replace the orginal audio microcode with the popcorn to test it (DTS downmix for example). In worst case it's posible to upgrade with the original firmware again.
ripkey is offline
post #103 of 2569 Old 02-04-2009, 03:23 PM
mcflyyy's Avatar
Tested modules for me :
Module Size Used by Tainted: PF
asix 8368 0
usbnet 15088 1 asix
pegasus 20048 0
mii 3824 2 asix,pegasus
em8xxx 846784 8
llad 95648 9 em8xxx
now i must find an usb network adapter !
See you tomorrow !
mcflyyy is offline
post #104 of 2569 Old 02-04-2009, 03:37 PM
root:/tmp/media/usb/USB1/C831-67DC> lsmod
usbnet 15088 0
pegasus 20048 0
mii 3824 1 pegasus
em8xxx 846784 8
llad 95648 9 em8xxx
See you tomorrow !
mcflyyy, try to get a ASIX based adaptor - this works for me.
As I said in an earlier post, I was unable to get my pegasus based adaptor
to work (though the modules did load and I could configure the interface).
post #105 of 2569 Old 02-05-2009, 10:31 AM - Thread Starter
3dxr's Avatar
Any tests with RTL based adapters ?
if someone need AX based devices I found this
Code:
http://dev.laptop.org/git?p=olpc-2.6...;hb=HEAD#l1350
seek to end
line 1350: static const struct usb_device_id
and there are vendor and model names
Eminent 1010 Rev.2 (Pegasus chipset) - tested by mcfly - status working
Topcom USB LAN 101 (unknown chipset) - tested by mcfly - status working
Airlink ASOHOUSB 10/100Mbps Fast Ethernet USB 2.0 Adapter : (asix chipset) tested by linuxjacques status working
--ASIX Based adapters ----------------------------------
Linksys USB200M
Netgear FA120 - verified using AX88172
DLink DUB-E100 - on amazon used from $8.95
intellinet, ST Lab USB Ethernet
Hawking UF200, TrendNet TU2-ET100
Billionton Systems, USB2AR
ATEN UC210T
Buffalo LUA-U2-KTX
Buffalo LUA-U2-GT 10/100/1000
Sitecom LN-029 "USB 2.0 10/100 Ethernet adapter"
corega FEther USB2-TX
Surecom EP-1427X-2
goodway corp usb gwusb2e
JVC MP-PRX1 Port Replicator
1ASIX AX88772 10/100
ASIX AX88178 10/100/1000
Linksys USB200M Rev 2
0Q0 cable ethernet
DLink DUB-E100 H/W Ver B1
DLink DUB-E100 H/W Ver B1 Alternate
Linksys USB1000
IO-DATA ETG-US2
Belkin F5D5055
Apple USB Ethernet Adapter
3dxr is offline
post #106 of 2569 Old 02-05-2009, 11:05 AM
Originally Posted by 3dxr View Post
any tests with RTL based adapters ?
Sorry, I only have Pegasus and ASIX.
Code:
seek to end
line1350: static const struct usb_device_id
This is the ASIX adaptor I have. I had bought some because apparently
they are one of the few that work on the Nintendo Wii:
http://www.airlink101.com/products/asohousb.php
I got mine at Fry's - normally $15 but sometimes on sale for $5
BTW, if people already have Pegasus based adaptors, please give them a try anyway.
I could have done something wrong when I tried mine.
It would be nice to try everything we have and start a list of known working adaptors.
post #107 of 2569 Old 02-05-2009, 11:26 AM
mcflyyy's Avatar
Heyy !! Good news for mee
I have tested a network adapter today and result : it works !
Pegasus based !!! ( Eminent 1010 Rev.2 )
root:/tmp/media/usb/USB1/C831-67DC> insmod pegasus.ko
pegasus: v0.6.12 (2005/01/13), Pegasus/Pegasus II USB Ethernet driver
pegasus 2-2:1.0: setup Pegasus II specific registers
pegasus 2-2:1.0: eth0, ADMtek ADM8511 "Pegasus II" USB Ethernet, 00:40:f4:cb:9a:04
usbcore: registered new driver pegasus
root:/tmp/media/usb/USB1/C831-67DC> ifconfig eth0 up
eth0 Link encap:Ethernet HWaddr 00:40:F4:CB:9A:04
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:2230 errors:0 dropped:0 overruns:0 frame:0
TX packets:2230 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:195084 (190.5 KiB) TX bytes:195084 (190.5 KiB)
root:/tmp/media/usb/USB1/C831-67DC> ifconfig eth0 192.168.1.78
eth0: set allmulti
eth0: set allmulti
root:/tmp/media/usb/USB1/C831-67DC> eth0: set allmulti
inet addr:192.168.1.78 Bcast:192.168.1.255 Mask:255.255.255.0
RX packets:5 errors:0 dropped:0 overruns:0 frame:0
TX packets:17 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:342 (342.0 B) TX bytes:4560 (4.4 KiB)
Ping ok !!
I'm going to make some tests with samba this evening ! Result in 3-4 hours if everythings is ok !
We progress !!
mcflyyy is offline
post #108 of 2569 Old 02-05-2009, 11:33 AM - Thread Starter
3dxr's Avatar
Can anyone help where to buy USB2TTL converter (plug&go)
I need assembled one I dont want have selfmade one.
>mcfly: check also NFSsupport if is not there.
probably NFS will have better performance (jumboframes:-D)
3dxr is offline
post #109 of 2569 Old 02-05-2009, 12:18 PM
avs_calderon's Avatar
Just do a search on Ebay for USB to UART, you should come up with a few. I just bought 2 with the armtek ARK3116 chip. Unfortunately, I cant seem to find OSX drivers for it so I'm stuck with using either Linux or Windows(bleh).
avs_calderon is offline
post #110 of 2569 Old 02-05-2009, 12:31 PM
mcflyyy's Avatar
it's seems that pegasus crash after some request on network !!!
Arghhhhhhhh !! I search if i find something on the web to correct this problem. ( pegasus 2-1:1.0: get_registers, status -19 )
mcflyyy is offline
post #111 of 2569 Old 02-05-2009, 12:42 PM
cerulean's Avatar
I've had pretty good luck with FTDI based boards under windows:
http://www.sparkfun.com/commerce/pro...roducts_id=718
I've never tried one under Linux, but it looks like it's supported in the 2.16 kernel.
Bob
cerulean is offline
post #112 of 2569 Old 02-05-2009, 12:58 PM - Thread Starter
3dxr's Avatar
This is not good. "-19 should be "no such device" error
FedoraCore had also some problem with this in past
also sometime if was module inserted and in this moment will come packet driver have problem
3dxr is offline
post #113 of 2569 Old 02-05-2009, 01:30 PM
mcflyyy's Avatar
I found the problem i think !
I have added an Usb-Hub and now no lost device anymore !
Another interresting thing from the root console :
root:/tmp/media/usb/USB2/C831-67DC> Server: dlink-6A9787, Model name is DNS-343, verson is 103:
Wdtv seems detect my Media server
mcflyyy is offline
post #114 of 2569 Old 02-05-2009, 01:53 PM
CuE_'s Avatar
Go ninja go !!
CuE_ is offline
post #115 of 2569 Old 02-05-2009, 02:18 PM - Thread Starter
3dxr's Avatar
how is connected this NAS with USB cable ?
or over the network NFS/SMB
I think over USB or not ?
Code:
$>mount  #?
if is over network try copy/move 700mb+ file over network from NAS to USBx localWDTV storage
and stop the time. small benchmark test copying over net
3dxr is offline
post #116 of 2569 Old 02-05-2009, 02:24 PM
mcflyyy's Avatar
It's connected by network, but no mount point ... just a line in console appears after 1 or 2 minutes
mcflyyy is offline
post #117 of 2569 Old 02-05-2009, 02:32 PM - Thread Starter
3dxr's Avatar
describe what you are doing which networked filesystem
you are testing.... and add commands probably somebody
will see somethink what is hidden for you now.
[ in early euphoria ]
3dxr is offline
post #118 of 2569 Old 02-05-2009, 02:57 PM
mcflyyy's Avatar
I don't try to mount anything, after some minutes of inactivities the WDTV console show the following line :
Perhaps, it's only the kernel information ! I don't know ...
Now i try to run Samba but i have a problem with libresolv.so.0 librairy ! In wdtv firmware she's named : libresolv-0.9.28.so
I search a solution !
mcflyyy is offline
post #119 of 2569 Old 02-05-2009, 03:08 PM - Thread Starter
3dxr's Avatar
idea1) I think there is tmpfs support /lib have cca 19mb its too big for tmpfs
idea2)but you can create symblink libresolv.so.0 -> libresolv-0.9.28.so I am not sure if is / or /lib writable
idea3) copy /lib on USB storage create symblink and remount /lib with modified storage
if is not possible mount another diretory over /lib you can use losetup/mount -o loop0 as workaround
and I am not sure if is depmod -a nescesary re-run
btw: tempovery forgot on SMB try less painfull way I understand SAMBA/CIFS is most wanted but SMB may be need some extra researching
export /home/mcflyy direcotory on you linux/*OS box
#mkdir -p /tmp/nfsroot
#mount -t nfs -o nolock xxx.xxx.xxx.xxx:/home/mcflyy /tmp/nfsroot
reason may be work and xxxx.xxx.xxx.xxx can by IP and this if in original firmware probably dont need resolver
3dxr is offline
post #120 of 2569 Old 02-05-2009, 03:58 PM
mcflyyy's Avatar
Don't seems to be working The tricks for /lib works, but samba crash apparently ...
With Wget i can transfert some files but it's slow ~1mo/s ! I think it's my usb key ...
mcflyyy is offline
