Western Digital - WD TV Live Media Player (WDTV2) - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 10-12-2009, 01:08 AM
voggers's Avatar
Anyone tried Flickr on the box?
Does it let you log in so you can view your private photos?
voggers is offline
Old 10-12-2009, 01:38 AM
lone-ranger's Avatar
wow 512mb that does sound nice
lone-ranger is offline
Old 10-12-2009, 01:55 AM
joshjoshlol's Avatar
sorry to be a nag in all this, but if i may resurrect an older request of mine that's been buried in this thread...
Originally Posted by joshjoshlol View Post
i'm wondering if the WDTV team included tag hiding in .ssa/.ass subtitles. can anybody mux this subtitle file into an mkv along with any old video and see if the tags within {} braces are hidden/displayed on the WDTV Live?
http://www.sendspace.com/file/6z0mp7
i've put in a variety of tags, such as bold, italic, place movement, translator comment, etc. greatly appreciated if anybody could test it.
thanks for anyone who will take this one up.
joshjoshlol is offline
Old 10-12-2009, 02:45 AM
Goba's Avatar
So there is a 1080p 24HZ and 1080p 23,976Hz option?
Can someone test a 23,976fps Mkv with the option 1080p 23,976Hz, to see if there is stutter or 40 second lost frame, like happens with WD TV 1?
Does WD TV Live do Autodected frame rate? Or do we still have to change manually the refresh rate depending on the movie fps?
Thx!
Goba is offline
Old 10-12-2009, 03:49 AM
daskino's Avatar
From the manual I can see the following features and new features
WD TV Live Manual
New Functions
* still has 2 usb ports, great for adding ie a wireless adapter and a hd
* Search function for all types of media, and on-screen keyboard for input
* support and cables for Component og Composite and HDMI (no HDMI cable included)
* Music can be sorted by album, genre, Artist, Number, and it can read Itunes and normal playlists
* Network DHCP or static IP adr.
* Option for adding wireless adapter by USB port, and support for wireless setup in the menu with WPA2
* a connected usb harddisk can act as a network harddive when connected to the wd tv, other clients can see and acess the harddisk.
* flickr, youtube, 365 og Pandora web services built into the menu with login and search
* file magement for delete, copy, move on usb harddisk
* change of border and size of subtitles
* Photo scaling size, Diff transitions in slideshow and interval between pics in slideshow
daskino is offline
Old 10-12-2009, 04:26 AM
ff_mark's Avatar
anyone know if these are available in the UK yet ?
Mark
ff_mark is offline
Old 10-12-2009, 04:27 AM
daskino's Avatar
wonder how the media library will handle search and indexing of network drives? Will it scan and build an index when you add a share to the player?
daskino is offline
Old 10-12-2009, 04:28 AM
tzyn's Avatar
@stumlad
You have set the audio output to "digital"? I think you have it set to "analog" and so the wdtv live downmix if he can (just für DD and DTS supported).
Could you tell us where you found the "23.976/24Hz" mode? Because in the interface video on youtube there was no option for 24p. But maybe the wdtv live detect and only show 24Hz if the tv support it.
@uefa_007
Dunno what you mean, but the old wdtv also scaled every file up/down to the selected resolution afaik. I use 1080p for all my files, SD and HD.
tzyn is offline
Old 10-12-2009, 04:38 AM
hijack's Avatar
So, the support is over for the WD TV 1? Any updates on that???
hijack is offline
Old 10-12-2009, 05:22 AM
Goba's Avatar
+1
Firmware is 90% of a player...
Goba is offline
i would doubt it hijack; one could easily envision western digital trying to establish a brand identity with the WDTV line and as such they probably wouldn't want to overtly flaunt any sort of planned obsolescence with their products. they want returning customers throughout the numerous iterations, and if the incentive for buying the next new thing is that the previous is completely killed off... well, nobody would even bother with such a company in the first place and just go with the competition.
short version: they'll likely still support the original wdtv
Old 10-12-2009, 05:39 AM
kevin2's Avatar
I tried this and the subtitles were there but the formatting bold, italics, and placement were not and the comment showed up too. They all played on the bottom of the screen.
So my take is that it doesn't work like you would like, but this was the first time I ever tried this so I might have missed something. I used mkvmerge and a sample video that came with Vista.
kevin2 is offline
Old 10-12-2009, 05:43 AM
uefa_007's Avatar
Originally Posted by tzyn View Post
@stumlad
@uefa_007
Yeah mate .. Look however it can upscale a 480P to 720P , clarity wise there will be improvement. However even though u play it at 1080P , it has the same clarity of 720P..
uefa_007 is offline
Old 10-12-2009, 05:50 AM
fits79's Avatar
Quoted: 46 Post(s)
Scott don't answer to any pm?
And these two videos:
1. basketball 60fps 1080p 10000kbps
2. Planet_Earth_From Pole_to_Pole_1080p_sample_16ref
It don't play well on the wd hd tv 1 but it play normal on wd hd tv live?
fits79 is offline
Old 10-12-2009, 05:53 AM
stumlad's Avatar
@stumlad
Ah yes... I found it. DTS core is coming through now. TrueHD was bitstreaming even with analog/stereo option on.
Settings menu, then choose Audio/Video, then choose Video Output (should be hdmi by default)... if you click OK on it, you'll have 3 options (Composite, Component, HDMI), click OK on hdmi, another menu will popup... the last 4 options: 1080p 23.976, 1080p24, 1080p50, 1080p60.
I think it will show 23.976/24 on all tvs, but try it out.
I can try it with a blu-ray m2ts, but I'm not sure how I'd determine if the frame is lost. Is it really noticeable?
stumlad is offline
Old 10-12-2009, 05:54 AM
liquidmetal's Avatar
For those that have network shares working (I don't), can you let us know:
1. What OS?
2. Blank password or not?
3. Any other details?
liquidmetal is offline
Old 10-12-2009, 06:04 AM
tzyn's Avatar
@stumlad
So that mean there's already no working autoframerate-selection and you need to select the correct resolution/frequency by yourself?
About 23.976:
First of all it would be interessting what info your tv gives you if you select 1080p/23.976Hz. The old wdtv1 has this option, too, but it jumps to 480p/60Hz (so it was useless/out of function). But if it shows you 1080p@24Hz and/or the bluray m2ts runs smooth, then everything should be ok.
ps: I ordered a wdtv live yesterday (here in germany it seems to be available in the next 1-3days) and I hope it will be delivered by weekend. So I can compare the old one with the new one.
tzyn is offline
Old 10-12-2009, 06:31 AM
spark9990's Avatar
Post 324 answers your question. (its yes, they play flawlessly)
spark9990 is offline
Old 10-12-2009, 06:34 AM
liebowa's Avatar
Just to expand on this - did you play these over USB, or a network?
liebowa is offline
Old 10-12-2009, 06:41 AM
BounceMeister's Avatar
Originally Posted by leoleu View Post
I have the information from WD that DVD menus support for both players will come in next fw update very soon.
ScottWD, can you please confirm this?
BounceMeister is offline
Old 10-12-2009, 06:43 AM
ChayesFSS's Avatar
Any Hulu or Netflix going on here yet?!?!
ChayesFSS is offline
Old 10-12-2009, 06:56 AM
YukonJack's Avatar
Has anyone tried Pandora on the new unit? That is my primary interest in getting one, and of course to transfer my ripped DVDs through my network without having to copy to another drive and then manually transferring them.
Greg
YukonJack is offline
Old 10-12-2009, 07:01 AM
hijack's Avatar
If you connect a 2TB My Book Essential Desktop Hard Drive threw usb to the wdtv2 does it work as a NAS? I mean, can you place content on the drive remotely and play it on the wdtv2? This would be better than streaming.
hijack is offline
Old 10-12-2009, 07:03 AM
hijack's Avatar
ScottWD:
Any WD TV1 support news?
hijack is offline
Old 10-12-2009, 07:04 AM
spark9990's Avatar
It wasn't me, but if you read the post it says that the test was done over the network.
Old 10-12-2009, 07:11 AM
stumlad's Avatar
1. What OS?
I tested it out with WHS. I am able to connect to it as a media server, AND i can connect to it as a network share. When using it as a network share, it asks for user/pass.
About 23.976:
There is an AUTO selection, or you can choose anywhere from 480p (even 576) all the way to 1080p60 (including the 23.976/24). I only have one device that supports 1080p24 (my projector) so I'll have to test it out tonight and see how it works. Will post a followup.
stumlad is offline
Old 10-12-2009, 07:18 AM
csgamer's Avatar
Liked: 29
Just ordered one. 3-5 day until shipping wait.
Now i need to order a hard drive. Hmm, what to get. 2.5" usb powered, kinda expensive, low GB amount. Pre-made external drive, less warranty, possible crappier drive inside, crappier enclosure. Get my own 3.5" internal drive and pick my own external enclosure. Or use a docking station. Don't know much about those NAS thingies but they are expensive. Hmmm.
Anybody using a 3.5" internal drive with a docking station with the wdtv? Newegg has a combo deal, wondering if that would be a good idea.
csgamer is offline
Old 10-12-2009, 07:22 AM
Chadillac's Avatar
I've tried Live365 and Pandora on the new Live Media Player. Both worked great - for Pandora, I just logged in using my existing account info. All of my stations were there - Brilliant!
Chadillac is offline
Old 10-12-2009, 07:26 AM
tzyn's Avatar
@stumlad
Yeah thanks.
The resolution-settings-menu is the same. But you could also try what happen if you select Auto and play a bluray file. The old wdtv just select 1080p/60Hz with auto, also for PAL and 24p files.
tzyn is offline
Old 10-12-2009, 07:38 AM
Darknyt's Avatar
@stumlad
@uefa_007
Not sure if this is answering my question - but will new WDTV scale most everything (properly encoded!) to my 1080i res? Notably, upscale 720p to my 1080i or will it just drop it, I dunno what to expect?
Darknyt is offline
