WD TV HD Media Player - Replacement Remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-11-2009, 10:35 PM - Thread Starter
nineteen9's Avatar
Hi -
I've lost my remote and was wondering if anyone has had any luck getting the WD HD Media Player to work with another remote.
Ideally I'd like to have my satellite remote (a 5.0 IR from dish network) be able to control the WD HD Media Player. Has anyone had any luck with doing this?
nineteen9 is offline
post #2 of 9 Old 02-11-2009, 11:28 PM
BoschRock's Avatar
My WDTV works flawlessly (better than the original remote) with my Harmony remote.
If you don't have one, you should look into them!
BoschRock is offline
post #3 of 9 Old 02-11-2009, 11:40 PM
tyree91's Avatar
Originally Posted by nineteen9 View Post
Hi -
I have all the codes in a Universal Remote File. If that's of any help PM me and I'll send you the file. Regards, Norm
Wilbur Buckley likes this.
tyree91 is offline
post #4 of 9 Old 02-12-2009, 08:44 AM
piecutter's Avatar
I'll second the Harmony option. I have a Harmony 880 and it works much better than the original. Harder to lose too!
piecutter is offline
post #5 of 9 Old 02-12-2009, 02:10 PM
fred_be9300's Avatar
fred_be9300 is offline
post #6 of 9 Old 02-13-2009, 12:49 AM
jblack94530's Avatar
You can order the replacement WD remote from the WD Online Store for $15
jblack94530 is offline
post #7 of 9 Old 03-12-2009, 08:48 AM
jmoose's Avatar
hey i have a harmony 659 i believe, im trying to set up my wdtv with it.. but i cant seem to find the proper settings care to help me?
jmoose is offline
post #8 of 9 Old 03-12-2009, 11:33 AM
ericwe's Avatar
Code:
Device            Manufacturer       Model
Media Center PC   Western Digital    WD TV HD Media Player
A good place to poke around is http://myremotesetup.com/EasyZapper/New/Main.asp when you need to find out what is supported.
ericwe is offline
post #9 of 9 Old 07-08-2013, 02:24 PM
Wilbur Buckley's Avatar
would like a copy sent as soon as you have time please an thank you
Wilbur Buckley is offline
