WD TV Prerelease 1.02.04 is out - Page 13 - AVS Forum | Home Theater Discussions And Reviews
Old 04-16-2009, 09:46 PM
priesto's Avatar
Please make it a feature so that you can display more than 2 rows of 6. There's space for at least one more row
and add some readability to .txt or .nfo files, so we can read info about what you're watching
keep up the good work
priesto is offline
Old 04-17-2009, 12:05 AM
Dion250's Avatar
I found a bug with the latest firmware. When you have hard drives hooked up via USB hub. It sorts the Hard drives by Size and not alphabetical. Fix Please.
Dion250 is offline
Old 04-17-2009, 01:45 AM
eskargo's Avatar
has someone reported this as a bug? the counter for the last page is incorrect when the number of items in the last page does not have the pointer of the previous page.
22/88
34/88
46/88
58/88
70/88
82/88
94/88 <---- last page
eskargo is offline
Old 04-17-2009, 02:59 AM
hiendas's Avatar
Originally Posted by hungi View Post
Please post hard evidence (oscilloscope screens?). Im sure that WD can fix that...
The first oscilloscope screen.
The output signal was taken directly from the WD TV analog output.
WD TV tries to replay an audio file (.wav). The 1Khz test tone is at 0dB full scale.
g.kar
hiendas is offline
Old 04-17-2009, 03:06 AM
hiendas's Avatar
This is the second screen shot.
The signal was taken from an external D/A converter .
WD TV supplies the digital signal, i.e. the converter's digital input was directly connected to the WD TV digital (toslink) output.
g.kar
hiendas is offline
Old 04-17-2009, 03:18 AM
hiendas's Avatar
As you can clearly see from the previous two shots, my WD TV failed to reproduce properly a full scale audio signal that has been recorded at 0dB (full scale).
Both the analog and the digital outputs are affected by that replay gain issue.
What about your WD TV , does it behave the same way ?
P.S I performed the same test with a similar media player of a different brand. The waveform in that case was perfect (no clipping).
g.kar
hiendas is offline
Old 04-17-2009, 03:57 AM
HWTest's Avatar
Originally Posted by hiendas View Post
Exactly !!!
You can also record a sinewave at 0dB and observe the o/p on an oscilloscope
I don't have an oscilloscope.
I've done some more test with mp3, flac, ogg - clipping everywhere :-(
HWTest is offline
Old 04-17-2009, 04:02 AM
lmaolmao's Avatar
good work, any idea if this affects dolby digital when playing videos?
lmaolmao is offline
Old 04-17-2009, 04:39 AM
Rob100's Avatar
Assuming you have an amp decoding the bitstream I can't see how it can.
If however the WD TV if decoding the DD track and outputting as 2CH PCM (output set to "stereo" rather than "digital") then I guess this issue could exist.
Rob100 is offline
Old 04-17-2009, 08:38 AM
sdsi's Avatar
HI,
To WD Team - BUG in 1.02.04:
1. Settings->Photos->Photo scaling - "Keep as original" doesn't work. WD displays photos ALWAYS as "Fit to screen"
2. Settings->Audio Video - NTSC/PAL switch doesn't work
Best regards,
sdsi is offline
Old 04-17-2009, 09:45 AM
jsimeo's Avatar
Originally Posted by wicker_man View Post
Regarding idx/sub subs, i can confirm that the last subtitle is not showing up with 1.02.04
Please say if you believe that an external srt file that has overlapping on lines 112-113 can cause problem on displaying ok lines for example 1 to 20!
And if one other file with NO error at all (reported by subtitle workshop), is faulty because ONLY WDTV (ONLY prereleases) can't display the subs in time and for the duration that the str file very simply declares!
Some people here have big problem to read and understand what they read!!! Maybe that's the reason they don't care about subs...
jsimeo is offline
Old 04-17-2009, 09:54 AM
wicker_man's Avatar
I would have to investigate that srt to get to a conclusion; an error on a later line is surely not the cause, but there may be a cause on the file (or not, and then it's the wdtv's fault).
And if one other file with NO error at all (reported by subtitle workshop), is faulty because WDTV (ONLY prereleases) can't display the subs in time and for the duration that the str file very simply declares!
Again, let me have that srt to investigate. You're on 1.02.04, right?
wicker_man is offline
Old 04-17-2009, 09:57 AM
wicker_man's Avatar
Originally Posted by sdsi View Post
HI,
Could this be something to do with your tv, not wanting to go to a tv system it does not support? I can do it with this firmware - although NTSC looks (of course) crappy on my PAL tv.
Old 04-17-2009, 10:15 AM
jsimeo's Avatar
I'm talking about the two files i have upload for GuyWD some days ago. You gave an answer, i replied to you and some took only your (half) answer as a fact and where happy for nothing... LOL
jsimeo is offline
Old 04-17-2009, 10:19 AM
wicker_man's Avatar
ah, the p.s. i love you and the other... ok, wait a couple of minutes, be right back.
Old 04-17-2009, 10:29 AM
Monkeyface66's Avatar
This is not a bug.
This only works if you use COMPOSITE output.
WD TV (again!) & Xtreamer owner :)
Monkeyface66 is offline
Old 04-17-2009, 11:00 AM
jsimeo's Avatar
And i repeat:
(Some lines from a external srt file (a simple text format file as you can all see, each line says when it starts , when it stops and then the text that should be on screen.
With blue color i give the duration that file says the line has to be on screen and with red is the time that WDTV prereleases have the subs on screen)
12
00:02:25,244 --> 00:02:29,040 about 4 sec 0.1sec
- Δεν ξέρω τι είπα.
- Το είπες. Ξέρεις ότι το είπες.
13
00:02:29,075 --> 00:02:31,257 about 2 sec 0.1sec
Δεν ξέρω τι είπα,αλλά δεν
το εννοούσα.
14
00:02:31,292 --> 00:02:33,252 about 2 sec 0.1sec
Φυσικά το εννοούσες. Πάντα εννοείς
ότι λες.
15
00:02:33,294 --> 00:02:35,421 about 2 sec0.1sec
Μερικές φορές δεν εννοώ τίποτα
από αυτά που λέω.
16
00:02:35,456 --> 00:02:37,305 about 2 sec 0.1sec
Δεν υπάρχει τίποτα. Υπάρχει πάντα
κάτι.
17
00:02:37,340 --> 00:02:40,384 about 3 sec 0.1sec
Δεν εννοώ ότι ότι λέω δεν είναι τίποτα,
απλά τα λέω έτσι για χάρη του λόγου.
18
00:02:40,419 --> 00:02:43,387 about 3 sec 0.1sec
Το να λες κάτι για χάρη του λόγου είναι
ένας τρόπος να ξεφύγεις,
19
00:02:43,422 --> 00:02:46,140 about 2.5 sec 0.1sec
αλλά ξέρεις τι λες κάθε φορά
που το λες.
This file is working ok on VLC, MKPLAYER, and generally on all pc media players, also it plays ok on official WD 1.01.02! Only prereleases gives the red color duration!
Some people here says that it is sub file problem! Believe them! Also the earth is stood still!
jsimeo is offline
Old 04-17-2009, 11:08 AM
wicker_man's Avatar
relax, jsimeo, no need to get all worked up. I never said the problem *was* on the srt file, only that it *might* have been.
I'm embedding one minute of your paranoid park srt (the fixed one, of course, the one after subtitle workshop) onto a video i have - it's not paranoid park, but it doesn't matter, it's a video behind it.
I'm going to see the video and the embedded subs will obviously appear the correct time - at the same time, i'll have the srt loaded to compare.
On the other hand, i've placed english text on a copy of that 1 minute portion of your srt file and it *seemed* to appear the correct amount of time. This i will also compare with the embedded ones. Should this be the case, then the bug is real, but apparently only on some character encodings, like greek.
Will report back in a couple of minutes.
Old 04-17-2009, 11:20 AM
jsimeo's Avatar
... I never said the problem *was* on the srt file, only that it *might* have been. ...
I'm not talking about you, i know you said "it might be" but some took this phrase of you and without taking in mind my reply said :
"This is confirming what i said, some users have broken subs and accuse the prereleases" some other said even worse.
jsimeo is offline
Old 04-17-2009, 11:30 AM
wicker_man's Avatar
Ok, i think i've figured it out - it seems to be connected to the additional character encoding one chooses on the wdtv.
Western Europe:
greek text srt - perfect synch, full duration, lovely.
english text srt - perfect synch, full duration, lovely.
Greek :
greek text srt - later synch, smallest duration, barely readable, a disgrace.
Eastern Europe (windows1250 and iso):
greek text srt - later synch, small duration, not too readable, a disgrace.
i'm going to film this and post it on youtube, so that it can become obvious to everyone.
You were right, and i was right - we were just using different additional character encoding and that's why you saw a bug and i didn't.
Old 04-17-2009, 11:53 AM
jsimeo's Avatar
My answer on your "might be" file's problem 3 days ago:
Hello m8, as i said before both files shows "flashing" subs. It's not overlapping problem, problem is obvious at first 20 lines (all the movie of course) , the overlapping sub is line 122. I've been editing my subs at subtitle workshop more than 2 years, i've test them it is not a sub error. Maybe only at some ISO's/"codepages" happens, i don't know but it is not sub file error. I tried to watch more than 40 files that were tested and watched ok (from start to end! ) with 1.01.02 and none was watchable with prereleases! Anyway thank you for your concern. - Gracias-
After this reply, talking for your "might be file's error":
Originally Posted by high_definitely View Post
Confirms what I wrote earlier, thanks for the info. The subtitles that caused those problems for me so far were faulty, and the problems could be reproduced on the PC also (using VLC). This can be easily cured by adding a proper external .srt subtitle file from a different source, giving it the same name as the video file.
MPC and other media players may be more tolerant when it comes to handling faulty subtitles, so the problems are not obvious there.
Later:
Originally Posted by David-s View Post
NO PROBLEMS HERE WITH SUBITLES ON MKV AND AVI !!!!!!!!!!!!!!!!!!!!!!
Firs of all try download good sub's and that check it on player.
Most of post here are rubbish !!!!!!!!!!
Download the official release and than check your media.
Do not download any stuff from p2p for test
What i don't like is someone to talk about something that doesn't know! If you want to say your opinion for something, first READ at least what the other side says!
Maybe is some guys aim to defend a product, a company etc (i dont care for the reason of this), but they should do this without offend others!
jsimeo is offline
Old 04-17-2009, 12:58 PM
jsimeo's Avatar
About the BLACK LEVELS!
Some reported that the 1.02.04 pre has problem with black levels!
An hour ago flashed again the 1.02.04 to check that the "flashing subs" problem is not there on other character encodings. Yes, wicker_man is right, only on Greek subtitles this bug is present!
So i had the opportunity to check the black levels. I always had black levels not so good with WDTV, so i had to check what about 1.02.04
I connected HDTV to my 22' pc monitor through HDMI to have same settings and same screen! Pc is connected through DVI
I watched some part from "Dark city" and then gone back to 1.01.02 (this is the only FW working ok for someone to watch files with Greek subs).
I watched the same part and it was identical!
Then i watched this part on pc. Very big difference! On pc i could see both sides of the main character's face and the lower part of the costume of the male doll (point 10m00s to 10m20s) that on WDTV (both 1.01.02 and 1.02.04) one side of face and male doll's lower part are invisible and lost in the blacks!
So this problem seems to be on all FWs...
jsimeo is offline
Old 04-17-2009, 01:01 PM
high_definitely's Avatar
Look who is talking. I'm sorry, but since I don't speak greek, how the hell do you expect me to reproduce your very special problem? You keep on ranting about the subtitles not working, yet you failed to mention a very important detail - greek subs seem not to work properly. That's the result of wicker_man's detailed test, another user you kept barking at for no good reason.
It's you who has been ranting here for days, being rude and totally not helpful in any way. You should thank wicker_man for the proper bug report of your problem.
high_definitely is offline
Old 04-17-2009, 01:08 PM
wicker_man's Avatar
Yes, greek subs DO NOT work properly, because
a) they have a huge delay which causes them to flash and become unreadable if you choose the greek encoding support
and
b) you have to choose greek as the additional encoding support, otherwise all you see is gibberish, not greek.
he may have been a bit rude, but he is right.
Old 04-17-2009, 01:11 PM
wicker_man's Avatar
I don't speak or read greek, and yet i was curious enough to try and work out what happened.
I'm uploading the video to youtube as we speak.
EDIT: Besides, that's not his very special problem - it's a problem for all greeks, perhaps for other languages/countries as well.
Old 04-17-2009, 01:50 PM
ArgusP's Avatar
I'am having troubles with Slovenian accented characters in subtitles (windows 1250 - ščžŠČŽ).
Most of them are not displaying at all (except č which is displayed as e with a carret on it).
Any ideas?
(and yes, I have 1.02.04 FW)
ArgusP is offline
Old 04-17-2009, 01:56 PM
wicker_man's Avatar
Here's the youtube video i did, showing the problem with greek subs:
http://www.youtube.com/watch?v=kxd2szpjeu0
Old 04-17-2009, 01:59 PM
jangalang32's Avatar
i have a few problems...i am new and just pickd up this device and everything is working except 2 problems. can someone help me out?
1) how do you turn off the subtitles for good? i know once the movie starts the options button i can shut it off but they start up again everytime i play a movie. is there a permanent option?
2) some of my larger HD files stutter and sometimes come to a complete stop during playback. and soultions to this? i have the latest firmware
thanks for the help
jangalang32 is offline
Old 04-17-2009, 02:09 PM
droopysk's Avatar
Any ideas?
Hi, did you select correct (windows-1250) additional encoding in wdtv menu? And is your subtitles in windows 1250 encoding?
Because these letters works fine on my box.
irset - wdtv remote control over telnet
droopysk is offline
Old 04-17-2009, 02:11 PM
wicker_man's Avatar
thanks for the help
1) Yes, it's a permanent thing, that *may* change in the future if WD decides to make that into the setting menu.
2) Use a program called mediainfo to find out the specs on those videos and report back with that info. Most likely, they will have too many reframes (more than 5, if i remember correctly).
