HD media player for karaoke? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-19-2009, 11:17 PM - Thread Starter
kevotinh's Avatar
Hallo everyone,
I was wonder if anyone knows, if there is any HD media player that'll play Vob files, have a big remote with numbers, can play 2 audio channels, and can selects files with the number on the remote.
For example, if I have 2,000 karaoke vob files songs. Instead of selecting songs from the menu, I can just press the number on the remote and that particular song will play. Please help me.
kevotinh is offline
post #2 of 11 Old 08-30-2009, 05:43 PM
tom2t's Avatar
I been looking for solution to your question also no luck.What kind HDD media player you using?.I been try avoid using this HDD enclosure from VIVsys.com because there products is overprice.
tom2t is offline
post #3 of 11 Old 08-31-2009, 12:27 AM
hp_92117's Avatar
The only HDD Media player is MediaGate MG-350HD (DVI) or MG-450HD (HDMI) that can turn off the lyrics on the 2nd audio channel.
BTW, my friend has 2000+ songs in VNese that he is using MG-350HD to sing Karaoke.
Good lucks my friend "Ke~Vo^Tinh`"
hp_92117 is offline
post #4 of 11 Old 08-31-2009, 11:14 AM
afaa's Avatar
I bought the Ace Karaoke HDD player from ace-karaoke.net. It works like the Arrirang machines except that if you are like me who only like the DVD karaokes then this works perfectly. You can rip DVD songs into individual VOB files and use the remote to select the song by browsing or entering a number just like the Arrirang Medi files.
afaa is offline
post #5 of 11 Old 12-18-2009, 08:57 AM
l4tran's Avatar
Hello all,
I have a collection of over 300+ karaoke DVDs, I recently built myself a HTPC with HDMI output. I'm looking for a karaoke software that can rip the DVD into whatever format and plays them like a regular DVD player with the ability to turn off vocal. I have search on Google for this, but most of the karaoke software use cd+g or mp3+g which I find is far inferior to karaoke DVD. I have also tried several software demos such as MTU hoster, or Unify Karaoke, none of which can do what I need.
Is there anybody on the same boat as I?
l4tran is offline
post #6 of 11 Old 12-18-2009, 07:29 PM
celitrd2's Avatar
Dude, your answer is Brite-View. Get the CinemaTube model or the BV-6000P (same as CinemaTube without network). I use it to play iso/vob dvd/vcd images, rmvb movies, and hd movies. It has a full feature remote that will allow you to seamlessly change the audio l/r and subtitles with a push of a button. This device should take care of all your media playing needs.
Originally Posted by kevotinh View Post
Hallo everyone,
celitrd2 is offline
post #7 of 11 Old 12-19-2009, 10:29 AM
nitekonline's Avatar
l4tran,
Have you tried tkaraoke of tkaraoke.com? You have to do some work but I think it is worth it.
Nick,
nitekonline is offline
post #8 of 11 Old 12-20-2009, 04:58 PM
l4tran's Avatar
Originally Posted by nitekonline View Post
l4tran,
Nick,
Thanks niteonline, tkaraoke is exactly what I've been looking for. Now, does anybody want to trade vietnamese karaoke vob files )
l4tran is offline
post #9 of 11 Old 01-14-2010, 10:48 PM
vlai's Avatar
hey kevotinh,
have you try the mediagate that hp_92117 has suggested? does it work with the # pressing for song searching? wondering if you have found out any other media player that does it. please advise. thanks
vlai is offline
post #10 of 11 Old 03-08-2011, 08:18 AM
Son_pcbservice's Avatar
hello everybody
I got the Karaoke machine that you guy looking for and i had test with all the function that u guy need, if you guy need information just email me.
pcbservice82@yahoo.com
Son_pcbservice is offline
post #11 of 11 Old 04-14-2013, 04:04 PM
kc7fys's Avatar
Excuse me for replying to such an antique post. I purchased the same, or similar 2HDD machine from the same firm. Terrible customer service despite their "Golden Service Plan" thing on their site--but the machine works good for us. Zillions of songs and fun to use. We are veterans of 10 years in Tokyo, so we wanted something we could really use. This did the trick. Do you add songs? I have never, and want to know if it's easy.
Jonathan, St. Paul, MN
kc7fys is offline
