Best way to use WD HD TV Media Player? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 04-04-2009, 04:37 PM
mdfire's Avatar
I read this thread last week while waiting on my WD HD TV arriving in the mail. So I ripped a few of the kids cd's usind dvdshrink to ISO. The player arrived today and when I set it up it is only recognising AVI files not the iso. Anyone had this problem.
mdfire is offline
Old 04-16-2009, 01:13 PM
kc10a's Avatar
I'm having problems too. I ripped some movies using DVD Shrink and any DVD. Some work, some work without sound, and some don't work at all. I tried clone DVD and it works in stereo mode. Is there a way to rip to MP4?
kc10a is offline
Old 04-16-2009, 02:02 PM
mytbyte's Avatar
Liked: 25
Does it see the .iso but won't play it or it doesn't se .iso files at all? Were the .ISOs made from regular DVD video discs?
mytbyte is offline
Old 04-16-2009, 02:46 PM
YukonJack's Avatar
It may be that DVDShrink did not defeat the copyright on the DVD itself when it ripped it. You may want to try DVDFab or one of the other rippers and see if that works.
Greg
YukonJack is offline
Old 04-16-2009, 06:57 PM
lepidoptera's Avatar
I've watched at least a dozen ISOs created with DVD Shrink.
Note: make sure that the name of their folder does not start with "."
For example
.Flicks
will be ignored, whereas IOSs in
Flicks
will show up
lepidoptera is offline
Old 05-12-2009, 06:42 AM
tabo's Avatar
I've been using the WD HD Tunner for 4 days now and here are my findings.
After latest firmware upgrade 1.02.07:
To add cover art, take your favorite .jpg of the movie's cover, and drop it inside the folder where the .mvk or whichever file format file is. Name that EXACTLY the same as your video file. Ex, death_race_HD_movie.mvk death_race_HD_movie.jpg. The image must be in .jpg format. The folder in which the video file recides, along with the icon of the video file itself will also display the image file. This only works for thumbnail view.
You can add an image even to other folders by adding your favorite image (in my case I have a Blu-Ray and a DVD folder, I added the blu-ray logo to the blu-ray folder. Just drop inside the folder the .jpg file and name it FOLDER. That simple.
If you rip to .mvk (I use MakeMVK), it will keep all your surround (DB5.1 and DTS) and image quality true to original in one file. So you don't end up with a bunch of little files to sort through. I rip only the main movie, the audio tracks and the subtitles.
ISO's do play, but are buggy specially with Blu-rays. Audio cuts off, audio track defaults to some foreign language and they are huge! None of these problems are present when ripped to .mvk.
I cannot get subtitles to work for some reason.
On the new firmware, you can select different chapters as you play the blu-ray which is very nice.
Hope this helps.
tabo is offline
Old 06-06-2009, 11:26 AM
danbidd's Avatar
Originally Posted by wdmediaplayerfan View Post
No, WDTV doesn't show cover art on any ISO files.
To make your ISO files display cover art all you have to do is put a jpg file in the same folder as your ISO with the same EXACT name as your ISO. This is how I get it to display cover art for my DVD ISO files anyway
danbidd is offline
Old 04-11-2013, 11:43 AM
nmharleyrider's Avatar
I use Imageburn to make an ISO out of my DVDS and put them on external hard drives. The menus, surround sound, et al are preserved in the ISO. Then I just plug my hard drive into the USB port on the WE HD TV Media Player. I've done several hundred dvds this way and they all play perfectly. In fact you don't have the digital effects you sometimes get playing the dvds directly on a dvd player. Hope this helps
nmharleyrider is offline
Old 04-11-2013, 03:36 PM
comicguy's Avatar
dvdshrink does not remove the copy protection. if you have anydvd running in the background (not free) then that will do the trick...
comicguy is offline
Old 04-12-2013, 01:04 PM
Forgot to mention I use anydvd in conjunction with ImageBurn when I am copying a dvd
Old 04-12-2013, 06:40 PM
GusGus748s's Avatar
Quoted: 415 Post(s)
Liked: 699
WDTV doesn't support ISOs.
GusGus748s is offline
Old 04-13-2013, 07:30 AM
Otter0911's Avatar
Quoted: 69 Post(s)
Otter0911 is offline
Old 04-13-2013, 02:34 PM
If you are talking about the Western Digital WD TV Live Plus Unit, I play ISOs on it all the time. I use Imageburn to burn the ISOs and so far have had no trouble playing them. I did have to get a firmware upgrade though for it although that was a long time ago.
Old 04-13-2013, 02:35 PM
hahaha You know I did not notice the date on these posts. as usual, I'm right on top of things or under them
