Just got a 1TB mybook mass storage unit what first? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-22-2009, 01:29 PM - Thread Starter
BowerR64's Avatar
I just got thsi and plugged it in and there is about 500 megs of crap on it.
Do i just start moving my movie files over to it or can i get rid of all this WD junk on the drive first?
Should i format the thing clean like its just a new partition and format it to NTFS or what will the WDtv player want?
I have about 10 movies ripped on my computer drive that i want to move over and start transfering my dvds to this book.
I dont have the wdtv unit yet i thought ide wait a few weeks to get it.
Thanks for any help ou can give me.
Originally Posted by donsantos
How can you tell a point is a reflection point?
Originally Posted by maxcooper
sit in normal spot
have friend slide mirror on wall
see speaker? bingo!-Max
BowerR64 is offline
post #2 of 12 Old 04-22-2009, 08:17 PM - Thread Starter
BowerR64's Avatar
Is this a dumb question?
I wanted to start ripping my DVDs and putting them to the drive but i didnt want to have to start over if i needed to format the drive or do somthing special to it before.
sit in normal spot
BowerR64 is offline
post #3 of 12 Old 04-22-2009, 10:39 PM
clicke's Avatar
If you don't need it, delete it. Or back it up (zip, burn to disc, whatever) just in case.
sigh.. Mods, we really need a WD TV subforum.
clicke is offline
post #4 of 12 Old 04-23-2009, 06:30 AM
Joel Graffman's Avatar
Make sure the drive goes into sleep mode properly and that you have all of the latest firmware updates.
Mastermoto
Joel Graffman is offline
post #5 of 12 Old 04-23-2009, 09:51 PM - Thread Starter
BowerR64's Avatar
Well i just have the drive for now, i didnt have enough for both the WDtv AND the drive so i decided to get the drive first because i figured it would take me some time to rip and move all my DVDs to the drive. While i was doing that i could sae for the player.
My question was now i have the drive (no WDtv player) do i need to do anything to it before i start to fill up the drive? Can i just plug it in and start ripping movies or should i format it to fat 32? NTFS? leave it, delete the default files on it?
Im wondering what others are doing?
Maybe i misread your post? does the drive need firmware or updates? I know the WDtv unit might but i dont have that part yet.
sit in normal spot
BowerR64 is offline
post #6 of 12 Old 04-24-2009, 01:09 PM
whiteboy714's Avatar
I bought a WD passport and formatted it as soon as I got it, I did a quick format to ntfs. No need for the junk WD puts on it imo.
Been working great ever since which has been a few months!!
whiteboy714 is offline
post #7 of 12 Old 04-25-2009, 12:42 AM - Thread Starter
BowerR64's Avatar
Thanks man! thats what i needed to hear. I dont think ill need the stuff thats on it either but wanted to ask before i started.
Ive already transfered a few movies over but it was pretty much just to test and see how it went. I think this is gona be a fun.
sit in normal spot
BowerR64 is offline
post #8 of 12 Old 04-25-2009, 02:22 AM
fred_be9300's Avatar
Some people have found that WDTV reacts a bit snappier when the NTFS drive is formatted with larger-than-default cluster size. The default is 4kb clusters. If your drive will be (almost) exclusively used for video files, then I would reformat at e.g. 8kb cluster size. Quick format will do that in minutes... full format could be several hours
read more: http://www.avsforum.com/avs-vb/showthread.php?t=1138318
WD TV Wiki: info for users, by users
fred_be9300 is offline
post #9 of 12 Old 04-25-2009, 04:46 PM - Thread Starter
BowerR64's Avatar
I hope i didnt mess up, when i used the default cluseter i hooked the HD up to my philups upconverting dvd player and i could read files and actualy play the vob files threw the USB port, now when i hook it up it doesnt even reconize any of the files on the drive.
WHy would it do that?
WHen i hooked it to the DVD player it played the files but it kinda skipped every few seconds like it was struggeling to transfer the data or decode it or somthing. I thought maybe changing the file alocation would speed it up a tad and it would then play smoother. Now it doesnt even work at all.
I think im gona hold off on transfering movies till i get the WD tv player and make sure its even gona play the movies i have on it so far.
Maybe i used the wrong type?
sit in normal spot
BowerR64 is offline
post #10 of 12 Old 04-25-2009, 10:35 PM
xXVirusXx's Avatar
I formatted mine right away then added my files.
xXVirusXx is offline
post #11 of 12 Old 04-26-2009, 08:29 PM
Psychoav's Avatar
I just got a WD 1TB MyBook Essentials edition, do I need to keep the original files to maintain the spin-on spin-off(or auto on/off) functions for WD TV?
Psychoav is offline
post #12 of 12 Old 04-26-2009, 08:35 PM
high_definitely's Avatar
Of course not.
high_definitely is offline
