Best Player/Streamer for Blu-Ray Folder and ISOs - AVS Forum | Home Theater Discussions And Reviews
Old 06-30-2009, 11:40 PM - Thread Starter
Stiltz's Avatar
Quoted: 18 Post(s)
I currently have a Popcorn Hour A110 upstairs and am looking for a player/streamer for my home theater.
The main function will be to play Blu-Ray, HD-DVD, and DVD rips from my unRAID server. (using AnyDVD-HD)
Most of my files are in folder structure, but some are .iso.
I've heard the new Popcorn Hour C-200 might have this functionality?
SageTV's STP-HD200 HD Theater supposedly can play BD ISOs or forlder structures, even "unencrypted" BDs from a shared Blu-ray optical drive in a PC.
What's my best bet?
Media Room - JVC RS500 PJ, 130" Dalite JKP 1.3, Anthem MRX 1120 AVR, Panasonic UB900 UHD, Martin Logan Vantage, ML Stage, 4xML Motion FX, 4xML R Ceiling, PS Audio PWD, Seaton Submersive (2xHP, 1xF2) / HSU MBM Subs, Dune 3D, Sonos, HTPC, 2xButtKicker
Family Room: LG 65E6P OLED, Marantz SR7010, Philips UHD, 2xMartin Logan Motion 15, ML Motion C2, 2xML Motion 2, 2xML IC Ceiling, REL T9 Sub, HTPC
Stiltz is offline
Old 07-01-2009, 06:27 AM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 108
The Sage extender does not support menus (if that matters to you.) More importantly, it does not fully support the High def audio (TrueHD, DTS-HD MA.) It will pass on (through the HDMI connection) the core DD or DTS track found in those High Def tracks, but it does not currently pass on the full res audio track.
Don't know much about the popcorns so I can't comment on those.
-Suntan
Suntan is offline
Old 07-01-2009, 10:17 AM
Raistlin_HT's Avatar
Quoted: 31 Post(s)
Liked: 30
You may want to hold out for info on the new Popcorn Hour C200.
For the spec, it lists BD.iso. What hasn't been answered however, is whether that is only for when using discs (it accepts a BD drive), or for backups on an HDD/network.
It does not support HD DVD however.
http://www.popcornhour.com/onlinestore/index.php
Raistlin_HT is offline
Old 07-01-2009, 12:45 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Also, the HD200 does not have DTS Downmix so you will get zero audio out of it if you connect the HD200 directly to a device that cannot decode (such as directly to your tv) when only HD audio tracks are available (TrueHD, LPCM, DTS-MA). I have an HD200 connected directly to a tv and I now have to go add an AC3 audio track to my DTS Blu Ray mkvs just to get sound.
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
Old 07-06-2009, 12:42 AM
lsarver's Avatar
I'm always on the lookout for new toys, but my TViX M6500-A does all this now. I use firmware .111, which correctly recognizes 24 fps. (HD DVDs are remuxed to BD.) Of course, it has been around for a while.
lsarver is offline
Old 07-06-2009, 12:48 AM
Quoted: 31 Post(s)
Liked: 30
I should mention that if menus are not a concern for you, you can in fact use llink with your Popcorn Hour to watch your HD movies.
Old 12-16-2009, 04:03 PM
ronaks's Avatar
Bumping this thread to see what the latest recommendation would be given that there are a number of new devices available.
Here's what I need:
- Ability to playback Blu-Ray ISOs
- Output all Blu-Ray audio and video formats via HDMI
- Full Menu and BD-Live Support
- Chapter Support
- Responsive Fast Forward and Rewind (local, not network)
- Support for internal 3.5" drive
ronaks is offline
Old 12-16-2009, 04:33 PM
mlknez's Avatar
Quoted: 208 Post(s)
Liked: 52
The Dune Base 3.0 will be the closest to what you are looking for.
http://dune-hd.com/hd_players/110-dune-hd-base-3.0.html
if you wish to sacrafice a 3.5" drive for a blu-ray drive then the Prime would be the one for you
http://dune-hd.com/hd_players/111-du...prime-3.0.html
They are just starting to ship is production numbers from digital connection and duneplayer.com
mlknez is offline
