Firmware - Western Digital - WD TV HD Media Player - Page 86 - AVS Forum | Home Theater Discussions And Reviews
post #2551 of 2569 Old 02-01-2010, 04:58 AM
craftech's Avatar
Originally Posted by thnmnt View Post
Lots of people (including me) held fast at 1.01.07 because that's the last official firmware that supported hubs. Subsequent firmwares have fixed various things - lots of subtitle help, some sync issues, gain issues...you can check the changelogs to see.
Basically, you should upgrade to the latest version - it's stable and there's no downside (unless you use hubs). If you do use a hub, you can get b-rad's wdlxtv which is based on the latest firmware but puts hubs back in - plus a bunch of other stuff.
plus - you can upgrade, see if you like it and downgrade if you don't. you just make a small text edit to the .ver file if you're downgrading.
Thanks for that. Really appreciate it.
John
craftech is offline
post #2552 of 2569 Old 02-01-2010, 08:59 AM
DigitalfreakNYC's Avatar
Quoted: 84 Post(s)
Don't shoot the questioner but...
what the hell's a hub?
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #2553 of 2569 Old 02-01-2010, 09:20 AM
Derelict_Drvr's Avatar
USB hub. Multiple usb ports for a single port. Like this.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways,
totally worn out, shouting '...holy sh*t ....what a ride!'
Derelict_Drvr is offline
post #2554 of 2569 Old 02-01-2010, 09:35 AM
jponte55's Avatar
Originally Posted by kevotinh View Post
Now they have three firmwares to work on. Live, generation 1, and generation 2. Soon or later, they'll have to cut down their work. I just feel sad that I bought the WD TV generation 1 not to long ago, now i'm stuck with it.
Considering the pricepoint on these devices I hardly think you are "stuck" with anything.
jponte55 is offline
post #2555 of 2569 Old 02-01-2010, 11:13 AM
vanylapep's Avatar
Can someone add support for cd+g files? please...!
vanylapep is offline
post #2556 of 2569 Old 02-07-2010, 07:13 AM
craftech's Avatar
Ok,
I searched for firmware version 1.01.07 and couldn't find that to be a valid firmware version.
Are you sure you didn't mean firmware 1.02.07?
Is there a direct link to the firmware?
John
craftech is offline
post #2557 of 2569 Old 02-07-2010, 09:02 AM
thnmnt's Avatar
yes, sorry - i meant 1.02.07 - it had been a while!
check here: http://www.wdtvc.com/downloads/
I use TVnoos and so should you!
thnmnt is offline
post #2558 of 2569 Old 02-07-2010, 02:19 PM
craftech's Avatar
Thanks for the response. Much appreciated:
John
craftech is offline
post #2559 of 2569 Old 02-08-2010, 06:15 AM
craftech's Avatar
Put it on a thumb drive. Update went flawlessly.
Thanks again
John
craftech is offline
post #2560 of 2569 Old 02-11-2010, 02:08 PM
hahahaha's Avatar
I have two WDTVs (v1). The harddrive is attached to one of them and shared with another WDTV via NFS. I was able to explore the shared the folder and video files on the 2nd WDTV through NFS share. However, none of the videos is playable. When I choose the video, I got a black screen for about 1 minute and the some kind of message telling me the video format is not supported. All videos are playables on the WDTV with the harddrive directly attached. Both WDTVs are on WDLXTV 0.57 with nfs.app application. They are all attached to network with USB to ethernet adapters.
Anyone know why? Thanks
hahahaha is offline
post #2561 of 2569 Old 03-12-2010, 01:19 AM
cocof2001's Avatar
I installed everything from WDLXTV 0.5.8.1 (hxxp://b-rad.cc/wdlxtv/) to the usbkey. I get a NO IP message. I tried setting the net.config file. I tried also with diffrent asix.ko modules found on the hxxp://wiki.wdtv.org/doku.php?id=supported_usb_devices. I still get NO_IP. I powerd on/off the WDTV each time.
The device is a Gembird USB to Fast Ethernet.
What am I missing in configuring this usb to ethernet device.
cocof2001 is offline
post #2562 of 2569 Old 03-25-2010, 05:06 PM
tax3ver's Avatar
Hello *,
refering to the wiki, where the list of supported usb-adapters is located, i found the Wintech LAU-15. But the link to the driver file (its a MCS7830 based driver) is broken. Does anybody has a different link for getting the driver file ?
Could please anybody help me ?
tax3ver is offline
post #2563 of 2569 Old 04-29-2010, 07:45 AM
tempelis's Avatar
Hello guys!!! I am new to the forum. I have a WDTV Gen1 and recently I have updated to the final unofficial firm WDlxTV.I have followed all the instructions for network configuration but my WDTV don't take any ip.Maybe I do something wrong!I should update firm with the modified net.config. Can u give me any help??How the apps are working???only with usb plunged in??? Thanx anyway!!
tempelis is offline
post #2564 of 2569 Old 04-05-2012, 07:25 PM
rightway44's Avatar
I bought a WD live TV streaming media player box.
Unlike usa model this canadian model has been modified to without live channels.
Very limited stuff.I want any live news channel on it in Canada,
Kindly provide any third party software/ firmware to enhance channels
rightway44 is offline
post #2565 of 2569 Old 10-09-2012, 11:40 AM
lazarusbf's Avatar
Hello
I have this old (1st gen) WDTV, i never ever installed any unofficial FW and was wondering if in installing one, all my recent MKV files would work. For a couple of years i've had numerous MKV (movies and TV episodes as well) that were crashing the WDTV. My only solution was a reset and play them on my macbook pro but that'd be cool if i could still use my wdtv. I'm not too keen on buying a new WDTVlive just for this issue.
Thanks for replying. Sorry for the (english) mistakes.
lazarusbf is offline
post #2566 of 2569 Old 10-09-2012, 12:16 PM
asif9t9's Avatar
You may as well try to load the custom firmware. But if MKV's aren't working, you may be better off to try a small program called mkvfix.exe. Here is a thead where someone posted a link.
http://community.wdc.com/t5/WD-TV-HD/WD-Medial-Player-gen-won-t-play-any-files-it-just-stop-working/td-p/67744
You will also have to install MKVMerge (aka MKV Toolnix).
http://www.bunkus.org/videotools/mkvtoolnix/downloads.html
Just make sure you change the option in MKVMerge to disable header compression. Or use an older version like 5.1.0.
asif9t9 is offline
post #2567 of 2569 Old 10-15-2012, 07:58 AM
lazarusbf's Avatar
Thanks for your reply!
I will try a custom FW. I must say 80% of my MKV files do work fine on my WDTV (TV episodes work 99% of the time, it's more the occasional movies in 1080p that does not play anymore).
post #2568 of 2569 Old 10-15-2012, 10:38 AM
asif9t9's Avatar
If that's the case, you're better to try my tip about mkvfix.exe before trying custom firmware. Custom FW looks cooler and you can do different things (my Gen1 player is looked up to my LAN using a USB to ethernet adapter). But Custom FW won't play a file the WDTV can't play, AFAIK.
asif9t9 is offline
post #2569 of 2569 Old 02-18-2013, 02:43 AM
inspiron_l6400's Avatar
Please i need HELP.
i don't find wireless-mod-rt3070v2.app.bin I need this file. please if someoane have this file, can upload again?
inspiron_l6400 is offline
